Not sure if this thread is still active, but I struggled also with the devices showing as offline is ESPHome.
My solution was to allow “unregistered forward” in the multicast filter-rule of my switch.
Regards,
Uli
Regards,
Uli
Only fix for me is to go and “reconnect” then in Unifi controller. Then they’re back to being online.
The marked solution works only for the HA appliance environment.
For those who run esphome dashboard in a separate docker environment (e.g. local PC), on the same network, using mDNS resolver:
In details:
An example docker configuration:
$ docker run -it --name esphome-db --network=host \
-v "$PWD":/config \
-e ESPHOME_DASHBOARD_USE_PING=true \
-v /var/run/dbus:/var/run/dbus \
-v /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket \
esphome/esphome
esphome-db$ apt -qq update && apt -y install avahi-utils # in container
Yes, installing avahi-utils manually in every container is inconvenient. You can use your own ‘forked’ images or whatever, but at least it works.
This isn’t really necessary with modern OS (eg Windows/Ubuntu 22.04…) as mDNS is already propagated to the container. I spent a good while trying to fix my container setup (including the steps described above) before realizing that the docker host resolver is looking for .home
rather than .local
(the ESPHome default). All I needed to do was add a domain: .home
entry to the wifi section of the device config and all is well
Alternatively one could modify the host resolver to handle .local
searches (I didn’t want to do that)
