If anyone is still stuck try and set a static ip, that did the trick for me:
Lots of posts all over about this issue.
Seems one of the problems is Unifi equipment and mDNS
Solution posted is change
status_use_ping: true
I don’t see anywhere to enter this, nor a config file that mentions status
sorry to resurrect an old topic!
It’s in the configuration of the ESPHome addOn. Not in a device config file, the yaml, but rather a general setting in ESPHome.
Config > AddOns > ESPHome > Configuration > status_use_ping
thank you - will be doing that
Oh my god I love you!!
Thanks to you, I finally solved this problem!
Yes, as the saying goes, at UniFi not everything that glitters is gold
finally clear instructions… Thank you paddy !!!
