ESPHome: DIY Irrigation Controller With Internal Scheduler
HI @bremby Thank! I havent installed yet, i have to make a modification at pump shelter. I tested on my kitchen table :sweat_smile: everything was working but I dont remeber if I tested that specific function.
regards
@bremby hi again! if you define initial, every time you reboot HA it will set to that value. will lost you days or times settings.
Bye
@bremby guess what?? it“s me again :stuck_out_tongue_closed_eyes: delete initial from code
From my config.yaml
input_number:
  irrigation_zone1_duration:
    name: Duración Zona 1
    min: 0
    max: 30
    step: 1
    mode: slider
    icon: mdi:timer
Tell me if that works
Regards
thanks for noticing this. Maybe because i am spanish speaker and in spanish today = ā€œhoyā€, just 3 letters so i didn’t have that problem when i modified irrigation.h
regards,
I managed to make everything working and cover 6 zones
this is the configuration page
I also added 2 additional switches
one to stop all the schedules when they are running
    name: Stop All Zones
    icon: mdi:sprinkler-variant
    optimistic: true
    turn_on_action:
      - switch.turn_off: irrigation_channel_1
      - switch.turn_off: irrigation_channel_2
      - switch.turn_off: irrigation_channel_3
      - switch.turn_off: irrigation_channel_4
      - switch.turn_off: irrigation_channel_5
      - switch.turn_off: irrigation_channel_6
      - delay: 10s
      - switch.turn_off: irrigation_stop_zones
one to ā€œsuspendā€ the schedule (eg. you want to suspend the irrigation for a period of time, but you don’t want to clean the configurations or turn off the esp)
    name: Irrigation Zone 1
    lambda: return id(irrigation_channel_1).state;
    optimistic: true
    turn_on_action:
      # Turn on if not disabled and not running
      if:
        condition:
          and:
            - lambda: return id(irrigation_zone_1_duration) > 0;
            - binary_sensor.is_off: ui_stop_irrigation_automation
        then:
          - switch.turn_on: irrigation_channel_1
    turn_off_action:
let me know what you think or if you have made additional configurations or have any suggestions
regards
Hi! great Job…i thinking about different season config, you dont need the same amount of water in autumn and winter, as in spring and summer.
Regards
Hey all, thinking about giving this project a try. I notice the device used for switching is a Sonoff 4 Channel Pro R2. I don’t seem to be able to find one and the link in the blog article says it is out of stock.
Does anyone know if a Sonoff 4 Channel Pro R3 would work or is this something different again?
Also would this be suitable as a power supply?
Hi @currest2620,
I used an ESP32 module with an 8ch relay module:
LILYGOĀ® TTGO T-Internet-POE ESP32-WROOM LAN8720A Chip Ethernet Adapter And Downloader Expansion Board Programmable Hardware - Module - Shenzhen Xin Yuan Electronic Technology Co., Ltd
ELEGOO Relay Module with Optocoupler for Arduino UNO R3 MEGA 2560 1280 DSP ARM PIC AVR STM32 Raspberry Pi – ELEGOO Official
The trick is adjusting the PINOUT definition with your board
Nice, though I would prefer to use a sonof four channel as the relays are built in.
Thank you for letting me know about the outdated Sonoff link (I am updating the link on my post). The R3 looks to be a direct replacement for the R2, so it should work the same.
Awesome. I’ll get one ordered. Thanks for the feedback.
So I have everything configured but I’m running into an issue.
I have it scheduled for Saturday @05:53 and Monday @11:00. The next watering for zone 1 should say Monday @11:00 since the watering for Saturday has already ran but it’s showing Saturday @11:00.
Not sure why it’s not following the schedule.
Hi! @stinger that’s because the schedule is for every day, you can’t choose the time for each days… So, if you choose Saturday and Monday, and then you set it to run at 5 am and 11am, it will run those two days at those two hours :grimacing:
Thanks for the info. I’ll see what I can do to modify it to fit my needs.
Hey guys, I have received the Sonof 4ch pro R3 and have flashed it with ESP Home. So now I would like to try out the ESP home code.
The first, most basic question I have is … what do I do with then irrigation.h file? Do I copy that to any specific location?
I am also unsure about these includes in the irrigation.yaml file:
  <<: !include common/substitutions/gpio/sonoff4chpror2.yaml
  <<: !include common/esphome/leds/status_with_api.yaml
Where do I obtain these files and where do they go?
Hold the phone… think I’ve worked it out. Pretty basic really.
OK, got this setup on the SONOF 4CH Pro. Seems to be working OK. I’ll run some tests to check.
Todo, is to have the system run on certain days, say every second day (to comply with local water restrictions) and to have the duration minutes displayed on the card, (I only see the slider).
Awesome work. Thanks for the instructions and documentation.
@VikingBlod @joaquin68 I really need help here.
I re-installed HA and the ESP and now I’m stuck with the never-ending loop
can you help me with the steps to successfully load the code and stop the reboot very 60 seconds?
Regards
Hi! @bremby did you upload my code or others code? Did you verified this?
https://community.home-assistant.io/t/esphome-diy-irrigation-controller-with-internal-scheduler/171844/41?u=joaquin68
@joaquin68 , yep. last month i started from your code and i added 6 zones. but now after the re-install (i reloaded the config from the backup) probably i missed something and the esp reboots every 60sec. I think that this happen when it try to get the time from home assistant. i really don’t remember what step i did last time to fix it
here the config.xml
### IRRIGATION
input_text:
  ##Time Schedule
  irrigation_zone_1_times:
    name: Time Schedule - Zone 1
    icon: mdi:chart-timeline
    mode: text
    #initial: 01:00
##Day Schedule
  irrigation_zone_1_days:
    name: Day Schedule - Zone 1
    icon: mdi:calendar-week
    mode: text
    #initial: mon
input_number:
  ##Duration
  irrigation_zone_1_duration:
    name: Duration - Zone 1
    min: 0
    max: 30
    step: 1
    mode: slider
    icon: mdi:timer
    #initial: 5
this is the ESP config
esphome:
  platform: ESP32
  board: esp-wrover-kit
  includes:
    - irrigation.h
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  power_pin: GPIO12
  manual_ip:
   static_ip: 192.168.1.x
   gateway: 192.168.1.x
   subnet: 255.255.255.0
   dns1: 192.168.1.x
   dns2: 192.168.1.x
# Enable logging
logger:
# Enable Home Assistant API
api:
  reboot_timeout: 0s
ota:
globals:
  # Irrigation time remaining
  - id: remaining_time_1
    type: int
    restore_value: no
    initial_value: "300"
  # Store previous values to verify change.
  - id: remaining_time_1_previous
    type: int
    restore_value: no
    initial_value: "0"
binary_sensor:
  # Connection status
  - platform: status
  - platform: homeassistant
    entity_id: input_boolean.stop_irrigation_automation
switch:
  - platform: restart
  # Virtual Zone Switches which toggle the relay, and store the current state.
    optimistic: true
    turn_on_action:
      - delay: 10s
    optimistic: true
    turn_on_action:
      # Turn on if not disabled.
      if:
        condition:
          and:
        then:
    turn_off_action:
  # Relays which trigger solenoids
  - platform: gpio
    pin: GPIO04
    restore_mode: ALWAYS_OFF
    inverted: yes
    on_turn_on:
      then:
        # Start the countdown timer.
        - globals.set:
            value: !lambda return id(irrigation_zone_1_duration).state * 60;
        # Show the remaining time.
        - sensor.template.publish:
            state: !lambda return id(irrigation_zone_1_duration).state;
        # Show the "Next Time" as "now".
        - text_sensor.template.publish:
            state: "now"
            # state NOW on original code, change to your preferred language
    on_turn_off:
      then:
            state: "0"
        # Update the next scheduled run time.
            state: !lambda |-
              return update_next_runtime(id(irrigation_zone_1_times).state, id(irrigation_zone_1_days).state);
  - platform: uptime
    name: "Uptime irrigation-control"
  # Retrieve durations settings from the Home Assistant UI.
    entity_id: input_number.irrigation_zone_1_duration
    on_value:
      #if:
      #  condition:
      #    api.connected:
      then:
            state: !lambda return id(ui_zone_1_duration).state;
  # Store durations.
    name: Irrigation duration - Zone 1
    accuracy_decimals: 0
    unit_of_measurement: min
    icon: mdi:camera-timer
  # Countdown sensors.
    name: Remaining Time - Zone 1
    lambda: "return 0;"
    icon: mdi:timer
    on_value:
      then:
        - if:
            condition:
              lambda: return id(remaining_time_1) == 0;
            then:
# Template Text Sensors
  - platform: version
  # Retrieve list of times from the Home Assistant UI.
    entity_id: input_text.irrigation_zone_1_times
    on_value:
      #if:
      #  condition:
      #    api.connected:
      then:
        #- delay: 10sec
            state: !lambda return id(ui_zone_1_times).state;
  # Store time lists.
    name: Schedule - Zone 1
    on_value:
      then:
            state: !lambda |-
  # Retrieve list of days from the Home Assistant UI.
    entity_id: input_text.irrigation_zone_1_days
    on_value:
      #if:
      #  condition:
      #    api.connected:
      then:
        #- delay: 10sec
            state: !lambda return id(ui_zone_1_days).state;
  # Store time lists.
    name: Day - Zone 1
    on_value:
      then:
            state: !lambda |-
  # Set the next scheduled time.
    name: Next Irrigation - Zone 1
    icon: mdi:calendar-clock
# Update the countdown timers every 5 seconds.
interval:
  - interval: 5s
    then:
      - lambda: |-
          if (id(remaining_time_1) > 0) {
            // Store the previous time.
            id(remaining_time_1_previous) = id(remaining_time_1);
            // When the relay is on.
            if (id(irrigation_channel_1).state) {
              // Decrement the timer.
              id(remaining_time_1) -= 5;
              // Turn off the relay when the time reaches zero... or the remaining time fails a sanity check!
              //if (id(remaining_time_1) <= 0 || id(irrigation_zone_1_remaining).state > id(irrigation_zone_1_duration).state){
              if (id(remaining_time_1) <= 0) {
                id(irrigation_channel_1).turn_off();
                id(remaining_time_1) = 0;
            // Update the remaining time display.
            if (id(remaining_time_1_previous) != id(remaining_time_1)) {
              id(irrigation_zone_1_remaining).publish_state( (id(remaining_time_1)/60) + 1 );
# Time based automations.
time:
    timezone: Europe/Rome
    #timezone: CET-1CEST-2,M3.5.0/02:00:00,M10.5.0/03:00:00
    on_time:
      - seconds: 0
        minutes: /1
        then:
          - lambda: |-
              if (scheduled_runtime(id(irrigation_zone_1_next).state.c_str()))
                  id(irrigation_zone_1).turn_on();
Check to make sure all you input fields are properly defined. Might even want to add some values. I remember before I added those it would loop.
