ESPHome experience with m5stack products
I thought it was about time I tried out ESPHome, and this is my experience so far with m5stack products. I have uploaded it on a m5stick-c and five m5stamp-c3u’s. I’m using a Windows laptop for the install, whereas I’ve seen others have issues with a Pi or Ubuntu; so ymmv. I also have a Core 2 and v1 Paper, but ESPHome doesn’t (yet) support the displays, so I will skip them for now.
For the m5stick-c, once I clicked connect, it was there, but it would not install. I found I needed to press the middle button (below the screen) for the install to work. I’m not sure how long you have to keep it pressed, so I did so for the whole process of several minutes. I understand there’s more editing required to get the screen working with the m5stick-c, but this will come later.
For the m5stamp, you have to hold the middle button down while inserting the usb plug into the laptop. If you don’t, it won’t show up in the connection dialog. I have the c3u, and it’s possibly different for the c3, because I think that connects with an adapter rather than via the inbuilt usb. It sits on “Preparing install” for several minutes. After the install is complete, it will try to connect, and you will get “Configuration created but unable to detect the device on the network”, but don’t unplug! If you do, you’ll notice it keeps connecting and disconnecting from USB because it isn’t working. Plug it back in, remembering to hold the middle button. Then edit the config and change the top to match the code below (3 lines to be inserted). After installing this, and unplugging/re-plugging, you should be good to go.
esphome:
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: esp32-c3-devkitm-1
  variant: ESP32C3
  framework:
    type: esp-idf
As a noob, I found out the hard way you shouldn’t navigate away from the page while it’s “Preparing installation”, or it will (probably) fail. The other first-timer experience is that it’s probably not a good idea to rename the device once installed. Initially it won’t work unless you power cycle, because it will still be connected to wifi with the old name. But even after that, it appears that the yaml file maintains the original name, which might cause confusion later on.
In the latest 2022.5 Esphome, there is a new Rename option. I’ve tried it and it works well. You do need to delete and re-add the integration though.
the m5stack core module has the best compatibility because of the buttons and display.
i have the m5stamp-c3 too, but also didn’t get it to work.
if one compares the pin assignments of the devkit-c3 and the stamp-c3, he finds differences.
i think the stamp must be supported by platformio by itself, not as the devkit from espressif
I have the m5stamp-c3u working with ESPHome and esp32_ble_tracker tracker. At first it seemed to be switching the antenna between BT and wifi, so it would miss BT broadcasts. OTA updates were also not working. However, when changing the config to that below, it is now working as expected. Having said that, when I move it to where its to belong, it’s not working properly - it doesn’t connect to wifi. If I plug it into my laptop at the same location, it works, so I’m still troubeshooting what’s going on. Consequently, I have not yet tried ESPresence.
variant: ESP32C3
framework:
  type: esp-idf
  sdkconfig_options:
    CONFIG_BT_BLE_50_FEATURES_SUPPORTED: y
    CONFIG_BT_BLE_42_FEATURES_SUPPORTED: y
    CONFIG_ESP_TASK_WDT_TIMEOUT_S: "10"
UPDATE: It seems it was working all along. With esp32_ble_tracker it seems to take a minute or two to connect to wifi, and I interpreted this as not working at all. Having the LED go from red (on_boot priority 600), to yellow (priority 260, Wifi connected) to green (once api is connected) made it a lot easier to see what was happening.
so i got it working as well, thanks to your hints.
but i learned pretty fast that the c3 is basically a esp8266 with bluetooth, including the lower clock rate compared to a “full” esp32
[12:49:41][W][esp32_ble_tracker:085]: Too many BLE events to process. Some devices may not show up.
Could you please shared your code switching LED of m5stamp-c3u depending on the state that you mentioned?
Here is the on_boot section:
esphome:
  platformio_options:
    board_build.mcu: esp32c3
    platform_packages:
      - platformio/framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#2.0.2
  on_boot:
    - priority: 600
      then:
        - logger.log: "Boot - LED red"
        - <<: !include /config/esphome/include/action/m5stamp-led-off.yaml
        - delay: 500ms
        - <<: !include /config/esphome/include/action/m5stamp-led-red.yaml
    - priority: 240
      then:
        - logger.log: "Boot - LED yellow"
        - <<: !include /config/esphome/include/action/m5stamp-led-yellow.yaml
        - wait_until:
            api.connected:
        - logger.log: "Boot - LED green"
        - <<: !include /config/esphome/include/action/m5stamp-led-green.yaml
        - delay: 1s
And then the includes are along the lines of the code below. I’ve put it in a dummy repeat at the moment because I was thinking of adding more, but haven’t as yet.
- repeat:
    count: 1
    then:
      - light.turn_on:
          brightness: 100%
          transition_length: 0.1s
          red: 100%
          green: 0%
          blue: 0%
The light is defined as:
- platform: neopixelbus
  type: GRB
  variant: SK6812
  pin: 2
  num_leds: 1
Thanks for the guide, this helped a lot! My own notes: I had to use the Arduino framework with a recent version because esphome (installed on HA) complained that neopixelbus is not supported on esp-idf
esp32:
  variant: esp32c3
  framework:
    type: arduino
    # See https://github.com/espressif/arduino-esp32/releases for available versions
    version: 2.0.2
    platform_version: 5.2.0
Also: the built-in RGB LED is not working great, lots of issues controlling the color, sometimes it works, most of the time it renders a wrong color or does not react… Config is:
light:
  # Note: the built-in LED doesn't seem to behave correctly, and color control is flaky...
    type: GRB
    variant: SK6812
    pin: 2
    num_leds: 1
    method:
      type: esp32_rmt
      channel: 0
(I set the channel on esp32_rmt so that I can have a separate neopixelbus on another GPIO, but the behavior is also flaky when only the built-in LED is enabled).
Hi
I’m trying to add a ‘M5Stack Stamp C3U’ in HA ESP Home.
I’m new with ESP32 but I’ve try to read / test as much as possible without success.
The board is shown in windows 10 : USB JTAG/ serial debug unit.
Product sheet :
the main tests I’ve done was around those 2 parameters :
esp32:
framework:
type: esp-idf
I’ve also tryed :
  • flash_mode: dio
  • sdkconfig_options
  • framework:
    type: arduino
    version: 2.0.2
When I do this change :
type: arduino > type : esp-idf … it seem my first and last line have a error (1- esphome: 30- captive_portal:)
If I remove captive_portal … first line is accepted.
When having a correct syntax yaml i try to install it and error seem to be with the C compiler :
– Check for working C compiler: /data/cache/platformio/packages/toolchain-riscv32-esp/bin/riscv32-esp-elf-gcc – broken
– Configuring incomplete, errors occurred!
progressing … slowly
platformio_options:
platform_packages:
- toolchain-riscv32-esp @ 8.4.0+2021r1
- toolchain-xtensa-esp32s2 @ 8.4.0+2021r1
and (without falsh_mode)
platformio_options:
platform_packages:
Both compile but I then have connection problem
A fatal error occurred: Failed to connect to ESP32-C3: No serial data received.
For troubleshooting steps visit: Troubleshooting - ESP32 - — esptool.py latest documentation
INFO Upload with baud rate 460800 failed. Trying again with baud rate 115200.
esptool.py v3.3.1
Serial port /dev/ttyUSB0
I then saw :
using https://web.esphome.io
install works
but I have a pairing error message saying ‘only SP32 and esp8266’ supported.
Here is what is working perfect for me on current ESPHome installed as a HA Add-on (2022.11.4). In my experience, what’s critical is to explicitly set the various versions, because 2022.11.4 does not support those boards at all by default.
The code below should get you started, it will turn the M5 Stamp into the most basic RGB light imaginable, and as a bonus will also drive (as a second light) a small strip of neopixels, to demo how to do this without crashing the ESP32 at startup:
esphome:
  platformio_options:
esp32:
  variant: esp32c3
  framework:
    type: arduino
    version: 2.0.2
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "XXXXXXXXXXXXXXX"
ota:
  password: "XXXXXXXXXXX"
wifi:
  ssid: !secret wifi_ssid
  fast_connect: True
  ap:
    ssid: "Rbg-Light2 Fallback Hotspot"
    password: "XXXXXXXXXX"
light:
    type: GRB
    variant: SK6812
    pin: 2
    num_leds: 1
    method:
      type: esp32_rmt
      channel: 0
  # Adafruit "Jewel" neopixel with RBG + Warm White
    type: GRBW
    variant: WS2812
    pin: 3
    num_leds: 7
    default_transition_length: 250ms
    restore_mode: RESTORE_DEFAULT_ON # Attempt to restore, and default to ON if restore fails
    method:
      type: esp32_rmt
      channel: 1
I’m just now looking to roll out BTLE tracking. Is the M5Stamp a good candidate or should I look at a standard ESP32 module?
I had a few issues trying to get my Stamp C3U up and running a few months ago, but tried adding it to esphome today, and the automatic detection of device worked for it today. I plugged it into the laptop and flashed locally, shortly afterwards I got a notification on my phone that a new device had connected to my network.
I’m using the M5Stamp and an M5 relay module as a garage door opener. It’s also BT proxying the Yale lock in the garage. Works great with good response time.
Has anyone used espHome with M5stack Tough?
I’m also curious, I picked up one several weeks ago, but it doesn’t seem easy to integrate via espHome. Although, admittedly, I haven’t given it much effort yet. I did open up a feature request, but it hasn’t gotten any traction yet: Support for M5Stack Tough ESP32 IoT Development Board Kit · Issue #2166 · esphome/feature-requests · GitHub
