Calibrate linear or polynomial filter should work to map reading to level percent. This would let calibration be adjustable via yaml config. Otherwise you could write a function to map reading to the percent and pass that to publish_state()
publish_state(-0.0022*reading*reading*reading + 0.2778*reading*reading - 11.889*reading + 193.33);
Below sample uses a lambda call that will get the raw value from the esp32 touch binary sensor and returns it in a template sensor (as an alternative to your custom component).
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable Home Assistant API
api:
logger:
baud_rate: 115200
ota:
password: !secret esp_home_ota_pw
wifi:
ssid: !secret wifi_ssid
# Sync time with Home Assistant.
time:
- platform: homeassistant
esp32_touch:
setup_mode: false
binary_sensor:
- platform: esp32_touch
#name: "ESP32 Touch Pad GPIO27"
pin: GPIO27
threshold: 1000
icon: mdi:car-coolant-level
update_interval: 1s
lambda: |-
return (float) id(capacitive_level_hack).get_value();
filters:
- calibrate_linear:
- 20.0 -> 100.0
- 2080.0 -> 0.1
