EspHome - INMP441 microphone for voice control - pipeline error
Here is my working config for s3-dev kit board You need to set the mic to left to work on these boards:
substitutions:
  voice_assist_idle_phase_id: '1'
  voice_assist_listening_phase_id: '2'
  voice_assist_thinking_phase_id: '3'
  voice_assist_replying_phase_id: '4'
  voice_assist_not_ready_phase_id: '10'
  voice_assist_error_phase_id: '11'
  voice_assist_muted_phase_id: '12'
esphome:
  friendly_name: Master Bedroom Voice assistant
  platformio_options:
    board_build.flash_mode: dio
  on_boot:
      priority: 600
      then:
        - script.execute: control_led
        - delay: 30s
        - if:
              lambda: return id(init_in_progress);
            then:
              - lambda: id(init_in_progress) = false;
psram:
  mode:  octal
  speed: 80MHz
esp32:
  board:   esp32-s3-devkitc-1
  variant: esp32s3
  framework:
    type: esp-idf
    version: recommended
    components:
      - name:    esphome_board
        source:  github://jesserockz/esphome-esp-adf-board@main
        refresh: 0s
    sdkconfig_options:
      CONFIG_ESP32_S3_BOX_BOARD: "y"
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB:      "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B:  "y"
      CONFIG_AUDIO_BOARD_CUSTOM:           "y"
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "snip"
  on_client_connected:
  on_client_disconnected:
ota:
  password: "snip"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: *
    gateway: *
    subnet: *
  ap:
    ssid: "Master-Bedroom-Voice-Assistant"
    password: "snip"
esp_adf:
external_components:
  - source: github://pr#5230
    components:
    - esp_adf
    refresh: 0s
captive_portal:
light:
  - platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: GPIO18
    num_leds: 3
    rmt_channel: 0
    chipset: WS2812
    default_transition_length: 0s
    effects:
      - pulse:
          transition_length: 800ms
          update_interval: 800ms
          min_brightness: 0%
          max_brightness: 30%
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO3  ##INMP441-WS
    i2s_bclk_pin: GPIO2  ##INMP441-SCK
  - id: i2s_out
    i2s_lrclk_pin: GPIO6  ##Max98357 - LRC
    i2s_bclk_pin: GPIO20   ###Max98357 - BCLK
    ## l/R pin on ##INMP441 is connected to ground
microphone:
  platform: i2s_audio
  adc_type: external
  i2s_audio_id: i2s_in
  i2s_din_pin: GPIO4
  channel: left
  pdm: false
speaker:
  platform: i2s_audio
  dac_type: external
  i2s_audio_id: i2s_out
  i2s_dout_pin: GPIO8  ###Max98357 - DIN
  mode: mono
voice_assistant:
  microphone: external_microphone
  speaker: external_speaker
  use_wake_word: true
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.5
  on_listening:
    - lambda: id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
  on_stt_vad_end:
    - lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
  on_tts_stream_start:
    - lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
  on_tts_stream_end:
    - lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
  on_error:
    - if:
          lambda: return !id(init_in_progress);
        then:
          - lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
          - delay: 1s
          - if:
                switch.is_on: use_wake_word
              then:
              else:
                - lambda: id(voice_assistant_phase) = ${voice_assist_muted_phase_id};
    - if:
        then:
          - voice_assistant.start_continuous
        else:
    - lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
switch:
    name: Use Wake Word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
      - if:
          then:
            - if:
                    not:
                      - voice_assistant.is_running
                then:
    on_turn_off:
      - if:
          then:
            - voice_assistant.stop
globals:
  - id: init_in_progress
    type: bool
    restore_value: no
    initial_value: 'true'
  - id: voice_assistant_phase
    type: int
    restore_value: no
    initial_value: ${voice_assist_not_ready_phase_id}
script:
  - id: control_led
    then:
      - if:
          then:
            - if:
                    wifi.connected:
                then:
                  - if:
                          api.connected:
                      then:
                        - lambda: |
                            switch(id(voice_assistant_phase)) {
                              case ${voice_assist_listening_phase_id}:
                                id(led).turn_on().set_rgb(0, 0, 1).set_brightness(1.0).set_effect("none").perform();
                                break;
                              case ${voice_assist_thinking_phase_id}:
                                id(led).turn_on().set_rgb(0, 1, 0).set_effect("slow_pulse").perform();
                                break;
                              case ${voice_assist_replying_phase_id}:
                                id(led).turn_on().set_rgb(0, 0, 1).set_brightness(1.0).set_effect("fast_pulse").perform();
                                break;
                              case ${voice_assist_error_phase_id}:
                                id(led).turn_on().set_rgb(1, 1, 1).set_brightness(.5).set_effect("none").perform();
                                break;
                              case ${voice_assist_muted_phase_id}:
                                id(led).turn_off().perform();
                                break;
                              case ${voice_assist_not_ready_phase_id}:
                                id(led).turn_on().perform();
                                break;
                              default:
                                id(led).turn_on().set_rgb(1, 0, 0).set_brightness(0.2).set_effect("none").perform();
                                break;
                      else:
                        - light.turn_off:
                else:
                  - light.turn_off:
          else:
            - light.turn_on:
                blue: 50%
                red: 50%
                green: 50%
                effect: "fast_pulse"
Video of them working:
