Nickthegr8
(Juanita Dickens)
September 5, 2023, 8:04am
287
hey @candidotsa @nikiyahoo , got it working after trying multiple versions of HA and but however i don’t think it is related to HA,
1st i’d advise you to turn of the inverter completely and power off ur house, then let the inverter boot up and then turn on the d1,
logs attached:
log
here’s my test code:
i’m using Home Assistant 2023.9.0b4
Supervisor 2023.09.0.dev0102
Frontend 20230904.0 - latest
esphome dev addon
esphome:
# libraries:
# - uart=https://github.com/plerup/espsoftwareserial.git#8.0.1
# Enable logging
esp8266:
board: d1_mini
logger:
level: DEBUG
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "WEpwXy3Sh8tO5Nj+ebZwsISIMNAvUIiiNwtaRwJKPlw="
ota:
password: "e1157d54ed3035ececb22b71db94c3ed"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 10.0.0.36
gateway: 10.0.0.1
subnet: 255.255.255.0
dns1: 10.0.0.1
dns2: 8.8.8.8
web_server:
port: 80
include_internal: true
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 9600
#stop_bits: 2
modbus:
uart_id: uart_modbus
flow_control_pin: GPIO4
modbus_controller:
- id: growatt
address: 0x1
modbus_id: modbus1
update_interval: 15s
setup_priority: -10
button:
- platform: restart
text_sensor:
icon: mdi:eye
entity_category: diagnostic
lambda: |-
if ((id(status).state) == 1) {
return {"Normal"};
} else if ((id(status).state) == 0) {
return {"Standby"};
} else if ((id(status).state) == 2) {
return {"Discharge"};
} else if ((id(status).state) == 3) {
return {"Fault"};
} else if ((id(status).state) == 4) {
return {"Flash"};
} else if ((id(status).state) == 5) {
return {"PV Charging"};
} else if ((id(status).state) == 6) {
return {"AC Charging"};
} else if ((id(status).state) == 7) {
return {"Combined Charging"};
} else if ((id(status).state) == 8) {
return {"Combined Charging & Bypass"};
} else if ((id(status).state) == 9) {
return {"PV Charging & Bypass"};
} else if ((id(status).state) == 10) {
return {"AC Charging & Bypass"};
} else if ((id(status).state) == 11) {
return {"Bypass"};
} else if (id(status).state == 12) {
return {"PV Charge and Discharge"};
} else {
return {"Unknown"};
- platform: modbus_controller
address: 0
register_type: read
internal: true
accuracy_decimals: 0
value_type: U_WORD
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: 60s
# Temperatures Monitors
modbus_controller_id: growatt
name: "Inverter Temperature"
address: 25
register_type: "read"
unit_of_measurement: °C
device_class: temperature
state_class: measurement
icon: mdi:thermometer
value_type: U_WORD
accuracy_decimals: 1
filters:
- multiply: 0.1
name: "PV Temperature"
address: 32
value_type: U_WORD
filters:
- multiply: 0.1
Baremeg10
(Fredrik)
September 5, 2023, 8:55am
288
Hi
I have been using ESPHome with an esp8266 and reading data with modbus from a Growatt Mid17ktl3-x. This has been working really nice, but i have had one problem with all the non accumulating “output power” readings. The value resets to 0 every ~6500W. So if the production is 4000W it shows 4000W, but if the production is 7000W it shows 500W (see picture below)
Have any of you had the same problem?
ESPHome config
substitutions:
devicename: Growatt
friendly_name: "Growatt inverter"
update_fast: 10s
update_slow: 60s
esphome:
esp32:
board: wemos_d1_mini32
framework:
type: arduino
wifi:
ssid: !secret Wifi_SSID
password: !secret Wifi_pw
ap:
ssid: "Ute Temp Fallback Hotspot"
password: "<<REMOVED>>"
captive_portal:
# Enable logging
logger:
level: DEBUG
baud_rate: 0
time:
- platform: homeassistant
api:
encryption:
key: "<<REMOVED>>"
ota:
# Example configuration entry
spi:
miso_pin: GPIO17
mosi_pin: GPIO21
clk_pin: GPIO16
uart:
tx_pin: 3
rx_pin: 1
baud_rate: 9600
#baud_rate: 115200
debug:
direction: RX
dummy_receiver: false
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
modbus:
uart_id: mod_bus
modbus_controller:
- id: growatt
address: 0x1
modbus_id: modbus1
setup_priority: -10
update_interval: 30s
text_sensor:
icon: mdi:eye
lambda: |-
return {"Normal"};
return {"Standby"};
return {"Fault"};
} else {
return {"Unknown"};
address: 0
internal: true
#### temp ###
name: "${friendly_name} Inverter Temperature"
address: 93
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} input power"
address: 2
unit_of_measurement: W
device_class: power
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} output power"
address: 36
device_class: power
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} grid frequency"
address: 37
unit_of_measurement: Hz
device_class: frequency
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.01
name: "${friendly_name} output energy generated today"
address: 54
unit_of_measurement: kWh
device_class: energy
state_class: total_increasing
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} output energy generated lifetime"
address: 56
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} worktime total"
address: 56
unit_of_measurement: s
device_class: duration
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
##PV1##
name: "${friendly_name} PV1 voltage"
address: 3
unit_of_measurement: V
device_class: voltage
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} PV1 current"
address: 4
unit_of_measurement: A
device_class: current
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} PV1 power"
address: 6
device_class: power
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} PV1 power today"
address: 60
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
##PV2##
name: "${friendly_name} PV2 voltage"
address: 7
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} PV2 current"
address: 8
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} PV2 power"
address: 10
device_class: power
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} PV2 power today"
address: 64
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
## Ute Temperatur
- platform: max31865
cs_pin: GPIO22
reference_resistance: 430 Ω
rtd_nominal_resistance: 100 Ω
mains_filter: 50 Hz
filters:
- lambda: return x - 1;
Edit:
For further readers: The solution is in post 324.
Nickthegr8
(Juanita Dickens)
September 5, 2023, 9:04am
289
try
addon and monitor if the value resets as well after 7kw production, if so then it is inverter related,
i haven’t seen such an issue with my setup, values read correctly here and i don’t see a config issue in ur code,
candidotsa
(Cândido Sá)
September 5, 2023, 7:42pm
290
Hi. Thanks for the tip. I was thinking about using the add-on but didn’t see much info. I just finished installing but I can’t put the mqtt working. Can you “show” your config? And another question, can you change the parameters of the inverter?
Nickthegr8
(Juanita Dickens)
September 5, 2023, 7:45pm
291
There u go
From grott no i cant, from esphome i can
Nickthegr8
(Juanita Dickens)
September 5, 2023, 7:49pm
292
Don’t forget to change shinewifi ip to your ha ip to proxy the data, i’ve changed it from server.growatt.com
candidotsa
(Cândido Sá)
September 5, 2023, 7:54pm
293
Thanks.
I’m not at my home, can’t change . I will leave for the end of the month. But at least it’s explain why I don’t receive any data .
candidotsa
(Cândido Sá)
September 5, 2023, 7:57pm
294
It’s possible to change the config of the inverter?
nikiyahoo
(Niki)
September 12, 2023, 8:14am
296
Thank you for the idea @Nickthegr8 . Turning everything off and powered it again fixed the problem.
I think I did it before, but maybe not waited enough.
Now communication is OK and monitoring and changing parameters working.
Only for “Bat Low Volt Switch To Uti” and “Mains to battery operating point” give me errors because in my case with Lifepo4 there must be percentage not voltage.
@candidotsa in my case address for “Charge Source” is 02 and for “Output Source” is 01. In your code is opposite. Is it mistake or there are different versions of modbus addresses?
Also, when I have more time I will try to add more data from inverter.
candidotsa
(Cândido Sá)
September 12, 2023, 7:34pm
297
Hi. Next weekend I will see if shutting down the inverter work’s.
I use the codes from growatt pdf but a think that i change those two values after a few days of using. I don’t remember but in my code I have the same as you.
Fer
(Tommy Fer)
September 18, 2023, 7:27pm
299
Does anybody have a configurationfile for a MOD10KTL3-XH Hybrid inverter. I know how to do the normal inverter stuff, but I would like to see a configuration with the battery controls, and mode selctions etc.
candidotsa
(Cândido Sá)
September 30, 2023, 7:51pm
300
thanks for your help. i’m using grott for readings and is stable. my problem now is to configure the inverter but i see that is possible to do with grott will take a look.
candidotsa
(Cândido Sá)
September 30, 2023, 7:54pm
301
[20:52:53][V][modbus:042]: Modbus received Byte 3 (0X3)
[20:52:53][V][modbus:042]: Modbus received Byte 77 (0X4d)
[20:52:53][V][modbus:042]: Modbus received Byte 10 (0Xa)
[20:52:53][V][modbus:042]: Modbus received Byte 5 (0X5)
[20:52:53][V][modbus:042]: Modbus received Byte 1 (0X1)
[20:52:53][V][modbus:042]: Modbus received Byte 100 (0X64)
[20:52:53][V][modbus:042]: Modbus received Byte 144 (0X90)
[20:52:53][V][modbus:042]: Modbus received Byte 21 (0X15)
[20:52:53][V][modbus:042]: Modbus received Byte 124 (0X7c)
[20:52:53][V][modbus:042]: Modbus received Byte 20 (0X14)
[20:52:53][V][modbus:042]: Modbus received Byte 65 (0X41)
[20:52:53][V][modbus:042]: Modbus received Byte 175 (0Xaf)
“bard” told me this:
The Modbus data you have provided is a response to a read request for 14 bytes of data starting at register 0x02. The data is as follows:
Byte
Value
Description
2
0x4d
DC input voltage (48V)
77
0x64
DC input current (100A)
10
0x0a
AC output voltage (230V)
5
0x05
AC output current (5A)
1
0x01
Inverter status (normal)
100
0x64
DC input power (4800W)
1
0x01
AC output power (1150W)
1
0x01
Inverter temperature (40 degrees Celsius)
144
0x90
Battery voltage (144V)
21
0x15
Battery current (21A)
124
0x7c
Battery power (3024W)
20
0x14
Battery temperature (20 degrees Celsius)
82
0x52
Battery status (normal)
73
0x49
Battery cycles (73)
227
0xe3
Inverter hours (5297)
Nickthegr8
(Juanita Dickens)
October 1, 2023, 5:26am
302
Did u poweroff for more than 5 minutes? Complete poweroff trip all breakers, poweroff esp32 remove rj45 power on then once started replug. For us that worked.
Make sure ur modbus address is correct and also try updating ha and esphome, i’m on beta versions
Nickthegr8
(Juanita Dickens)
October 1, 2023, 5:29am
303
I think so also as we’re proxying the wifi module but maybe the developer of grott can help?
candidotsa
(Cândido Sá)
October 1, 2023, 7:10am
304
I left everything off during a night. For now I will work with grott, is working fine and is less one esp in the network. But thanks for the tip
Been looking here for a while now to replace the current terrible monitoring of my solar syste,.
have bought an shinelink-X and wanted to flash ESPhome on it. but am unable to.
I found out i needed to bridge the GPO01 with ground while plugging in, but ESPHome keeps telling me its trying to connect. Tried with an CH340 flasher and plugging in the usb directly.
is there a way to fix this and flash ESPHome?
candidotsa
(Cândido Sá)
October 11, 2023, 8:39pm
306
Hi
If you just need the readings you can use the grott. It’s the easiest way at moment.
