That is really nice work!! Thank you for sharing!
Is the rs485 connected to the com port on pin 3 and 4? And the USB is only for power the TTL converter and the D1 mini? Or is the ground connected to the com plug also?
Correct, in my case, the USB is just for power.
The green/white wires are cut and don’t connect into the USB-A connector.
Instead, they connect the RS485 converter to pin 3&4 of the COM port.
Red and black take 5v from the USB-A, over to the D1-mini and the RS485 converter.
This was the RS485 converter I used: Stable UART Serial Port to RS485 Converter Function Module RS485 to TTL Module k | eBay
And this is how its wired:
I had previously tried the ESPHOME ‘growatt_solar’ sensor platform with this hardware.
On my 1500TL-X, it read one or two values. But most were NaN.
However, with the code here, it populates all values perfectly.
substitutions:
device_name: growatt-mic-1500tl-x
device_description: "Growatt Solar Inverter Monitoring"
friendly_name: Growatt MIC 1500TL X
esphome:
comment: '${device_description}'
esp8266:
board: d1_mini
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
ota:
safe_mode: true
reboot_timeout: 10min
num_attempts: 5
web_server:
port: 80
auth:
username: !secret esphome_web_username
password: !secret esphome_web_password
wifi:
ssid: !secret wifi_ssid
# Optional manual IP
ap:
ssid: '${device_name}'
password: !secret fallback_password
captive_portal:
time:
- platform: homeassistant
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 9600
#baud_rate: 115200
modbus:
uart_id: mod_bus
modbus_controller:
- id: growatt
# the Modbus device addr
address: 0x1
modbus_id: modbus1
setup_priority: -10
- platform: modbus_controller
address: 5
register_type: "read"
unit_of_measurement: W
device_class: power
icon: mdi:flash
value_type: U_DWORD
accuracy_decimals: 1
filters:
- multiply: 0.1
name: "${device_name} DcVoltage"
address: 3
unit_of_measurement: V
device_class: voltage
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${device_name} DcInputCurrent"
address: 4
unit_of_measurement: A
device_class: current
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${device_name} AcFrequency"
address: 37
unit_of_measurement: Hz
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.01
name: "${device_name} AcVoltage"
address: 38
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${device_name} AcOutputCurrent"
address: 39
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
address: 40
device_class: power
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${device_name} EnergyToday"
address: 53
unit_of_measurement: kWh
device_class: energy
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${device_name} EnergyTotal"
address: 55
state_class: total_increasing
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${device_name} Temperature"
address: 3093
unit_of_measurement: C
device_class: temperature
icon: mdi:thermometer
value_type: U_WORD
filters:
- multiply: 0.1
Internal: false needs to be added to all exposed sensors as of the last esphome version
Thank you for keeping an eye on the topic! In this case it is only about the homeassistant platform. So no worries.
Sure? It’s says All sensors. Not in line with the title of the issue
Yes im sure. The GitHub pr is a little misleading. I updated my device today and it is al fine😉
I found a way to upload to pvoutput.org, from home assistant.
PVOuput Uploader - #26 by rieschard
Next step is to do it in esphome. That shouldnt be too hard
Is this code also working on three-phase inverters?
I’m preparing to test it out on a Growatt MOD 5000TL3-X with ShineWifi-X in a few weeks, when the inverter is powered up
Yes. Get the code for de X Growatt/shinewifi-x.yaml at 696aab77c35bceb7e72333253cfb7fa8c6d04c1e · WilbertVerhoeff/Growatt · GitHub if you need help, please let me know.
For everyone that is using my previous code. This is better and far more accurate and reliable.
Grid Power Today can be used for incoming old power if you’re grid connected (input)
AC Output Today is all AC Output from the device.
Charge Power (today) is how much AC charging from the grid.
This lets you put in accurate values into the Energy tab. I’ve tested all of these values against a calibrated meter and they’re within like 1-2% of real. Let me know if there are any other values anyone would find useful. (for other inverters there are data points for multiple PV inputs etc. and this should work for all “off grid” inverters. It won’t work for grid connected.
substitutions:
friendly_name: "Growatt Inverter"
esphome:
platform: ESP8266
board: esp01_1m
api:
ota:
password: !secret esphome_ota_password
wifi:
captive_portal:
logger:
level: DEBUG
baud_rate: 0
web_server:
port: 80
time:
output:
# Blue Led
- id: light_bl
platform: gpio
pin: 16
# Green Led
- id: light_gr
platform: gpio
pin: 0
# Red Led
- id: light_rd
platform: gpio
pin: 2
uart:
- id: mod_bus
baud_rate: 9600
tx_pin: GPIO1
rx_pin: GPIO3
modbus:
uart_id: mod_bus
flow_control_pin: GPIO4
modbus_controller:
- id: growatt
address: 0x1
modbus_id: modbus1
setup_priority: -10
text_sensor:
icon: mdi:eye
entity_category: diagnostic
update_interval: 10s
lambda: |-
if ((id(status).state) == 1) {
return {"Normal"};
} else if ((id(status).state) == 0) {
return {"Standby"};
} else if ((id(status).state) == 2) {
return {"Discharge"};
} else if ((id(status).state) == 3) {
return {"Fault"};
} else if ((id(status).state) == 4) {
return {"Flash"};
} else if ((id(status).state) == 5) {
return {"PV Charging"};
} else if ((id(status).state) == 6) {
return {"AC Charging"};
} else if ((id(status).state) == 7) {
return {"Combined Charging"};
} else if ((id(status).state) == 8) {
return {"Combined Charging & Bypass"};
} else if ((id(status).state) == 9) {
return {"PV Charging & Bypass"};
} else if ((id(status).state) == 10) {
return {"AC Charging & Bypass"};
} else if ((id(status).state) == 11) {
return {"Bypass"};
} else if (id(status).state == 12) {
return {"PV Charge and Discharge"};
} else {
return {"Unknown"};
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: 60s
address: 0
internal: true
accuracy_decimals: 0
name: "${friendly_name} Solar Energy Today"
address: 48
icon: mdi:solar-power
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${friendly_name} Battery Discharge Energy Today"
address: 60
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${friendly_name} AC Charge Energy Today"
address: 56
value_type: U_DWORD
filters:
- multiply: 0.1
- platform: total_daily_energy
name: "${friendly_name} Grid Energy Today"
power_id: grid_power
icon: mdi:counter
min_save_interval: 1h
restore: true
filters:
- multiply: 0.001
name: "${friendly_name} AC Ouput Energy Today"
power_id: ac_output_power
icon: mdi:counter
accuracy_decimals: 2
restore: true
filters:
- multiply: 0.001
name: "${friendly_name} Solar Voltage"
address: 1
state_class: measurement
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} Solar Current"
address: 7
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.02
name: "${friendly_name} Solar Power"
address: 3
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${friendly_name} AC Output Hz"
address: 23
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.01
name: "${friendly_name} AC Output Voltage"
address: 22
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} AC Output Current"
address: 34
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} AC Output Power"
address: 9
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${friendly_name} Grid Hz"
address: 21
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.01
name: "${friendly_name} Grid Voltage"
address: 20
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} Grid Current"
address: 68
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} Grid Power"
address: 36
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${friendly_name} Battery Power"
address: 77
device_class: power
icon: mdi:flash
value_type: S_DWORD
filters:
- multiply: 0.01
name: "${friendly_name} Load %"
address: 27
unit_of_measurement: percent
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} Battery SoC %"
address: 18
icon: mdi:flash
value_type: U_WORD
name: "${friendly_name} Inverter Temperature"
address: 25
unit_of_measurement: °C
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} PV Temperature"
address: 32
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} Bus Voltage"
address: 19
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
I’ve modified @pasarn’s code for the ShineWiFi-X to include PV1 and PV2 power.
As it turns out DcPower presents only presents the power of string 1 (PV1). If you have a dual string inverter like me (Growatt MIN 5000TL XE), you can include the following code in the sensor part to get the DcPower of string 2 (PV2) as well.
name: "${devicename} DcPowerPV2"
address: 10
device_class: power
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
I would also suggest to rename DcPower (from @pasarn’s code) to DcPowerPV1 if you have a dual string inverter.
Hi, I have a Growatt 750TL-X and a spare D1 mini and I’m trying to make the cable from @chopwood so that I can read values off my inverter with ESPHome.
I’ve just noticed my TTL to RS485 converter has different labels on it though? Yours has VCC, TXD, RXD & GND on the left, mine has DI, DE, RE, R0 on the left. Did I buy the wrong thing?
Okay after a bit of research I think I connect DE & RE together and also to the GPIO defined as the modbus flow_control_pin. DI goes to RX, RO goes to TX. Cross fingers.
Here is my configuration for a 3 phase Growatt inverter MOD 8000TL3-X-AU with 3 string input (even though it only appears as 2 DC inputs)
Pretty straight forward to flash on a Shine-wifi-x, just pop off the cover and connect your programmer to the header inside. Flash with ESPhome and load the code via OTA after that. I bought a second wifi-x module off ebay so I didn’t mess up the registered one for service/repairs.
here is the doc I used to figure out the modbus registers.
http://www.photovoltaicsolar.in/Growatt_Manual/MAX%20Series%20Modbus%20RTU%20Protocol.pdf
Just a note, where there is a high and low in the modbus map - ie the power values, you want to select the address for high (the lower address), and make sure you read as double word value_type: U_DWORD all the others will just be a single word value_type: U_WORD
I checked what values I wanted from the shinephone app, select the datalogger, all parameters, then other data. these values match up to the modbus map perfectly. from here I could see the 3 strings, strangely it was stings 1, 3 and 4
esphome:
substitutions:
devicename: Growatt
esp8266:
board: esp07s
# Disable logging on Serial port
logger:
baud_rate: 0
api:
encryption:
key: "xxxx"
ota:
password: "xxxx"
wifi:
ap:
ssid: "Growatt-Esphome Fallback Hotspot"
password: "xxxx"
captive_portal:
time:
output:
# Blue Led
- id: light_bl
platform: gpio
pin: 16
# Green Led
- id: light_gr
platform: gpio
pin: 0
# Red Led
- id: light_rd
platform: gpio
pin: 2
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 115200
modbus:
uart_id: mod_bus
modbus_controller:
- id: growatt
address: 0x1
modbus_id: modbus1
setup_priority: -10
- platform: uptime
name: "${devicename} Uptime Sensor"
name: "${devicename} PV1 DcPower"
address: 5
device_class: power
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} PV1 DcVoltage"
address: 3
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} PV1 DcInputCurrent"
address: 4
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} PV2 DcPower"
address: 9
device_class: power
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} PV2 DcVoltage"
address: 7
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} PV2 DcInputCurrent"
address: 8
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} AcFrequency"
address: 37
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.01
name: "${devicename} AcVoltage VAC1"
address: 38
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} AcOutputCurrent IAC1"
address: 39
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} AcPower PAC1"
address: 40
device_class: power
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} AcVoltage VAC2"
address: 42
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} AcOutputCurrent IAC2"
address: 43
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} AcPower PAC2"
address: 44
device_class: power
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} AcVoltage VAC3"
address: 46
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} AcOutputCurrent IAC3"
address: 47
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} AcPower PAC3"
address: 48
device_class: power
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Total Power"
address: 35
device_class: power
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Total Energy Today"
address: 53
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Total Energy Lifetime"
address: 55
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} PV1 Energy Today"
address: 59
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} PV1 Energy Lifetime"
address: 61
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} PV2 Energy Today"
address: 63
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} PV2 Energy Lifetime"
address: 65
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Temperature"
address: 93
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} V String 1"
address: 142
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} I String 1"
address: 143
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} V String 3"
address: 146
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} I String 3"
address: 147
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} V String 4"
address: 148
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} I String 4"
address: 149
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
i try to flash my shinewifi-x via esphome. but it is not working. the first question is do you flash it whitin home assistants esphome orw with a different flasher (esptools or somthing). and then you need set de gpio0 to GND on the x self or do you need fom gpio0 to de gnd on the usb to ttl module?
AFAIK (just managed to flash my wifi-s) I connected ground and gpio0 and connected the pins to my usb-serial converter. Had to fiddle with rx tx, but then lo and behold, it worked.
And oh, I used the USB port on my home assistant/esphome host. Flashed it through de web server.
Hope that helps?
I use a USB to serial flashing device. They are pretty cheap, and I just used jumper cables to connect to the wifi-x terminals. They are pretty clearly marked. And the gpio0 was connected between the wifi-x and the USB programmer
I did have issues jumping it to the download mode… can’t remember exactly, but I think only 2 of the 3 leds are on… Or maybe all 3 were on in the end… i was in a rush to get it done before school pickup. But I just kept hitting download and power cycling till it worked.
As the new version of ESPhome is out… and its nighttime… i decided its a great time to open up the unit and flash it via USB. this is whats inside
to flash you need to jumper GPIO0 and GND together and then plug in the USB. only 2 LED should be lit. no need for an external programmer
And dont be an idiot like me and spend 10min trying to get USB logs out of the thing to make sure its working… they are disabled! it worked instantly with wireless logs
Now that I know what’s inside and have a better idea of what’s inside I think any ESP device with USB should work, like a $7.50 d1-mini. Seems a waste to spend $75 to get the pretty unit unless you need the water resistance the cover offers.
perhaps one day someone will work out the RTC and make some pretty status lights. i think it would be wise to set the time in the inverter for error logging.
i have try it but it fails it say Failed to initialize. Try resetting your device or holding the BOOT button while selecting your serial port until it starts preparing the installation. but i have try to upload the firmware to a esp8266, and that works great it runs now for 2 days and its amazing. thanks all for your help.
Yeah I did get that message a lot, then I just kept plugging in and out till it worked.
Did you get the 2 led’s or were all 3 lit? Or sometimes all were off
The most consistent way was to bridge gpio0 and gnd then plug in the USB.
