ESPHome modbus Growatt ShineWiFi-S
hi.
This is the esphome code for Growatt SPF 5000 ES.
I’m using a d1 mini with a ttl converter.
This code allows changing the parameters of the inverter. BE CAREFUL !! (The worst thing that can happen is you have to configure the inverter again.)
The code has all the configurations that I was able to find, it doesn’t mean that they are all here.
The names are the factory names, I don’t change anything.
Thanks to all.
substitutions:
  device_name: inv1
  friendly_name: "inv1"
  device_description: "Growatt SPF 5000 ES"
esphome:
  comment: '${device_description}'
esp8266:
  board: d1_mini
# Enable logging
logger:
  baud_rate: 0
  level: DEBUG
# Enable Home Assistant API
api:
  encryption:
    key: " your new api key " #     https://esphome.io/components/api.html
ota:
  safe_mode: true
  reboot_timeout: 10min
  num_attempts: 5
#web_server:
# port: 80
wifi:
  ssid: !secret wifi_ssid
  reboot_timeout: 2min
  # Optional manual IP
#  ap:
#    ssid: '${device_name}'
#    password: !secret wifi_password
captive_portal:
time:
  - platform: homeassistant
uart:
  tx_pin: 1
  rx_pin: 3
  baud_rate: 9600
  #baud_rate: 115200
  debug:
    direction: RX
    dummy_receiver: false
    after:
      delimiter: "\n"
    sequence:
      - lambda: UARTDebug::log_string(direction, bytes);
modbus:
  uart_id: mod_bus
#  flow_control_pin: GPIO4
modbus_controller:
  - id: growatt
    address: 0x1
    modbus_id: modbus1
    setup_priority: -10
#    update_interval: 30s
text_sensor:
    icon: mdi:eye
    entity_category: diagnostic
    lambda: |-
      if ((id(status).state) == 1) {
        return {"Normal"};
      } else if ((id(status).state) == 0)  {
        return {"Standby"};
      } else if ((id(status).state) == 2)  {
        return {"Discharge"};
      } else if ((id(status).state) == 3)  {
        return {"Fault"};
      } else if ((id(status).state) == 4)  {
        return {"Flash"};
      } else if ((id(status).state) == 5)  {
        return {"PV Charging"};
      } else if ((id(status).state) == 6)  {
        return {"AC Charging"};
      } else if ((id(status).state) == 7)  {
        return {"Combined Charging"};
      } else if ((id(status).state) == 8)  {
        return {"Combined Charging & Bypass"};
      } else if ((id(status).state) == 9)  {
        return {"PV Charging & Bypass"};
      } else if ((id(status).state) == 10)  {
        return {"AC Charging & Bypass"};
      } else if ((id(status).state) == 11)  {
        return {"Bypass"};
      } else if (id(status).state == 12)  {
        return {"PV Charge and Discharge"};
      } else {
        return {"Unknown"};
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 60s
  - platform: modbus_controller
    address: 0
    register_type: "read"
    internal: true
    accuracy_decimals: 0
#### temp ###
    name: "${friendly_name} Inverter Temperature"
    address: 25
    unit_of_measurement: °C
    device_class: temperature
    state_class: measurement
    icon: mdi:thermometer
    value_type: U_WORD
    accuracy_decimals: 1
    filters:
    - multiply: 0.1
    name: "${friendly_name} PV Temperature"
    address: 32
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "${friendly_name} DC‐DC Temperature "
    address: 26
    value_type: U_WORD
    filters:
    - multiply: 0.1
### ac input ###
    name: "${friendly_name} AC Input Hz"
    address: 21
    device_class: FREQUENCY
    unit_of_measurement: Hz
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.01
    name: "${friendly_name} AC Input Voltage"
    address: 20
    unit_of_measurement: V
    device_class: VOLTAGE
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "${friendly_name} AC Charge Current"
    address: 68
    unit_of_measurement: A
    device_class: CURRENT
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "${friendly_name} AC charge watt (low) "
    address: 14
    unit_of_measurement: W
    device_class: POWER
    icon: mdi:flash
    value_type: U_WORD
    accuracy_decimals: 2
    filters:
    - multiply: 0.1
    name: "${friendly_name} AC input watt (low) "
    address: 37
    device_class: POWER
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "${friendly_name} AC charge Energy today  "
    address: 57
    unit_of_measurement: KW
    device_class: POWER
    state_class: total_increasing
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.1
## ac output ##
    name: "${friendly_name} Output active power (low) "
    address: 10
    device_class: power
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "${friendly_name} AC output Volt"
    address: 22
    device_class: voltage
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "${friendly_name} Output Current "
    address: 34
    device_class: current
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "${friendly_name} AC discharge watt (low) "
    address: 70
    device_class: power
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.1
## solar ##
    name: "${friendly_name} PV1 charge power (high) "
    address: 3
    unit_of_measurement: Wh
    device_class: power
    icon: mdi:solar-power
    value_type: U_DWORD
    filters:
    - multiply: 0.1
    name: "${friendly_name} PV1 voltage "
    address: 1
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "${friendly_name} Buck1 current"
    address: 7
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.1
    name: "${friendly_name} Epv1_today H"
    address: 48
    device_class: energy
    value_type: U_DWORD
    filters:
    - multiply: 0.1
## bat ##
    name: "${friendly_name} Battery volt (M3)"
    address: 17
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.01
    name: "${friendly_name} Bus Voltage"
    address: 19
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 0.01
    name: "${friendly_name} fan speed"
    address: 82
    unit_of_measurement: "%"
    device_class: POWER_FACTOR
    icon: mdi:flash
    value_type: U_WORD
    filters:
    - multiply: 1
####  TTL RS485   ####
select:
    name: "${friendly_name} Charge Source"
    address: 01
    value_type: U_WORD
    optionsmap:
      "Pv Priority": 0
      "Pv&Uti": 1
      "Only Pv": 2
    name: "${friendly_name} Output Source"
    address: 02
    value_type: U_WORD
    optionsmap:
      "Bat Priority": 0
      "Pv Priority": 1
      "Uti Priority": 2
      "Pv&Uti Priority": 3
    name: "${friendly_name} Uti Output Start Time"
    address: 03
    value_type: U_WORD
    optionsmap:
      "0h": 0
      "1h": 1
      "2h": 2
      "3h": 3
      "4h": 4
      "5h": 5
      "6h": 6
      "7h": 7
      "8h": 8
      "9h": 9
      "10h": 10
      "11h": 11
      "12h": 12
      "13h": 13
      "14h": 14
      "15h": 15
      "16h": 16
      "17h": 17
      "18h": 18
      "19h": 19
      "20h": 20
      "21h": 21
      "22h": 22
      "23h": 23
    name: "${friendly_name} Uti Output End Time"
    address: 04
    value_type: U_WORD
    optionsmap:
      "0h": 0
      "1h": 1
      "2h": 2
      "3h": 3
      "4h": 4
      "5h": 5
      "6h": 6
      "7h": 7
      "8h": 8
      "9h": 9
      "10h": 10
      "11h": 11
      "12h": 12
      "13h": 13
      "14h": 14
      "15h": 15
      "16h": 16
      "17h": 17
      "18h": 18
      "19h": 19
      "20h": 20
      "21h": 21
      "22h": 22
      "23h": 23
    name: "${friendly_name} Uti Charge Start Time"
    address: 05
    value_type: U_WORD
    optionsmap:
      "0h": 0
      "1h": 1
      "2h": 2
      "3h": 3
      "4h": 4
      "5h": 5
      "6h": 6
      "7h": 7
      "8h": 8
      "9h": 9
      "10h": 10
      "11h": 11
      "12h": 12
      "13h": 13
      "14h": 14
      "15h": 15
      "16h": 16
      "17h": 17
      "18h": 18
      "19h": 19
      "20h": 20
      "21h": 21
      "22h": 22
      "23h": 23
    name: "${friendly_name} Uti Charge End Time"
    address: 06
    value_type: U_WORD
    optionsmap:
      "0h": 0
      "1h": 1
      "2h": 2
      "3h": 3
      "4h": 4
      "5h": 5
      "6h": 6
      "7h": 7
      "8h": 8
      "9h": 9
      "10h": 10
      "11h": 11
      "12h": 12
      "13h": 13
      "14h": 14
      "15h": 15
      "16h": 16
      "17h": 17
      "18h": 18
      "19h": 19
      "20h": 20
      "21h": 21
      "22h": 22
      "23h": 23
    name: "${friendly_name} PV Input Mode"
    address: 07
    value_type: U_WORD
    optionsmap:
      "Independent": 0
      "Parallel": 1
    name: "${friendly_name} AC Input Mode"
    address: 08
    value_type: U_WORD
    optionsmap:
      "APL,90‐280VAC": 0
      "UPS,170‐280VAC": 1
    name: "${friendly_name} Output Volt Type"
    address: 18
    value_type: U_WORD
    optionsmap:
      "208 VAC": 0
      "230 VAC": 1
      "240 VAC": 2
    name: "${friendly_name} Output Freq Type"
    address: 19
    value_type: U_WORD
    optionsmap:
      "50 Hz": 0
      "60 Hz": 1
    name: "${friendly_name} Over Load Restart"
    address: 20
    value_type: U_WORD
    optionsmap:
      "Yes": 0
      "No": 1
      "Swith to UTI": 2
    name: "${friendly_name} Over Temperature Restart"
    address: 21
    value_type: U_WORD
    optionsmap:
      "Yes": 0
      "No": 1
    name: "${friendly_name} Buzzer on/off enable"
    address: 22
    value_type: U_WORD
    optionsmap:
      "Enable": 0
      "Disable": 1
    name: "${friendly_name} Maximum Ac Charge Current"
    address: 38
    value_type: U_WORD
    optionsmap:  # 0 - 99
      "5": 5
      "10": 10
      "15": 15
      "20": 20
      "25": 25
      "30": 30
      "35": 35
      "40": 40
      "45": 45
      "50": 50
      "55": 55
      "60": 60
      "65": 65
      "70": 70
      "75": 75
      "80": 80
      "85": 85
      "90": 90
      "95": 95
    name: "${friendly_name} Bat Low Volt Switch To Uti"
    address: 37
    value_type: U_WORD
    optionsmap: # check manual 44 - ??
      "44,0": 440
      "44,2": 442
      "44,6": 446
      "44,8": 448
      "45,0": 450
      "45,2": 452
      "45,4": 454
      "45,6": 456
      "45,8": 458
      "46,0": 460
      "46,2": 462
    #   ...       ...    check the range in the manual
    name: "${friendly_name} Mains to battery operating point"
    address: 95
    value_type: U_WORD
    optionsmap:
      "48,0": 480
      "48,2": 482
      "48,4": 484
      "48,6": 486
      "49,0": 490
      "49,2": 492
      "49,4": 494
      "49,6": 496
      "49,8": 498
      "50,0": 500
      "51,0": 510
      "52,0": 520
So cool! Thanks for sharing.
I will give this a go. Is there no youtube tutorial about this? :slight_smile:
I don’t think so.
Screenshot of the parameters.
kBw3zL0
6X9zhDk
And thanks to you I now have immediate local control over the parameters on my SPH 10k-TL3 BH-UP I was most interested in:
select:
    name: "${devicename} AC Charging"
    icon: mdi:battery-charging-100
    address: 1092
    value_type: U_WORD
    optionsmap:
      "Disabled": 0
      "Enabled": 1
    name: "${devicename} Inverter Priority"
    icon: mdi:arrow-decision-outline
    address: 1044
    value_type: U_WORD
    optionsmap:
      "Load First": 0
      "Battery First": 1
      "Grid First": 2
Tested, works exactly as expected… this means I can finally build proper logic around low/high tariff use from grid (i.e. I can charge the battery at night using low tariff and then use it during high tariff period - that alone can save quite a few $ around here), be able to prepare for a planned outage and eventually when the market catches up and we can actually sell for spot prices, I can do that too…
Thanks!
This is really a game changer for the battery mangement. I’m going to do the same, using the production forecast I will charge or not the battery, and use the low tariff to charge wen need.
I’ve been waiting for such a solution for a long time, I’m testing it and it works fine.
Thanks !!
Hello Pavel,
do you have found a solution for this problem? Seems i have the same problem.
Greetings
Izi1
Thanks for info. I have ordered two types of converters, now waitng for them to arrive and test.
Until then i am stuck with standard integration with data update from server at 5min.
Hi goodmorning,
Thanks for sharing this.
I read the most of this thread and have ‘your’ version up and running now.
Original Shine WiFi-X stick and flashed with the yaml.
Got rid of the sensors I didn’t have and running in HA now.
Working with the MIC 3000 TL-X.
Thanks to Chris Huitema and Wilbert Verhoeff for helping me pointing in the right direction.
Pieter, what If you add external power to the stick?
5V ( USB Power ) soldered to the board?
Hi izi, no, I did not manage to get it working. Tried two different boards (esp8266 and esp32), two different RS485 converters, different pins (1-5, 4-5), different RS485 settings (VPP, unused) in all possible combinations, but nothing. There is no data coming on RX pin (LED does not blink). I will try the code from candidotsa but I am afraid it will not work. Probably the RS-485 connector is failed or the communication is somehow disabled.
Hi. Jumper You’re rs485 connection is RJ 45? Did you tried the pin 7&8? 7 for A and 8 for B.
Hi caro7372. The code is the same from the 5000es?
I used the next one as found above:
You can try to connect your converter and ESP32 to Easton SDM 630 smart meter if you have that installed and flash the ESP32 with Eastron SDM code. You will see some of the parameters provided by Growatt from there since the invertor is taking data form the smart meter. Here you can find info:
I did not try it myself, but i am planning to do it once i will receive the RS485 to TTL converter.
Hi guys, I also tried ShineBus software directly from Growatt (downloaded from here: Software - Growatt Italia), using the USB/RJ45 cable, but again no data read from the inverter. It is a mistery.
Hi. Did you tried the pin 7 and8?
I ordered the same setup - what hardware did you use to talk to the inverter? Esp32, TTL, type of cable? Would you mind sharing a picture? Got a bit confused looking at all the different varieties on this forum but i know for sure I want to be able to do what you do :grinning: - eg. Buy low sell high
The best way I would describe my setup is “always the first link on Aliexpress”…
Thanks, and the white cable is a standard CAT5/6 ethernet cable with an RJ45 directly into the inverter? Think I will manage thanks!:+1:
