I know that. I can alreay obtain the codes and trigger a binary sensor.
What I want to do is re-publish the code as an mqtt message
Using the latest Esphome-Dev add-on for Hassio, you can use this code,
remote_receiver:
pin: 4
dump: rc_switch
filter: 100us
tolerance: 50%
idle: 2ms
on_rc_switch:
- mqtt.publish:
topic: bridge/rf/result
payload: !lambda |-
char buff[21];
sprintf(buff, "%llu", x.code);
return buff;
I couldn’t figure out how to make use of on_raw
effectively - as the x
variable only contained the raw RF data - so you still needed to use the encode library from RC Switch to get it into a hex/binary string. And I don’t know enough about Esphome to figure out how to call methods from existing libraries.
See https://github.com/esphome/esphome/pull/983 for reference.
Thank you very much. I’d abandoned this as I never got a reply. What I wanted to do was get the bridge to pick up the rf signal from a sensor and publish it as an mqtt payload. That way you wouldn’t have to list every sensor in the esphome yaml.
So in theory your suggested code should accomplish this?
Yeah, I was trying to achieve the same thing, saw your post - and thought I’d add a reply when I found something (so someone didn’t end up like you and I).
My original goal was to have multiple RF Sonoff Bridges that ingested the RF data and sent it as a MQTT payload - so that I could have a single sensor fed by multiple RF sources (for reliability/coverage). I didn’t want to define the sensor on the bridge - but on Hassio itself.
But if you are defining the sensor on the Sonoff Bridge itself - you can actually just define the MQTT broker details and the MQTT sensor is automatically created and detected by Hassio.
Eg. Just put this
mqtt:
broker: 10.0.0.2
username: livingroom
password: MyMQTTPassword
So I guess my question is, do you have multiple bridges, where you want to define one sensor centrally - or just a single bridge?
Thank you very much again.
I define the sensors in HA and use this
Which allows me to use as many rfbridges as i want.
Ah, so I guess here’s how you can do it then
mqtt:
broker: 10.0.0.2
remote_receiver:
pin: 4
filter: 100us
tolerance: 50%
idle: 2ms
on_rc_switch:
- lambda: !lambda |-
char buff[21];
sprintf(buff, "rf/bridge/%llu", x.code);
id(mqtt_client).publish(buff, "ON");
thank you very much.
so no need to add the topic after on_rc_switch? it 's in the lambda function i see.
also noted you removed the “dump: rc_switch” parameter.
It just depends on what you are trying to achieve. If you are using sensors that only have a single state (eg. PIR) then the above code gives you a way of sending the MQTT payloads to individual topics.
Eg.
- platform: mqtt
name: 'Hallway PIR 1'
state_topic: 'rf/bridge/101112'
<<: &common_pir
off_delay: 5
device_class: motion
- platform: mqtt
name: "Hallway PIR 2"
state_topic: 'rf/bridge/456789'
<<: *common_pir
- platform: mqtt
name: "Landing PIR 1"
state_topic: 'rf/bridge/123456'
<<: *common_pir
The dump: rc_switch
line is merely for debugging to see the RF code in the Esphome log console. I turn it on when I need to sniff for a new 433Mhz device to see what the code is, then turn it off to avoid the device needlessly logging.
I took a slightly different approach though as I needed to support multi-state devices (eg. doors) and I didn’t want to have to reload Hassio every time I added a sensor to configuration.yaml
So instead, I used MQTT discovery with NodeRed and a number of modified Sonoff T2 light switches acting as 433MHz bridges.
Node Red Flow
This only needs to be updated and run when you add a new sensor.
[{"id":"9993cb8d.82e7c8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"f3b79420.a8ffe8","type":"mqtt out","z":"9993cb8d.82e7c8","name":"","topic":"","qos":"","retain":"","broker":"2ec7481f.cfe868","x":1070,"y":300,"wires":[]},{"id":"39715738.293628","type":"function","z":"9993cb8d.82e7c8","name":"","func":"function hexa(num) { return parseInt(num, 2).toString(10) }\nfunction nameToId(name) { return name.replace(/ /g,\"_\").toLowerCase(); }\n \nfunction templateDevice(device) {\n obj = {};\n \n id = nameToId(device.name);\n obj.payload = {\n name: device.name,\n state_topic: 'rf/bridge/all',\n };\n obj.topic = 'homeassistant/binary_sensor/' + id + '/config';\n \n switch (device.type) {\n case 'pir':\n case 'vibration':\n obj.payload.off_delay = 5;\n obj.payload.device_class = 'motion';\n obj.payload.payload_on = hexa(device.on); \n break;\n case 'door':\n case 'opening':\n obj.payload.payload_on = hexa(device.open);\n obj.payload.payload_off = hexa(device.close);\n obj.payload.device_class = 'door';\n break;\n default:\n obj = false;\n }\n \n return obj;\n}\n\n// Process entities\nfor (index = msg.payload.length - 1; index >= 0; --index) {\n msg.payload[index] = templateDevice(msg.payload[index]);\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":300,"wires":[["9f0dc2fb.11f02"]]},{"id":"db249a23.e95418","type":"inject","z":"9993cb8d.82e7c8","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":240,"y":300,"wires":[["16dced2d.c73ef3"]]},{"id":"9f0dc2fb.11f02","type":"split","z":"9993cb8d.82e7c8","name":"","splt":"\\n","spltType":"str","arraySplt":"1","arraySpltType":"len","stream":false,"addname":"","x":750,"y":300,"wires":[["a4d3a9d.be33a58"]]},{"id":"a4d3a9d.be33a58","type":"function","z":"9993cb8d.82e7c8","name":"","func":"return msg.payload;","outputs":1,"noerr":0,"x":910,"y":300,"wires":[["f3b79420.a8ffe8"]]},{"id":"8afe9a3f.f15358","type":"comment","z":"9993cb8d.82e7c8","name":"RF MQTT","info":"","x":240,"y":260,"wires":[]},{"id":"16dced2d.c73ef3","type":"template","z":"9993cb8d.82e7c8","name":"Sensors","field":"payload","fieldType":"msg","format":"json","syntax":"plain","template":"[\n {\n \"on\": \"0000000111110100\",\n \"name\": \"Hallway PIR 1\",\n \"type\": \"pir\"\n },\n {\n \"open\": \"0000000111110101\",\n \"close\": \"0000000111110111\",\n \"name\": \"Boiler Room Door\",\n \"type\": \"door\"\n } \n]","output":"json","x":420,"y":300,"wires":[["39715738.293628"]]},{"id":"2ec7481f.cfe868","type":"mqtt-broker","z":"","name":"MQTT-Server","broker":"192.168.1.1","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Esphome
mqtt:
broker: 10.0.0.2
username: myuser
password: mypassword
discovery: false
remote_receiver:
pin: 4
# dump: rc_switch
filter: 100us
tolerance: 50%
idle: 2ms
on_rc_switch:
char code[21];
sprintf(code, "%llu", x.code);
id(mqtt_client).publish("rf/bridge/all", code);
With this, it only needs NodeRed to create the sensor, Hassio does the rest after that.
This is very good. I did read in another post someone modifying T2 switches, which is the perfect bridge solution as most likely they’re spread all over the house.
In my case i have replaced all my switches with T2s and this would work great.
I have been using the sonoff rfbridge with tasmota for rf senssors for about 2 years now and what i found was that for PIRs it works very well. However for door/contact sensors it was not reliable unless the sensor was relatively close to the bridge. So i gave up on the contact sensors and switched to zigbee (zigbee2tasmota) for those, whilst retaining rf for pirs.
The zigbee contact sensors are very reliable, I use a cc2530+2591 flashed with zigbee2tasmotta connected to wifi via a sonoff basic and it covers the required area (3000sqf) well plus i dont need to plug it to my server. It’s remote.
Nevertheless, had i been able to get the rf contact sensors to work reliable, i probably wouldnt have switched.
For your modified T2s, did you modify the board to use its rf chip as i saw in the other post? or you just added a receiver or similar.
Thank you for sharing all this information/experience.
Its probably this post - Converting a Sonoff TX/T1/T2/T3 into a Sonoff Bridge
Just a single resistor was required - and its very similar to the RFR3/Bridge hack to make use of the onboard RF receiver (pin 10 on the RF chip to GPIO 3 with a 220ohm resistor). But you can just use a regular piece of wire.
There’s enough room on the board for the wire/resistor to fit without it affecting the cover/screws, you just route it around the buttons.
So there’s a few dozen T2’s in my house, all acting as 433MHz receivers. It has rendered the Sonoff Bridges that I bought as fairly useless now, but I’ll keep them for 433MHz transmit for the future.
Yes exactly that post. should have guessed it was yours
once again thank you for sharing this information.
indeed this mod does away with the need for rfbridges completely.
did you try the mod using tasmotta? I presume you’d also get a “code” via the tasmota console.
reason i ask is because my switches are tasmotized
I’ve never used Tasmota I’m afraid. I found Esphome so easy to flash via the web interface in Hassio that I just stuck with it.
thank you. I’ll give it a try with tasmota and see what i get.
just in case would you mind sharing one of your esphome switch.yaml
So there’s no configuration at all in Hassio - and the only other configuration for Esphome is what I posted above.
thank you for all your help
Good afternoon @blessani I saw that you understood a lot about Esphome and I need your help if possible? I am trying to transmit through Sonoff Bridge and without success I am using EspHome (dev) I know it has a bug but I do not know how to change and recompile it because when I change and I will recompile it changes everything I did and compiles in a buggy way, you are a enthusiastic like me for EspHome so I’m asking you for help because this is the last piece with tasmota because the rest is all with EspHome.
Make a new topic, include your config - then DM me and I’ll have a look. I haven’t done any transmit with my bridge, so I’m not super familiar with it. But I can have a play.
Tried to use the information in this thread, to publish rf codes to mqtt.
But i can’t get it to work.
It compiles without errors.
I used nodered, i receive the reboot message. But when pushing an RF433 device, nothing is send to mqtt. The devices works with rc_switch. I made an other .yaml file and i see in the log the code of the RF device.
What would i like to receive?:
If i push a RF device. That the raw rf_switch code is send to mqtt
For the future i would like more to get working. Would like to have it as a IR and RF gateway. Which sends all received raw IR/RF data and when receiving mqtt_on_message that it send the RAW data. But have to start somewhere, that was to receive RF signal and send to mqtt.
Does somebody know what is wrong?
esphome:
platform: ESP8266
board: d1_mini
# Enable logging
logger:
ota:
password: "!secret"
wifi:
networks:
- ssid: "!secret"
password: "!secret"
captive_portal:
#build webserver
web_server:
port: 80
mqtt:
broker: XXX.XXX.XXX.XXX
#Enable remote receiver
remote_receiver:
pin: GPIO4
dump: rc_switch
tolerance: 60%
filter: 4us
idle: 4ms
on_rc_switch:
char code[24];
id(mqtt_esphome).publish("rf/bridge/all", code);
Why is this automatically working?
remote_receiver:
pin:
number: GPIO4
inverted: True
mode: INPUT_PULLUP
dump: raw
tolerance: 60%
filter: 4us
idle: 4ms
and this not?
remote_receiver:
pin:
number: GPIO4
inverted: True
mode: INPUT_PULLUP
dump: rc_switch
tolerance: 60%
filter: 4us
idle: 4ms
The dump: raw also dumps it to mqtt. But then setting it to a specific protocol, than it stops sending to mqtt.
Are there tips where to find information how to make the yaml when wanting to make something that is not default in esphome?
I have searched and found some threads. A lot of them are saying, it is on the esphome pages defined. But i think i am not looking a the right place. Because i can find nothing that says something about this way of making the yaml, to retreive the raw data of protocols
