When you say that compiles means that work with the latest (later) versions?
If is not asking too much and since you have the same hardware can you try this code which is very similar to mine?
That’s the same reason why I add the domain key but only for the internal domain.
BTW, i use the same board, no issues with it (just tried with latest release):
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.103.18 using esphome API
INFO Successfully connected to doorbell @ 192.168.103.18 in 35.937s
INFO Successful handshake with doorbell @ 192.168.103.18 in 2.932s
[21:06:40][I][app:102]: ESPHome version 2024.2.2 compiled on Mar 6 2024, 21:04:13
[21:06:40][C][wifi:577]: WiFi:
[21:06:40][C][wifi:409]: Local MAC: 98:2D:AC:F2:9C:ED
[21:06:40][C][wifi:414]: SSID: [redacted]
[21:06:40][C][wifi:415]: IP Address: 192.168.103.18
My base yaml:
substitutions:
node_name: doorbell
node_id: doorbell
friendly_node_name: "DoorBell"
esphome:
comment: ${friendly_node_name}
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_iotpw
domain: .domain.mine
power_save_mode: none
ap:
ssid: ${node_name} FB
password: "fallback"
captive_portal:
# Enable Home Assistant API
api:
encryption:
key: !secret api_encryption
# Enable Over The Air updates
ota:
# Disable logging
logger:
baud_rate: 0
logs:
sensor: ERROR
duty_cycle: ERROR
binary_sensor: ERROR
light: ERROR
# Enable Web server.
web_server:
port: 80
# Sync time with Home Assistant.
time:
- platform: homeassistant
plus a couple of (binary_ / text_ )sensors, switch (relay GPIO0, the normal stuff
Basically it is the same as Frenck’s doorbell with some mods
