EspHome & TTGO T-Display: no screen refresh
In home assistant add to sensors:
  sensors:
    current_temp:
       value_template: "{{ state_attr('weather.home','temperature') | round(0) }}"
       friendly_name: "current temperature"
    current_weather:
      value_template: "{{ states('weather.home') | default('Unknown') }}"
      friendly_name: "current weather"
Esphome config:
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO19
# Fonts (can be dowloaded)
font:
  - file: 'slkscr.ttf'
  - file: 'BebasNeue-Regular.ttf'
  - file: 'Arial-Black.ttf'
#Icons 128x128 (put in the folder 'images')
image:
  - file: "images/0-default.png"
    type: RGB565
  - file: "images/1-clear-night.png"
    type: RGB565
  - file: "images/2-cloudy.png"
    type: RGB565
  - file: "images/3-fog.png"
    type: RGB565
  - file: "images/4-hail.png"
    type: RGB565
  - file: "images/5-lightning.png"
    type: RGB565
  - file: "images/6-lightning-rainy.png"
    type: RGB565
  - file: "images/7-partlycloudy.png"
    type: RGB565
  - file: "images/8-pouring.png"
    type: RGB565
  - file: "images/9-rainy.png"
    type: RGB565
  - file: "images/10-snowy.png"
    type: RGB565
  - file: "images/11-snowy-rainy.png"
    type: RGB565
  - file: "images/12-sunny.png"
    type: RGB565
  - file: "images/13-windy.png"
    type: RGB565
  - file: "images/14-windy-variant.png"
    type: RGB565
  - file: "images/15-exceptional.png"
    type: RGB565
display:
  - platform: st7789v
    reset_pin: GPIO23
    dc_pin: GPIO16
    cs_pin: GPIO5
    bl_pin: GPIO4
    brightness: 100%
    update_interval: 1s
    lambda: |-
      it.set_rotation(DISPLAY_ROTATION_0_DEGREES);
      //Icon
      if (id(current_weather).state == "clear-night")
         it.image(5, 5, id(wpng_1));
      else if (id(current_weather).state == "cloudy")
         it.image(5, 5, id(wpng_2));
      else if (id(current_weather).state == "fog")
         it.image(5, 5, id(wpng_3));
      else if (id(current_weather).state == "hail")
         it.image(5, 5, id(wpng_4));
      else if (id(current_weather).state == "lightning")
         it.image(5, 5, id(wpng_5));
      else if (id(current_weather).state == "lightning-rainy")
         it.image(5, 5, id(wpng_6));
      else if (id(current_weather).state == "partlycloudy")
         it.image(5, 5, id(wpng_7));
      else if (id(current_weather).state == "pouring")
         it.image(5, 5, id(wpng_8));
      else if (id(current_weather).state == "rainy")
         it.image(5, 5, id(wpng_9));
      else if (id(current_weather).state == "snowy")
         it.image(5, 5, id(wpng_10));
      else if (id(current_weather).state == "snowy-rainy'")
         it.image(5, 5, id(wpng_11));
      else if (id(current_weather).state == "sunny")
         it.image(5, 5, id(wpng_12));
      else if (id(current_weather).state == "windy")
         it.image(5, 5, id(wpng_13));
      else if (id(current_weather).state == "windy-variant")
         it.image(5, 5, id(wpng_14));
      else if (id(current_weather).state == "exceptional")
         it.image(5, 5, id(wpng_15));
      else
         it.image(5, 5, id(wpng_0));
      //Temperature
      if (id(current_temp).has_state())
        it.printf(95, 200, id(font2),  0xFFFF, TextAlign::BASELINE_RIGHT, "%.0f", id(current_temp).state);
        it.printf(100, 120, id(font3),  0xFFFF, "o");
        it.printf(105, 170, id(font4),  0xFFFF, "F");
      //Time
        it.strftime(67, 235, id(font1), 0x767E, TextAlign::BASELINE_CENTER, "%H:%M:%S", id(esptime).now());
      //Battery voltage
      if (id(vcc).has_state()) {
         it.printf(4, 4, id(font1), 0x767E, "%.2f V", id(vcc).state);
# Temperature from home assistant
  - platform: homeassistant
    entity_id: sensor.current_temp
#Battery voltage
  - platform: adc
    pin: 34
    attenuation: 11db
    update_interval: 30s
#Weather state for icons
text_sensor:
    entity_id: sensor.current_weather
#Left button
binary_sensor:
  - platform: gpio
    pin:
      number: 0
      inverted: True
      mode: INPUT_PULLUP
#Right button
  - platform: gpio
    pin:
      number: 35
      inverted: True
      mode: INPUT_PULLUP
time:
Hi Everyone,
I must be missing some part of the setup because validation reports the following:
Platform not found: ‘display.st7789v,’
But the source files are all present and correct as far as I can tell.
Running latest esphome-dev
Anything I should be doing or looking for?
You have to use custom component:
https://github.com/musk95/esphome
Thanks for your answer. I tried that before changing over to -dev with same result.
Am I correct that the path should be something like the following?:
4ee:/config/esphome/t_display1/src/esphome/components/[display|image|st7789v]/
I have added the three folders but I still get the same error when validating.
Are there some more steps in the process that I am not aware of?
Check my full project on GitHub
Got it working at last! Thanks, Anton! It took me a while to cotton on that one has to create the custom_components directory, in the same directory as the device directories and .yaml files, and of course then populate it with the directories and files of your project.
Im getting the same problem and cannot seam to fix it.
here is my .yaml
#____TEMP Sensors______________
i2c:
  sda: 21
  scl: 22
  scan: True
  - platform: bmp280
    address: 0x76
    temperature:
      oversampling: 8x
    pressure:
#______DISPLAY____________
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO19
font:
   - file: 'arial-black.ttf'
display:
  - platform: st7789v
    reset_pin: GPIO23
    dc_pin: GPIO16
    cs_pin: GPIO5
    bl_pin: GPIO4
    update_interval: 1s
    pages:
      - id: page1
        lambda: |-
          it.set_rotation(DISPLAY_ROTATION_270_DEGREES);
          it.strftime(4, 55, id(font1), 0x767E, TextAlign::BASELINE_LEFT, "%H:%M:%S", id(esptime).now());
          it.printf(4, 70, id(font1), 0x767E, "%.1f°C", id(Temperature).state);
time:
@leonb, Do you have the display related directories and source files in the custom_components directory? What error message do you get when you compile?
Here is the display related section of my .yaml:
All it currently does is to display the date and time it obtains from my network ntp server.
Example minimal configuration entry
spi:
clk_pin: GPIO18
mosi_pin: GPIO19
(Fonts - folder ‘images’)
font:
  • file: ‘fonts/slkscr.ttf’
  • file: ‘fonts/BebasNeue-Regular.ttf’
  • file: ‘fonts/Arial-Black.ttf’
display:
  • platform: st7789v
    bl_pin: GPIO4
    cs_pin: GPIO5
    dc_pin: GPIO16
    reset_pin: GPIO23
    brightness: 20%
    update_interval: 1s
    lambda: |-
    it.set_rotation(DISPLAY_ROTATION_90_DEGREES);
    it.strftime(120, 40, id(font3), 0xFFE0, TextAlign::BASELINE_CENTER, “%H:%M:%S”, id(esptime).now());
    it.strftime(120, 80, id(font5), 0x07E0, TextAlign::BASELINE_CENTER, “%A”, id(esptime).now());
    it.strftime(120, 120, id(font6), 0x07FF, TextAlign::BASELINE_CENTER, “%d %b %Y”, id(esptime).now());
time:
  • platform: sntp
    servers: 192.168.1.1
@phaedrus42 thanks for the reply
let me clarify (i’m new to home assistant and ESPHome)
I can get the screen to work no problem and get no errors while compiling.
My issue is like the original issue and the characters overwrite themselves. and just turn into a single block of white pixels.
I downloaded the files from musk95 about a week ago.
Thanks for the help
The files from musk95’s repository have the issue.
semenyak’s GitHub linked above has the fix.
Or a little further up in the 5th post, the issue and fix is listed. It’s in the st7789v.cpp file, which you can edit in notepad or any text editor… or just swap that file from semenyak’s repository.
Thank-you that has fixed it
I did look at the two st7789v.cpp files and did no see a deference (must have missed something) and just assumed that the musk95 files were updated (silly me for assuming).
I copied from semenyak’s and its all working
Thank-you again for your support
Hi, I’ve this error!! Can you help me ?
src\main.cpp: In lambda function:
src\main.cpp:780:23: error: ‘class esphome::st7789v::ST7789V’ has no member named ‘backlight’
st7789vdisplay->backlight (false);
src\main.cpp:783:23: error: ‘class esphome::st7789v::ST7789V’ has no member named ‘backlight’
st7789vdisplay->backlight (true);
src\main.cpp:787:27: error: ‘class esphome::st7789v::ST7789V’ has no member named ‘get_backlight’
if (st7789vdisplay->get_backlight()) {
src\main.cpp:796:23: error: ‘class esphome::st7789v::ST7789V’ has no member named ‘backlight’
src\main.cpp:807:23: error: ‘class esphome::st7789v::ST7789V’ has no member named ‘backlight’
Could you pls post the “display” section of your code?
display:
  • platform: st7789v
    reset_pin: GPIO23
    dc_pin: GPIO16
    cs_pin: GPIO5
    backlight_pin: GPIO4
    brightness: 25%
    update_interval: 5s
    lambda: |-
    //Icon
    if (id(curent_weather).state == “clear-night”)
    else if (id(curent_weather).state == “cloudy”)
    else if (id(curent_weather).state == “fog”)
    else if (id(curent_weather).state == “hail”)
    else if (id(curent_weather).state == “lightning”)
    else if (id(curent_weather).state == “lightning-rainy”)
    else if (id(curent_weather).state == “partlycloudy”)
    else if (id(curent_weather).state == “pouring”)
    else if (id(curent_weather).state == “rainy”)
    else if (id(curent_weather).state == “snowy”)
    else if (id(curent_weather).state == “snowy-rainy’”)
    else if (id(curent_weather).state == “sunny”)
    else if (id(curent_weather).state == “windy”)
    else if (id(curent_weather).state == “windy-variant”)
    else if (id(curent_weather).state == “exceptional”)
    else
    //Temperature
    if (id(curent_temp).has_state())
    it.printf(95, 204, id(font2),  0xFFFF, TextAlign::BASELINE_RIGHT, "%.0f", id(curent_temp).state);
    it.printf(100, 124, id(font3),  0xFFFF, "o");
    it.printf(105, 174, id(font4),  0xFFFF, "F");
    // it.printf(105, 174, id(font4), 0xFFFF, “C”);
    //Time
    it.strftime(67, 235, id(font1), 0x767E, TextAlign::BASELINE_CENTER, "%H:%M", id(esptime).now());
This seems to be at the heart of the matter.
Have you done Clean Build Files?
Yes, but nothing !!
I try to compile this project : https://github.com/anton-semeniak/Esphome-TTGO-T-Display-Weather
The first error is in custom_components renamed to components
The second is Unknown value ‘RGB565’, valid options are ‘BINARY’, ‘GRAYSCALE’, ‘RGB24’: renamed to RGB24
the third is in the bl_pin: renamed to bachlight_pin
Do you have the custom components directory?
Cattura
if I rename it to “components” it goes on
Cattura
This is the directory
