I JUST GOT IT WORKING!!
I bought a set of 5 of these INMP441 microphones. I just built up another (by soldering the pins on it) and swapped it out with the one I had been using for testing and VOILA:
- I was able to speak to it
- It sent the recording to HA’s voice assistant
- The voice assistant decoded it and performed the operation!
Here’s the ESPHome USB-to-serial debug log data:
[17:55:27][D][binary_sensor:036]: 'Boot Switch': Sending state ON
[17:55:27][D][voice_assistant:132]: Requesting start...
[17:55:27][D][light:036]: 'Response Light' Setting:
[17:55:27][D][light:047]: State: ON
[17:55:27][D][voice_assistant:111]: Starting...
[17:55:27][D][voice_assistant:154]: Assist Pipeline running
[17:55:28][D][sensor:094]: 'Testing Uptime Raw': Sending state 2099.45703 s with 0 decimals of accuracy
[17:55:29][D][binary_sensor:036]: 'Boot Switch': Sending state OFF
[17:55:29][D][voice_assistant:144]: Signaling stop...
[17:55:29][D][light:036]: 'Response Light' Setting:
[17:55:29][D][light:047]: State: OFF
[17:55:30][D][voice_assistant:168]: Speech recognised as: " Turn on the office light."
[17:55:30][D][voice_assistant:144]: Signaling stop...
[17:55:30][D][voice_assistant:192]: Response: "Turned on light"
[17:55:30][D][voice_assistant:207]: Response URL: "http://[REDACTED]:8123/api/tts_proxy/c9423eae01959b2af87c0b8d21f861b36e9b0fec_en-us_8f9b84fea8_tts.piper.raw"
[17:55:30][D][voice_assistant:218]: Assist Pipeline ended
Success! I actually found out that you can add something like this to your configuration.yaml file to capture the WAV files from your ESPHome microphone:
assist_pipeline:
debug_recording_dir: /share/assist_pipeline
That worked as well. I now have a recording of me saying “Turn off the office light”. It sounds pretty bad so I need to figure out how to clean it up but at least it was clear enough that HA understood what I wanted!
