ESPHome Voice Assistant
I also get no response from my esp32 dev board with INMP441. I tried various settings. My M5stack echo though is working perfectly now after todays Esphome update, and was working before the update with the no response issue a lot had.
@Arh Curious isn’t it? As I said it appears as though both my microphone and speaker work, but voice assistant doesn’t like them. I wonder if it’s the ESP32 Dev board??? I don’t have a spare board of any type at the moment to test with unfortunately. Been holding off getting whilst I make my mind what to go for… But that’s for another post!
I know I said “for another post”, BUT what boards are people using in their Voice Assistant builds? That are working!
On my board there’s a ESP32-WROOM32 module and I’m using
  i2s_lrclock: GPIO25
  i2s_bclock: GPIO33
  i2s_din: GPIO32
  i2s_dout: GPIO14
  onboard_led: GPIO02
  onboard_button: GPIO00
  rgb_led: GPIO13
  push_to_talk: GPIO23
Finally got it working, well mostly! The issue with the board I have is that the i2s clock NEEDS to be on certain pins, when I used one of these pins, I have voice! In my case I used GPIO3, all other pins were unchanged.
Not yet perfect, but it works!
Documentation:
https://www.espressif.com/sites/default/files/documentation/esp32-wroom-32_datasheet_en.pdf
https://www.espressif.com/sites/default/files/documentation/esp32_datasheet_en.pdf
Using the following from @SpikeyGG I’m able to hear what was sent from STT
assist_pipeline:
  debug_recording_dir: /share/assist_pipeline
Do you mean the L-R switch GPIO should be connected to the L/R of the microphone so as to allow switching left or right?
That’s what I did, simply for debug.
Where did you get the updated version from? I saw the bugfix on github, but is this now available via the webinstaller, or do I have to have a local beta version of esphome installed for the compiling/flashing? Thanks in advance :slight_smile:
I have tried 4 different INMP441’s on a nodemcu-32, doiT ESP32 DEVKIT V1 and S2 mini. All work with custom Arduino code but just can’t get any combination to work with voice_assistant :confused:
I messed with this today and couldn’t get it to work with the button push. I did however copy over the code for wake word from the atom device and got the wake word working. No idea what the button push problem was.
esphome:
  friendly_name: microphone input
  min_version: 2023.10.0
  on_boot:
    - priority: -100
      then:
        - wait_until: api.connected
        - delay: 1s
        - if:
            condition:
              switch.is_on: use_wake_word
            then:
              - voice_assistant.start_continuous:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "..."
ota:
  password: "..."
wifi:
  ssid: !secret wifi_ssid
i2s_audio:
  i2s_lrclk_pin: GPIO33  # LRCLK, WS, FS
  i2s_bclk_pin: GPIO19  # BLCK, SCK
microphone:
  - platform: i2s_audio
    i2s_din_pin: GPIO23  # DIN, SDIN, SD, SDATA, ADCDATA
    adc_type: external
    pdm: false
    bits_per_sample: 32bit
voice_assistant:
  microphone: echo_microphone
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  use_wake_word: True
  on_listening:
    - light.turn_on: response_light
  on_end:
    - light.turn_off: response_light
output:
  - platform: gpio
    pin: GPIO2  #onboard led
light:
  - platform: binary
    output: light_output
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - voice_assistant.stop
      - lambda: id(va).set_use_wake_word(false);
I mostly just copied and pasted code until it worked. No idea what I’m doing. This is with a normal esp32 dev board.
I have this code with ESP32 dev board and microphone and it works all well with wake work for sometime.
esphome:
  friendly_name: Microphone
  on_boot:
    then:
      - switch.turn_off: use_wake_word
      - delay: 30sec
      - switch.turn_on: use_wake_word
esp32:
  board: esp32dev
  framework:
    type: arduino
web_server:
  port: 80
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO26 #WS
    i2s_bclk_pin: GPIO25 #SCK
microphone:
    adc_type: external
    pdm: false
    channel: right
    i2s_audio_id: i2s_in
    i2s_din_pin: GPIO33 #SD
voice_assistant:
  microphone: mic_i2s
  auto_gain: 31dBFS
  volume_multiplier: 4.0
  on_wake_word_detected:
    - light.turn_on:
  on_listening:
    - light.turn_on:
        effect: "Scan Effect With Custom Values"
        red: 63%
        green: 13%
        blue: 93%
  on_error:
    - light.turn_on:
        effect: "flicker"
    - delay: 1sec
  on_end:
    - light.turn_off:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_OFF
    on_turn_on:
      - if:
          condition:
            not:
          then:
    on_turn_off:
light:
  - platform: neopixelbus
    type: grb
    pin: 32
    num_leds: 10
    variant: ws2812x
    default_transition_length: 0.5s
    effects:
      - addressable_flicker:
      - addressable_scan:
          name: Scan Effect With Custom Values
          move_interval: 50ms
          scan_width: 3
But after sometime, I guess it looks like the connection with HA drops and then it shows this log output in the esphome logs.
[22:52:13][D][voice_assistant:468]: Event Type: 0
[22:52:13][D][voice_assistant:468]: Event Type: 2
[22:52:13][D][voice_assistant:550]: Assist Pipeline ended
[22:52:13][D][voice_assistant:366]: State changed from STREAMING_MICROPHONE to IDLE
[22:52:13][D][voice_assistant:372]: Desired state set to IDLE
WARNING 192.168.0.37: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for 192.168.0.37
WARNING Disconnected from API
INFO Successfully connected to 192.168.0.37
[22:57:14][I][ota:117]: Boot seems successful, resetting boot loop counter.
[22:57:14][D][esp32.preferences:114]: Saving 1 preferences to flash...
[22:57:14][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
It gets stuck here and these are the last log lines and the wake word does not work any more.
I have to then switch off the “use wake word” button and switch it on again to make it work.
I will try now and replace
esphome:
  on_boot:
    then:
      - delay: 30sec
with
  on_boot:
    - priority: -100
      then:
        - delay: 1s
        - if:
            condition:
            then:
But finally what could be the issue?
Finally got this working, seems like my INMP441’s are wired incorrectly and run on the right channel when connected to GND.
There is however a lot of noise when sample rate is at the default 16000 set in ESPHome.
When testing with custom Arduino code, a sample rate of 8000 gives me clear audio with no noise.
Hi, just came across this as I might be having a similar issue.
I’m using an ESP32 with a INMP441 mic, and it works for a few hours at a time, then randomly I receive the following log error in Home Assistant Core.
Logger: homeassistant.components.assist_pipeline.pipeline
Source: components/assist_pipeline/pipeline.py:653
Integration: Assist pipeline (documentation, issues)
First occurred: 14:38:47 (19 occurrences)
Last logged: 19:00:08
Unexpected error during wake-word-detection
  File "/usr/src/homeassistant/homeassistant/components/assist_pipeline/pipeline.py", line 653, in wake_word_detection
    result = await self.wake_word_entity.async_process_audio_stream(
  File "/usr/src/homeassistant/homeassistant/components/wake_word/__init__.py", line 112, in async_process_audio_stream
    result = await self._async_process_audio_stream(stream, wake_word_id)
  File "/usr/src/homeassistant/homeassistant/components/wyoming/wake_word.py", line 152, in _async_process_audio_stream
    chunk_info = audio_task.result()
  File "/usr/src/homeassistant/homeassistant/components/wyoming/wake_word.py", line 82, in next_chunk
    async for chunk_bytes in stream:
  File "/usr/src/homeassistant/homeassistant/components/assist_pipeline/pipeline.py", line 736, in _wake_word_audio_stream
    async for chunk in audio_stream:
  File "/usr/src/homeassistant/homeassistant/components/assist_pipeline/pipeline.py", line 1147, in process_enhance_audio
    async for dirty_samples in audio_stream:
  File "/usr/src/homeassistant/homeassistant/components/esphome/voice_assistant.py", line 155, in _iterate_packets
    raise RuntimeError("Not running")
RuntimeError: Not running
My ESP32 also has a presence sensor and an LED attached to it. Both of those continue working no problem, it’s just the mic that stops. If I restart the ESP (I have programmed a restart toggle for it), then it works again no problem for a few hours.
You mentioned something about the wiring being wrong on the mic. Could you explain a bit more? Got any pictures of how you’ve wired it up? I’ve wired mine as per this guide (see at bottom).
Since I’m really underwhelmed with the performance of the voice assistant I wanted to listen to the recording of the microphone. I added the following lines to the configuration.yaml but no files are generated in the folder I created.
assist_pipeline:
  debug_recording_dir: /share/assist_pipeline/
I’m running Home Assistant Container version and Whisper also running in a container. Here’s the corresponding part of my compose:
  whisper:
    container_name: whisper
    image: rhasspy/wyoming-whisper
    restart: unless-stopped
    command: --model small --language de
    volumes:
      - /lightning/lightning/apps/portainer/data/whisper:/data
    environment:
      - TZ=Europe/Berlin
    ports:
      - 10300:10300
    networks:
      - default
Any clues why no files are generated?
Edit:
Okay got it myself.
I was expecting the /share folder to be inside of the /config folder just like media for example. Instead it is generated at the same level as the config folder. And since I’m not able to use addons I did not see it until I crawled through the console of my HA docker instance.
So if anyone is running Home Assistant and all the other voice components in Docker containers, you now know where to look for those recordings.
D1 mini is just a board style and esp32 comes in a d1 mini form. Using an external DAC isnt exactly a big deal and it doesnt get much simpler.
just trollin’, eh? good work, son!
No girl, im not trolling. Im correcting wrong information. Pay attention and you might learn something, kid.
I’m running an ESP32S, MAX98357A Amplifier for audio output, and INMP441 for Mic. I’ve got it working with OpenWakeWord, and I am getting output from the speaker. The problem I’m now facing is:
  1. The output to the speaker is choppy and within the log it appears that the audio buffer on the ESP32s is full.
  2. When changing the audio output over from the “speaker” component to “media_player”, so as to have a volume control slider within HA, the choppiness of the outputted audio is even more pronounced. (Sounds kinda like it’s speaking through a fan).
Hi Chris
Also struggling to get an Esp Wroom32 working. Which pins are you using? I see your prior post listing pins - we’re those the successful ones for you?
Tia
Andrew
@philimon121 Here are the pins I used, I’ve put the project on hold for the moment, looking for a suitable “housing”.
After reading the articles I referenced, I moved i2s_bclock onto the RX0 pin.
I’ve been spending quite some time on tinkering and figuring out the pins myself. Therefore, in case someone has the same combo as I am using, here is what works:
Microphone: M5Stack UO89 SPM1423
ESP device: NodeMCU-32S ESP32
ESPHome config and pin mapping:
i2s_audio:
  i2s_lrclk_pin: GPIO15
microphone:
    adc_type: external
    i2s_din_pin: GPIO13
    channel: right
    pdm: true
