From what I found the deep sleep mode of the display needs to be part of the esphome code for the display, it’s nothing you can manually set if it wasnt taken into account by the esphome developer before.
Ah, I understand.
But if so, everyone should be running into this issue…
And I do not understand why the greasy display fix hasnt been implemented in all v7,5 models …
I also never got the logic behind some people not having issues, and some (including me) struggling forever. The time and financial effort just got too big for me over time, which is a dealbreaker when compared to the little happiness i got out of it. Occasionally when it “hits me” i get motivated again and give it another go, but for projects where i need reliability i either use the 2.9inch display or leds.
Who knows, maybe in January I’ll risk it and get myself a new 7.5er panel
I am wondering if my display borked itself. I have been using a LilyGo 7.5 display, with wave share_epaper display working great. Yesterday at 3:21 pm was the last update. When I check the logs I see it hang on spi device, then throw a watchdog trigger. Has anyone else seen this?
[08:19:33][D][spi_device:393]: mode 0, data_rate 2000kHz
[08:19:38]E (10911) task_wdt: Task watchdog got triggered. The following tasks/users did not reset the watchdog in time:
[08:19:38]E (10911) task_wdt: - loopTask (CPU 0)
[08:19:38]E (10911) task_wdt: Tasks currently running:
[08:19:38]E (10911) task_wdt: CPU 0: IDLE0
[08:19:38]E (10911) task_wdt: CPU 1: IDLE1
[08:19:38]E (10911) task_wdt: Aborting.
[08:19:38]E (10911) task_wdt: Print CPU 0 (current core) backtrace
