Hi, Can you tell me how you flashed the board?
I have connected a USB to TTL and it all powers up good.
The problem is I cannot down load to the board.
Try using esphomeflasher. I could not flash some boards using web tool.
I donāt recall anything special to be honest. Shortening IO0 pin with GND before powering it, disconnected that after about 5 seconds and then flashed.
Thanks.
Used another flash tool and it worked.
Did you have to do anything special with the EspHome configuration?
i have successfully flashed it with EspHome from HA and the configuration succeeded but the wifi was not activated on the chip and I cannot access it via wifi.
Here is example. You should have your wifi details configured in secrets file. And if it cannot connect, it will revert to AP (name and password defined below)
esphome:
esp8266:
board: esp12e
early_pin_init: false
# Enable logging
logger:
#web_server:
# port: 80
ota:
password: "xxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "GardenWatering-8ChAP"
password: "xxx"
I am going crazy here.
It just will not find my wifi.
I even set up a fall back wifi using another hotspot and it cannot find that either.
I think that the version of yaml on the esp8266 is not the same as I have in EspHome.
Even though EspHome has returned a successful install.
To get EspHome to install I have to put on the jumper cable between IO0 and GND
And then for normal operation I remove the jumper.
Maybe the Yaml is just not being saved? Or it is always resetting it to the original version I flashed.
[D][wifi:402]: Found networks:
[D][wifi:450]: - āFerenczi_Netā[redacted] (68:FF:7B:49:97:2C) [redacted]āāāā
[W][wifi:456]: No matching network found!
[D][wifi:387]: Starting scanā¦
esphome:
friendly_name: Relay
esp8266:
board: esp01_1m
# Enable logging
logger:
level: debug
# Enable Home Assistant API
api:
encryption:
key: "KD1i/etXnNlzy84uaZxjgJCp9OuWzAJgzzqXZYnWJqY="
ota:
password: "54364c9085cf7eb39174df48a0c27378"
wifi:
ssid: Ferenczi_Net
ap:
ssid: "Relay Fallback Hotspot"
password: "IzwULOwcXU07"
captive_portal:
Should you be using quotes?
I donāt specify SSID in code. Both are stored in my secrets file and in " ". And in code for device, I point them to secrets.
So if you put SSID directly in code, should it be in quotes?
Device code has following:
wifi:
Secrets contain this:
# Your Wi-Fi SSID and password
wifi_ssid: "myssid"
wifi_password: "mypass"
I initially had it all in secrets.
Then I tried without secrets and without quotes
The I tried with quotes.
FFS !!
Just restarted the whole of Home Assistant and it now works. I did that earlier without any luck.
Well my device is now online
Thanks eveyone.
Much appreciated
hello,
still not clear on that⦠is there some benefit of that board comparing to the arduino+relay board? Still struggling here, whats the best way to control relay boards and integrate everything into HA.
thx
Resurrecting a long dead thread is rarely a good idea. Start a new thread with the question you have. Read this on how to ask a good question:
In particular focus on the real problem you are trying to solve not the problems you are having with what you believe to be the solution to your real problem.
The benefit of a relay board with a built-in esp is that it is one piece of hardware, so less work to hook up. Only you can decide if that is a benefit to you.
and unlike most arduino comes directly with networking capabilities (wifi ) on board
ESPHome on the other hand allows easy encrypted local push communication with Home Assistant without fuss (and inventing the wheel again)
