I would love to implement Fire effect from BRUH led strip, I’m using it when turning on heating. I cannot figure out how to add that effect…
I am trying also to move from a Arduino code (made by someone else) to ESPHOME, which is really great and practical, I love it.
I solved it with SWITCH, but its not optimal since I need a LOCK, I was wondering if/how to use a binary sensor instead of SWITCH for LOCK and another SWITCH for UNLOCK
Below the Arduino code, and my first attempt with SWITCH in ESPhome
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#define MQTT_VERSION MQTT_VERSION_3_1_1
// Wifi: SSID and password
const char* WIFI_SSID = "*****";
const char* WIFI_PASSWORD = "*****";
// MQTT: ID, server IP, port, username and password
const PROGMEM char* MQTT_CLIENT_ID = "DoorLock";
const PROGMEM char* MQTT_SERVER_IP = "*****";
const PROGMEM uint16_t MQTT_SERVER_PORT = 1883;
const PROGMEM char* MQTT_USER = "******";
const PROGMEM char* MQTT_PASSWORD = "*********";
// MQTT: topics
const char* MQTT_LOCK_STATE_TOPIC = "stat/home/door";
const char* MQTT_LOCK_COMMAND_TOPIC = "cmnd/home/door";
// payloads by default (on/off)
const char* UNLOCK = "UNLOCK";
const char* LOCK = "LOCK";
const PROGMEM uint8_t LOCK_PIN = 5;
boolean lock_state = false;
WiFiClient wifiClient;
PubSubClient client(wifiClient);
// function called to publish the state of the light (on/off)
void publishLightState() {
if (lock_state) {
client.publish(MQTT_LOCK_STATE_TOPIC, UNLOCK, true);
} else {
client.publish(MQTT_LOCK_STATE_TOPIC, LOCK, true);
// function called to turn on/off the light
void setLockState() {
if (lock_state) {
digitalWrite(LOCK_PIN, HIGH);
delay(100);
digitalWrite(LOCK_PIN, LOW);
delay(100);
delay(100);
delay(100);
delay(100);
Serial.println("INFO: Door is unlocked...");
} else {
delay(100);
delay(100);
Serial.println("INFO: Door is locked...");
// function called when a MQTT message arrived
void callback(char* p_topic, byte* p_payload, unsigned int p_length) {
// concat the payload into a string
String payload;
for (uint8_t i = 0; i < p_length; i++) {
payload.concat((char)p_payload[i]);
// handle message topic
if (String(MQTT_LOCK_COMMAND_TOPIC).equals(p_topic)) {
if (payload.equals(String(UNLOCK))) {
lock_state = true;
setLockState();
publishLightState();
} else if (payload.equals(String(LOCK))) {
lock_state = false;
setLockState();
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("INFO: Attempting MQTT connection...");
// Attempt to connect
if (client.connect(MQTT_CLIENT_ID, MQTT_USER, MQTT_PASSWORD)) {
Serial.println("INFO: connected");
// Once connected, publish an announcement...
// ... and resubscribe
client.subscribe(MQTT_LOCK_COMMAND_TOPIC);
} else {
Serial.print("ERROR: failed, rc=");
Serial.print(client.state());
Serial.println("DEBUG: try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void setup() {
// init the serial
Serial.begin(115200);
// init the led
pinMode(LOCK_PIN, OUTPUT);
analogWriteRange(255);
setLockState();
// init the WiFi connection
Serial.println();
Serial.println();
Serial.print("INFO: Connecting to ");
WiFi.mode(WIFI_STA);
Serial.println(WIFI_SSID);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("INFO: WiFi connected");
Serial.print("INFO: IP address: ");
Serial.println(WiFi.localIP());
// init the MQTT connection
client.setServer(MQTT_SERVER_IP, MQTT_SERVER_PORT);
client.setCallback(callback);
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "xx"
password: "xx"
manual_ip:
static_ip: 192.168.1.189
gateway: 192.168.1.239
subnet: 255.255.255.0
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
switch:
- platform: gpio
pin:
number: D0
inverted: yes
icon: "mdi:gate"
turn_on_action:
- switch.turn_on: relay
- delay: 500ms
- switch.turn_off: relay
icon: "mdi:gate"
turn_on_action:
- delay: 500ms
- delay: 100ms
- delay: 500ms
- platform: wifi_signal
name: "14b BLE Bridge WiFi Signal"
update_interval: 60s
- platform: uptime
name: "14b BLE Bridge Uptime"
text_sensor:
- platform: version
name: "14b ble bridge ESPHome Version"
Do you have an updated link to this code? I’m trying to do the same thing with converting BRUH’s Arduino on a NodeMCU to ESPHome.
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: 'xxxx'
password: 'xxxx'
domain: .xxxx
manual_ip:
static_ip: 172.16.0.80
gateway: 172.16.0.1
api:
# Enable logging
logger:
ota:
light:
- platform: fastled_clockless
chipset: WS2812
pin: D5
num_leds: 29
rgb_order: GRB
effects:
- addressable_flicker:
update_interval: 16ms
intensity: 5%
- addressable_fireworks:
update_interval: 32ms
spark_probability: 10%
use_random_color: false
fade_out_rate: 120
- addressable_random_twinkle:
twinkle_probability: 5%
progress_interval: 32ms
- addressable_twinkle:
progress_interval: 4ms
- addressable_scan:
name: Scan Effect With Custom Values
move_interval: 100ms
- addressable_color_wipe:
colors:
- red: 100%
green: 100%
blue: 100%
num_leds: 1
- red: 0%
green: 0%
blue: 0%
num_leds: 1
add_led_interval: 100ms
reverse: False
- addressable_rainbow:
speed: 10
width: 50
- strobe:
colors:
- state: True
brightness: 100%
red: 100%
green: 100%
blue: 100%
duration: 50ms
- state: True
brightness: 100%
red: 0%
green: 0%
blue: 0%
duration: 50ms
- strobe:
colors:
- state: True
brightness: 100%
red: 100%
green: 10%
blue: 10%
duration: 100ms
- state: True
brightness: 0%
duration: 3000ms
- strobe:
colors:
- state: True
brightness: 100%
red: 0%
green: 100%
blue: 0%
duration: 100ms
- state: True
brightness: 0%
red: 0%
green: 0%
blue: 0%
duration: 100ms
- state: True
brightness: 100%
red: 0%
green: 100%
blue: 0%
duration: 100ms
- state: True
brightness: 0%
red: 0%
green: 0%
blue: 0%
duration: 3000ms
- strobe:
colors:
- state: True
brightness: 100%
red: 10%
green: 10%
blue: 100%
duration: 100ms
- state: True
brightness: 0%
red: 0%
green: 0%
blue: 0%
duration: 3000ms
- strobe:
colors:
- state: True
brightness: 100%
red: 100%
green: 100%
blue: 100%
duration: 100ms
- state: True
brightness: 0%
red: 0%
green: 0%
blue: 0%
duration: 100ms
- state: True
brightness: 100%
red: 100%
green: 100%
blue: 100%
duration: 100ms
- state: True
brightness: 0%
red: 0%
green: 0%
blue: 0%
duration: 3000ms
- random:
transition_length: 5s
update_interval: 7s
Thank you!!! That worked perfectly!
