ESPresense, Wear OS, and Tips/Tricks
Hi where do you set this parameter? where i can change the Measured Power for the watch?
Hi Guys,
i have problems with my galaxy watch 6 :frowning: Hope you can help me, i tried everything i know since days now.
The Problem is that the iBeacon in the wear os ha app gives very strange parameter. - -
  • there are always gaps in the tracking
  • the distance is very inaccurate
i can´t find the correct ESPresense Preferences that will adjust the distance.
in the picture you can see the samsung-7cff… that is the watch with the correct distance. The iBeacon is the Beacon from Homeassistant Wear Os app.
can i adjust the RSSI@1m from the iBeacon from the watch? i tried with mttq explorer but it wont adjust the parameter.
the second option is to use the BT from the samsung-7cff… but the problem here is that the MAC and ID is changing every time. And i didnt found a way to fix this.
With my phone i fixed it with the enroll function. But the watch did not connect to this Bluetooth.
And i tried playing with the espresense preferences, set the absorbtion to 20 for example then the distance in 1-2m is correct but when i walk 6m the esp still showes 2,8m for example… my brain is soon exploding xD
thanks for youre help
Im just playing with a watch 6, and i see the same problems, the ibeacon show high distances (from 8 meters and up), when im 40cm away from the nodemcu it show like 8meters… when phone shows 0,8 meters.
Someone have the best config to make this work regarding:
  • ble_set_transmit_power
  • ble_set_advertise_mode
Just made a test changing ble_set_transmit_power from HIGH to LOW to MEDIUM and this are the results
@tkzger regarding BT mac, its not possible I think, because it create random address every time
and the battery. the battery consumption in galaxy watch its horrible! :frowning:
