wingers
(Darren Rose)
November 18, 2024, 12:21pm
2278
Yes the camera has RTSP but it is not enabled as connected to a HomeBase 3. But it is also not enabled on any other of my cameras (except one) and they all show okay in default tiles added to dashboard.
Now trying to make my own dashboard and struggling to find best way to add a live stream to my Eufy cameras, I can get it working, but often after pressing the play button icon I have to refresh the page to see it streaming, this is annoying especially on tablet where I can’t just hit F5
RT1080
(Ronald)
November 18, 2024, 1:36pm
2279
Try webrtc and the relevant cards. You can add icons in the still with among others a play/pause button.
My experience though is that rtsp results in a more responsive behaviour - irrespective of the homebase
It will never be ideal, welcome to the Eufy customer experience.
wingers
(Darren Rose)
November 18, 2024, 1:39pm
2280
Okay, any guides as to the YAML I need to add to configure the WebRTC Camera Card please? I am new to this, so looking for some useful resources to control / display my eufy devices etc
wingers
(Darren Rose)
November 18, 2024, 8:26pm
2281
Can someone help me get this (e.g. popup window when doorbell motion activated) working with a Eufy E340 doorbell? Followed steps, but get error as below about webrtc codecs not matched
Many thanks
RT1080
(Ronald)
November 19, 2024, 6:55pm
2283
Would start with the basics, eg. See if you can implement the webrtc card and get it working. Once that works it will be easier to debug more complicated stuff.
When further exploring good to provide additional background. Eg. Whats the source? And what is included in your script?
There are by the way known conflicts with for instance frigate which has webrtc/gortc baked in. In order to get to the bottom please share more info and logs etc about your setup.
wingers
(Darren Rose)
November 19, 2024, 7:43pm
2284
Hi Ronald, thank you very much for your reply, and I fully appreciate what you are saying and think I need to start afresh and do the basics first. Think I got too involved in trying to follow various articles online to achieve my final goals without looking at the basics first.
One initial question, some guides indicate to install WebRTC via HACS, others seem to say to install go2rtc AND webRTC, but I thought just installng WebRTC also includes go2rtc? Think this may not be helping me as I have RTSPtoWebRTC and WebRTC Camera showing in integrations? so are the better steps to follow the ones here (GitHub - fuatakgun/eufy_security: Home Assistant integration to manage Eufy Security devices as cameras, home base stations, doorbells, motion and contact sensors. ) and just install webRTC via HACS?
Thank you - I can then test basics and come back with more details of any issues I face.
P.S. I don’t think I have frigate installed, certainly not chosen to do so and can’t see it anywhere
RT1080
(Ronald)
November 19, 2024, 7:50pm
2285
Would for now follow the steps outlined - there are more up to date versions available but at least the route on Fuatakgun’s repo is proven to work. From there provided it works you could use newer versions. Indeed gortc is integrated in this version.
Embedding Eufy within home assistant is not for the faint of heart… if i would invest again for sure the choice of product would be different…
wingers
(Darren Rose)
November 19, 2024, 7:52pm
2286
Okay will work through it tomorrow and see how I get on.
Yes I may choose differently another time, but unfortunately for now I am too far invested in eufy having 7 or 8 cameras now.
Thank you
First, Thanks @bropat and @anon63427907 for the Eufy integration work!
I have a Eufy C120 T8400 indoor 2K camera that can integrate, stream, and get event image notification in HA.
However, is there a way to get hourly snapshots and store in the /media directory?
My current setup:
Eufy cam: C120 T8400
HA (docker): 2024.7.3
bropat/eufy-security-ws (docker): 1.9.1
AlexxIT/WebRTC (HACS): 3.6.0
fuatakgun/eufy_security (HACS): 8.0.4
Thanks in advance!
RT1080
(Ronald)
November 20, 2024, 4:56pm
2288
Try an automation which starts a stream, takes a snapshot (built in functionality in ha) and stop the stream.
The snapshot works like this:
filename: /config/www/doorbell_snapshot.jpg
entity_id: camera.doorbell
action: camera.snapshot
If/when it works you can add the frequency and perhaps add the date / time stamp in the file name.
wingers
(Darren Rose)
November 20, 2024, 6:23pm
2289
When using a custom webrtc camera card, can I get it to show last event image from my camera when it is NOT streaming. So at idle it shows last event and then when I click play button it shows live stream?
Or if not how can I achieve this functionality please? basically want to show 6 cameras on one page (two columns of 3) and by default it shows the last event image, and then when clicked it either plays stream or perhaps even pops up a box showing the live stream and when popup closed the stream stops.
Thank you
Thank you so much! I will try it tonight.
Also, is there a way to save a copy of the Eufy event image?
I can see that the entity image.<eufycam_name>_event_image
contains the image of last triggered event of the camera, but how do I save a copy of it into my /media folder?
RT1080
(Ronald)
November 21, 2024, 7:09am
2291
I don’t know if its possible to extract a jpeg from an image.entity. If so it should be a feature built into home assistant
RT1080
(Ronald)
November 21, 2024, 7:13am
2292
home-assistant:dev
← NickM-27:image-service
opened 09:54PM - 08 Feb 24 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Integrations are moving from using the camera.entity to image.entity but there is not feature parity when it comes to the services offered for the image.entity. This PR adds the snapshot service to the image entity so users are able to save the images offline for their own usage.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request: https://github.com/home-assistant/home-assistant.io/pull/31327
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] I have followed the [perfect PR recommendations][perfect-pr]
- [x] The code has been formatted using Ruff (`ruff format homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [x] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [x] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
There was a pull request accepted last month in the dev version.
Its available in v2024.11
Yes, thank you!!
I updated HA to 2024.11.2.
The following automation works to “copy” the Eufy event image to my media folder (set up as persistent docker folder) whenever there’s a change in the Eufy event image:
alias: Eufy snapshot image
description: ""
triggers:
- trigger: state
entity_id:
- image.eufycam_lr_event_image
to: null
conditions: []
actions:
- action: image.snapshot
metadata: {}
filename: /media/eufy_image_snapshot.jpg
entity_id: image.eufycam_lr_event_image
mode: single
EDIT: add condition to make sure a true state change (not just attribute change) is detected.
See: https://github.com/fuatakgun/eufy_security?tab=readme-ov-file#alternative-trigger-condition
EDIT2:
Remove condition check. Add “to: null” in the trigger does the trick to make sure it triggers only on state change, not attribute changes.
See:
https://www.home-assistant.io/docs/automation/trigger/#state-trigger
Thanks again! It’s working for me.
In case it helps anyone, here’s my working hourly snapshot automation:
alias: Eufy rtsp stream snapshot
description: ""
mode: single
triggers:
- minutes: "7"
trigger: time_pattern
conditions: []
actions:
- target:
entity_id: camera.eufycam_lr
data: {}
action: eufy_security.start_rtsp_livestream
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
enabled: true
- variables:
timeStamp: "{{ as_timestamp(now(), 0) | timestamp_custom(\"%Y-%m-%d-%H%M\") }}"
- data:
filename: /media/eufy-snapshots/eufycam_lr-{{ timeStamp }}.jpg
- target:
data: {}
action: eufy_security.stop_rtsp_livestream
- data:
cmd_options: >-
-s -f /media/eufy-snapshots/eufycam_lr-{{ timeStamp }}.jpg
/media/eufy-snapshots/eufycam_lr.jpg
action: shell_command.ln_cmd
Note:
I use rtsp stream. The p2p stream doesn’t work on my C120 T8400 camera.
Some short delay is required after rtsp stream starts… I am using 5 seconds.
I do a symbolic link at the end so that my local_file integration can access the latest snapshot.
Try using Grid Card in the lovelace dashboard, then add a custom-webrtc card inside for each of your cameras, setting column to 2. The webrtc card should look like this:
type: custom:webrtc-camera
entity: camera.eufycam_lr
poster: image.eufycam_lr_event_image
ui: true
shortcuts:
- name: Play
icon: mdi:play
service: camera.turn_on
service_data:
- name: Stop
icon: mdi:stop
service: camera.turn_off
service_data:
See this for reference:
https://github.com/fuatakgun/eufy_security?tab=readme-ov-file#4-setting-up-your-dashboard-for-camera
I notice that encapsulating the webrtc card inside the Grid card forces it to update back to the event image when streaming is stopped.
wingers
(Darren Rose)
November 21, 2024, 10:06am
2296
Hi, thank you, tried that and when clicking play icon it shows stream, but when I then click stop it still shows last stream image, it doesn’t go back to the event image?
Update: it went back eventually but after about 2 minutes
hassiopi
November 22, 2024, 12:59am
2297
Yeah, the event image doesn’t come back immediately after streaming stops. Sometimes I have to do a refresh on the browser or my phone companion app.
