Are you sure you are using a correct country code? Did you login on the mobile app using secondary account?
Anyone else having issues running the latest version? (integration v2.6.1, addon v0.8.4)
2022-07-30 11:06:05.998 INFO Eufy Security server listening on host 0.0.0.0, port 3000
2022-07-30 11:06:10.712 INFO Connected to station T8010P23205218A1 on host 192.168.2.151 and port 16974
2022-07-30 11:06:11.206 INFO Push notification connection successfully established
2022-07-30 11:06:25.677 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:06:25.680 INFO Timeout connecting to station T8410P312143160B
2022-07-30 11:06:45.690 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:06:45.693 INFO Timeout connecting to station T8410P312143160B
2022-07-30 11:07:10.700 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:07:10.703 INFO Timeout connecting to station T8410P312143160B
2022-07-30 11:07:45.713 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:07:45.715 INFO Timeout connecting to station T8410P312143160B
2022-07-30 11:08:30.723 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:08:30.725 INFO Timeout connecting to station T8410P312143160B
2022-07-30 11:09:25.736 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:09:25.737 INFO Timeout connecting to station T8410P312143160B
My devices seemed to be unresponsive in HA
Error doing job: Task exception was never retrieved
File "/config/custom_components/eufy_security/__init__.py", line 60, in update
coordinator.async_set_updated_data(coordinator.data)
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 304, in async_set_updated_data
self.async_update_listeners()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 110, in async_update_listeners
update_callback()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 339, in _handle_coordinator_update
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 532, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 570, in _async_write_ha_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 538, in _stringify_state
if (state := self.state) is None:
File "/config/custom_components/eufy_security/alarm_control_panel.py", line 240, in state
return CODES_TO_STATES[current_mode]
KeyError: -1
I had the not available issue in the first boot after installing the latest update… but it was fine after a restart
You are far from latest version of add-on, it is 0.9.3, you have to update it
Any updates on this?
Updating the addon now, to my suprise the repository was removed from the addon store in my HA
This might be because of geofencing, please check it
I’ve updated the addon to 0.9.3, but it still gives me this result:
2022-07-30 11:56:33.109 INFO Eufy Security server listening on host 0.0.0.0, port 3000
2022-07-30 11:56:43.317 INFO Connected to station T8010P23205218A1 on host 192.168.2.151 and port 15436
2022-07-30 11:56:43.389 INFO Push notification connection successfully established
2022-07-30 11:56:58.272 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:56:58.276 INFO Timeout connecting to station T8410P312143160B
2022-07-30 11:57:18.288 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:57:18.291 INFO Timeout connecting to station T8410P312143160B
2022-07-30 11:57:43.308 INFO Timeout connecting to station T8410P312143160B
2022-07-30 11:57:43.306 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:58:18.316 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:58:18.319 INFO Timeout connecting to station T8410P312143160B
2022-07-30 11:59:03.330 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:59:03.333 INFO Timeout connecting to station T8410P312143160B
2022-07-30 11:59:58.343 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 11:59:58.346 INFO Timeout connecting to station T8410P312143160B
2022-07-30 12:01:03.356 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 12:01:03.361 INFO Timeout connecting to station T8410P312143160B
2022-07-30 12:01:49.915 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 12:01:49.917 INFO Timeout connecting to station T8410P312143160B
2022-07-30 12:03:18.372 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 12:03:18.374 INFO Timeout connecting to station T8410P312143160B
2022-07-30 12:06:33.384 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 12:06:33.386 INFO Timeout connecting to station T8410P312143160B
Ah no, this is something totally different, add-on is not able to reach out to base station
I’ve installed ‘NGINX Home Assistant SSL proxy’ yesterday, could that be the reason
Yes, too many variables might be impacting, some users are also separating their network virtually and limiting connections and causing similar issues
Restating the home base and then restarting the add-on might help. Lastly, you can try to access command line of eufy security add-on and try to ping home base with its ip address.
I think I see the issue ‘T8010P23205218A1’ is my base station and ‘T8410P312143160B’ is the inhouse camera that I’ve configured for my mothers house (different house in eufy app)
I think this causes the issue.
‘T8410P312143160B’ is currently offline (Mom pulled the plug out)
Still find it weird that homebase is unresponsive
You could only connect to one house right? or does it pickup all houses?
Restarting HomBase
2022-07-30 12:32:01.509 INFO Timeout connecting to station T8410P312143160B
2022-07-30 12:38:06.068 ERROR P2PClientProtocol.lookup(): station: T8410P312143160B - All address lookup tentatives failed.
2022-07-30 12:38:06.070 INFO Timeout connecting to station T8410P312143160B
2022-07-30 12:40:37.787 WARN Station T8010P23205218A1 - Heartbeat check failed. Connection seems lost. Try to reconnect...
2022-07-30 12:40:37.789 INFO Disconnected from station T8010P23205218A1
Cameras are working again so that is great!
But my Homebase is still unavailable. You have any idea?
Nope, this requires an issue with debug logs
I don’t know so much about houses and permission etc, having very simple setup at home. Did it work?
I feel like we have cleared many major bugs and left with p2p streaming reliability only. While i will come up with small adjustments on that topic, please share over here your requests.
Next big topic: have a custom webrtc card to eliminate conditional card usage and have stop button on it this is a working example running locally. Below you use one card to show live stream and latest picture depending on entity state, plus stop button and ptz buttons of configured. All working fine so far
I was working on adding pinch/tap pan & zoom (digital, not physical camera controls). Perhaps it’s something that could be added as well. I was basically aiming to replicate the functionality within the Eufy Android app for my various cameras. The library I was using generally seems to have all the needed functionality, but was missing proper shadow dom support. I have a PR open at https://github.com/timmywil/panzoom/pull/618, but it hasn’t gotten any attention for the couple months it’s been open…
