how can i activate the debug log?
and where can i find the log?
i get a little progress now i have a camera entity and much more but the picture is still not there
you should start streaming first to see the image or video. check readme/camera services section
yeah correct, i use
service: camera.turn_on
data: {}
entity_id: camera.kinderzimmer
and than click on a card with this
- type: custom:webrtc-camera
entity: camera.kinderzimmer
ui: true
the error i get is âcant get URL for camera.kinderzimmerâ
and sometimes "ârtsp client authorizedâ
Streaming either way is always going to be a resource hog although rtsp is desired for the obvious reason.
Having a option to idle the stream and turn it on is the best of both worlds.
Noticed the camera greyed out in the enabled section.
Is the eufy security adon running?
Release v5.2.5 ¡ fuatakgun/eufy_security ¡ GitHub is released.
more than 30 installations on 5.x.x versions, thanks
source: https://analytics.home-assistant.io/custom_integrations.json
In total, there are around 1800 installation of this integration and these numbers are gathered only from users who enabled analytics.
Working without issue and the only thing i noticed that broken is the streaming status doesnât change all the time when the stream is stopped.
As bugs go thatâs as minor as it gets
The new features are going to need a little explain for some and you gone and made a much more robust upgrade over the old one
I would suspect the 30 installations number to start jumping really fast
Is there a way to get my doorbell to stream to a Nest Hub on press? I have one in my office so it would be great if it could act as a sort of intercom without having to get my phone out.
Iâve tried various different ways including the below but nothing happens.
For context, everything is working as expected for normal streaming if I set up a card, so I donât think the actual integration is the issue, just my understanding of implementation for this particular set up. The doorbell is set to âSmart display firstâ as I thought this might be necessary as well
alias: Doorbell to Nest
description: ""
- platform: state
entity_id:
- binary_sensor.xxx_doorbell_ringing_sensor
to: "True"
condition: []
- service: eufy_security.start_rtsp_livestream
data: {}
device_id: 58e757512bca9a43a32a40b36f822b1a
- delay:
hours: 0
minutes: 0
seconds: 20
milliseconds: 0
- service: eufy_security.stop_rtsp_livestream
data: {}
mode: single
I also installed the RTSP Simple Server Add-on and when HA is started I first need to stream to get a camera thumbnail image every time I want to view the thumbnail it is slow to lead and now it always says streaming. Before it would show the thumbnail of the last image Eufy has, just like in the app and it would show that instantaneously before. Now that part is not working at all. Iâm also wondering if this will now drain the battery as it needs to start streaming first before you see an image.
Yes of course it will drain the battery if you keep streaming alive forever. Just turn it on for a couple of seconds and turn it off afterwards. Moreover eufy had encrypted thumbnails so as of now this is the only way, if you want to have thumbnails.
1- be sure to use correct service. If your doorbell doesnât support rtsp natively, you should call p2p service.
2- there should be a service called camera.play_stream to mirror the stream into cast devices
@anon63427907 how do I enable analytics for you? I got a T8200 and noticed that the motion sensor is not working. The ringing sensor is working correctly. Is this expected behavior for this model?
Thanks @anon63427907 using that camera.play_stream
service has done the trick. I have added a 30 second delay then called the eufy_security.stop_p2p_livestream
to get around the constant Stream Queue Size
that @Jeroen_Schwankhuizen pointed out above and I was also having as I couldnât find any other way to stop it. I was hoping it would stop itself after a few minutes but it doesnât seem to be. Is there a better approach to this?
description: ""
- platform: state
entity_id:
to: "True"
condition: []
- service: camera.play_stream
media_player: media_player.family_room_hub
device_id: c93323xxxxxxxfbfd7c0
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- service: eufy_security.stop_p2p_livestream
data: {}
mode: single
Example of image capturing, snoozing and alarming the camera. Replace camera entity name and mobile app name according to yours.
alias: Capture Image on Trigger, Send Mobile Notification with Actions, Snooze or Alarm via Actions
description: ""
- platform: state
entity_id:
- binary_sensor.entrance_motion_detected
- binary_sensor.entrance_person_detected
to: "on"
- platform: event
event_type: mobile_app_notification_action
event_data:
action: SNOOZE
- platform: event
event_data:
action: ALARM
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: eufy_security.start_p2p_livestream
data: {}
entity_id: camera.entrance
data: {}
- service: notify.mobile_app_fuatx3pro
message: Motion detected
image: /api/camera_proxy/camera.entrance
actions:
- action: ALARM
title: Alarm
- action: SNOOZE
title: Snooze
- conditions:
sequence:
- service: eufy_security.snooze
snooze_time: 10
snooze_chime: false
snooze_motion: true
snooze_homebase: false
- conditions:
sequence:
- service: eufy_security.trigger_camera_alarm_with_duration
duration: 1
mode: single
Soon, I will merge Alpha branch into Master, so it will become main version, so take your time and give it a try.
README is updated for alpha release
I deleted the integration and reinstalled it, solved it.
okay i get it to work i set the rtsp security to off in the app.
but now i have a question for the ptz control.
now i have buttons for each direction, the call unter services works well with this for example
service: eufy_security.ptz_down
entity_id: camera.keller
is it possible to use this with the ptz overlay?
in the past i use this
ptz:
opacity: 0.6
service: eufy_security.send_message
data_left:
message: |-
"messageId": "cmd Pan And Tilt Down",
"command": "device.pan_and_tilt",
"serialNumber": "T8410P3121431696",
"direction": 1
data_right:
message: |-
"direction": 2
data_up:
message: |-
"direction": 3
data_down:
message: |-
"direction": 4
is the old methode not working anymore?
Old method should work.
Where do you have this ptz overlay functionality?
You can get serial number on Debug sensor attributes.
Ok, just understood your question, i will publish a new service tomorrow to create one unified ptz service call eufy_security.ptz(up/down/right/left/360).
in the custom:webrtc-camera card, but when i usw services under developer, the command doesnt work, the camera dont move, i think the command is wrong?
entity: camera.keller
ui: true
ptz:
opacity: 0.6
data_left:
message: |-
"direction": 1
data_right:
message: |-
"direction": 2
data_up:
message: |-
"direction": 3
data_down:
message: |-
"direction": 4
