Hi @prese,
Here is the link to charging controller: https://www.phoenixcontact.com/online/portal/gb/?uri=pxc-oc-itemdetail:pid=1018701.
According to datasheet the Modbus interface contains all the same features as webpage, so the password is really not needed.
When I asked for support from Walbe, they said:
The LAN interface of this version is only intended for maintenance or programming works.
With the access you can easily change settings that could damage the charging station and you also lose your warranty.
Please note that an incorrect setting of the charge controller will result in immediate loss of warranty.
Unfortunately, we cannot offer support for integration or Modbus questions to private end customers.
My translation about the warning would be: You should make it absolutely sure that you do not configure the charger for higher currents: cabling in the device is rated only for 16A. I think the dip switches are used for this setting, but better safe than sorry!
Any other settings are probably reversible with the reset command from Modbus, firmware upgrade excluded of course
