Nice…I will check it
Can you set it for example on “4KW” when the car is connected? Is that not a problem for the car?
I don’t have an EV or electric car charger but I’m interested in the combination with HA.
Is it after integration of Etrel Inch with Modbus TCP possible to limit charging power to balance your network. In Belgium you pay extra if your 15 minute month peak is higher than 2.5KW.
So I’d like to consume own production by loading a car and/or limit power consumption of whole house below the highest peak of that month or below 2.5kW. I would like to add in HA some IFTTT like functions to do that; based on production info from Inverter PV, P1 port digital meter, …
So is this possible?
I’m just starting in HA and can install ‘predefined’ integrations; but no experience with writing code …
