EVCC integration via MQTT (sensor entity config)
Hey guys,
for the energy dashboard to work, you need to add state_class: measurement to the relevant sensor definitions. Which ones do you think are relevant and I am happy to amend them above.
ok, found it our by myself.
first, you have to create this template sensors (because the evcc sensors are positiv and negativ, we need to split up this sensors):
sensors:
  - name: "Netz Verbrauch (W)"
    unique_id: netz_verbrauch_w
    unit_of_measurement: "W"
    device_class: power
    state: "{{ max(states('sensor.evcc_grid_power_w') | int, 0) | default(0)}}"
  - name: "Netz Einspeisung (W)"
    unique_id: netz_einspeisung_w
    device_class: power
    state: "{{ min(states('sensor.evcc_grid_power_w') | int, 0) | abs | default(0)}}"
  - name: "Batterie Entladeleistung (W)"
    unique_id: batterie_entladeleistung_w
    device_class: power
    state: "{{ max(states('sensor.evcc_battery_power_w') | int, 0) | default(0)}}"
  - name: "Batterie Ladeleistung (W)"
    unique_id: batterie_ladeleistung_w
    device_class: power
    state: "{{ min(states('sensor.evcc_battery_power_w') | int, 0) | abs | default(0)}}"
Second, you need to create helper sensors ā€œRiemann sum integralā€ with ā€œk (kilo)ā€ and ā€œhourā€ for each of these new sensors (and in addition for the pv_grid_power sensor).
Third, you can use this Riemann sensors for the energy dashboard.
:slight_smile:
Hello, if you add the unique_id to the sensors you don’t need to do the conversion with Riemann, you can also do this via the user interface at the gear wheel at the top of the sensor.
@Bimbo009 I don’t want to convert from W to Wh, but from W to kWh, therefor I need the Riemann helper as far as I know :wink:
Are there any known issues with the march update. Since I have updated HA the mqtt sensors aren’t available any more…
You are right, the sensor would have to be in wh.
Sorry if I didn’t understand that thought: Why do you need Riemann (which intrinsically introduces a drift) if we already have evcc_charged_energy_kwh coming directly from EVCC?
Would love to update my set of complete MQTT entities above, as soon as we agree on the solution.
@ThomDietrich
EVCC exports also the evcc/site/gridEnergy if the meter supports it.
Since the meter is placed at feed-in, is that the total grid consumption (home usage - PV produced) ?
evcc/site.go at 7d08f929857cfe8db28a3b5829483adde0122277 Ā· evcc-io/evcc (github.com)
edit:
I found that at the ā€œevcc/site/gridEnergyā€ mqtt topic evcc exports the grid energy usage.
First of all: Thank you very much @ThomDietrich for your effort in integrating evcc into Home Assistant via MQTT. It works like a charm and adds an unbelievable amount of WAF :slight_smile:
I have a side question: Do you know how to change the frontend values of the mqtt-state-options? As far as I know, these values don’t have friendly names. I’d like to enhance the WAF further and like to change the displayed names to stuff like ā€œNo Chargingā€, ā€œPV onlyā€, ā€œCharge fastā€:
Thanks!
I can’t think of an easy way. Sadly you can’t ā€œtranslateā€ states like in the example. You have to define a new input with your desired display names, then set the MQTT entity from that via an automation.
Something like the below. Please share your working solution!!
input_select:
  evcc_mode_friendly:
    icon: mdi:tune-variant
    #initial: "Off"
    options:
      - "Off"
      - "Full throttle!"
automation:
  - alias: xxx
      - platform: state
        entity_id: input_select.evcc_mode_friendly
      - service: input_select.select_option
        option: >
          {% if is_state(trigger_state, 'Off') %}
            off
          {% elif is_state(trigger_state, 'Full throttle!') %}
            now
          {% else %}
            unknown
          {% endif %}
Gnah, I thought there will be an easier way than another automation. Thanks for your input!
Edit: I found a solution. I don’t know if its easier but it’s at least prettier than the MQTT topics in a drop down menu (in my opinion):
grafik
grafik
The Buttons will change their color according to the current state of the select-entity. When the Mode is off, the other buttons will be dark, in any other case, they will light up so that you can see that your charger is ready for operation.
I couldn’t get what I wanted with on-board lovelace cards and used a custom integration. If you’d like to recreate the dashboard, you’ve got to install the Custom Button Card Integration first - use HACS for your convenience.
Then I stacked a couple of buttons horizontally with the following code:
type: horizontal-stack
cards:
  - type: custom:button-card
    entity: select.evcc_mode
    tap_action:
      action: call-service
      service: select.select_option
      service_data:
        entity_id: select.evcc_mode
        option: 'off'
    color_type: card
    icon: mdi:power
    styles:
      card:
        - height: 60px
        - width: 110px
    state:
      - value: 'off'
        color: yellow
    tap_action:
      service_data:
        option: pv
    color_type: card
    icon: mdi:solar-power
    styles:
      card:
        - height: 60px
        - width: 110px
    state:
      - value: pv
        color: yellow
    tap_action:
      service_data:
        option: minpv
    color_type: card
    icon: mdi:ev-station
    styles:
      card:
        - height: 60px
        - width: 110px
    state:
      - value: minpv
        color: yellow
    tap_action:
      service_data:
        option: now
    color_type: card
    icon: mdi:power-plug
    styles:
      card:
        - height: 60px
        - width: 110px
    state:
      - value: now
        color: yellow
You could even beautify that more with a grid (I’m not yet lucky with the colors, does anyone know the standard ā€œyellowā€ for the default dark skin? :thinking:):
grafik
square: false
type: grid
columns: 4
cards:
    tap_action:
      service_data:
        option: 'off'
    color_type: card
    icon: mdi:power
    styles:
      card:
        - height: 60px
        - width: 100px
    state:
      - value: 'off'
        color: chocolate
    tap_action:
      service_data:
        option: pv
    color_type: card
    styles:
      card:
        - height: 60px
        - width: 100px
    state:
      - value: pv
        color: chocolate
    tap_action:
      service_data:
        option: now
    color_type: card
    styles:
      card:
        - height: 60px
        - width: 100px
    state:
      - value: now
        color: chocolate
    entity: input_boolean.laden_bis_80
    tap_action:
      action: toggle
    color_type: card
    styles:
      card:
        - height: 60px
        - width: 100px
    state:
      - value: 'on'
        color: chocolate
Right! Obviously you were asking about a nice way to build a UI with higher WAF and this looks amazing. I might copy that :slight_smile:
@Ener
There is an alternative solution to the one from @ThomDietrich above. You can use template for value_template and command_template to override the labels:
    - command_topic: "evcc/loadpoints/1/mode/set"
      unique_id: uniqueid__evcc_mode_select
      state_topic: "evcc/loadpoints/1/mode"
      value_template: >
          {% if value == 'off' %}
            Aus
          {% elif value == 'pv' %}
            PV
          {% elif value == 'minpv' %}
            Minimum + PV
          {% else %}
            Schnell
          {% endif %}
      command_template: >
          {% if value == 'Aus' %}
            off
          {% elif value == 'PV' %}
            pv
          {% elif value == 'Minimum + PV' %}
            minpv
          {% else %}
            now
          {% endif %}
      options:
        - "Aus"
        - "PV"
        - "Minimum + PV"
        - "Schnell"
grafik
Hey @softcat, thanks for your hint! I already used value_templates but didn’t remember that way to make values ā€œmore readableā€ or ā€œmore intutiveā€. Of course yours is the one and only way as my solution only makes the UI a (small) bit more usable.
Hi, I am facing the PrioritySoc problem still. (and BufferSoc)
It sais value ā€œunknownā€. All other parameters work fine.
Configuration is. EVCC newest version 0.116.7.
Symo GEN24 Plus
BYD HVM Battery
→ Why does it look like this? - I am missing ideas…
Any ideas what to look for next?
Maybe BYD Batteries (unlikely) do not support that? How could I test that? Maybe within EVCC? Where can I see the bufferSoc and prioritySoc-Values within EVCC?
Thank you very much for you help already!!!
The value is essential for further automations!
EVCC creates the configuration like this in evcc.yaml:
meters:
- type: template
  template: fronius-gen24
  usage: grid
  host: 10.10.10.42
  port: 502
- type: template
  usage: pv
  host: 10.10.10.42
  port: 502
- type: template
  usage: battery
  host: 10.10.10.42
  port: 502
  capacity: 11
HA configuration.yaml sais:
  number:
    - name: evcc_min_current
      unique_id: uniqueid__evcc_min_current
      icon: mdi:current-ac
      state_topic: "evcc/loadpoints/1/minCurrent"
      command_topic: "evcc/loadpoints/1/minCurrent/set"
      availability_topic: "evcc/status"
      min: 6
      max: 16
      step: 0.25
      unit_of_measurement: "A"
    - name: evcc_max_current
      unique_id: uniqueid__evcc_max_current
      state_topic: "evcc/loadpoints/1/maxCurrent"
      command_topic: "evcc/loadpoints/1/maxCurrent/set"
      min: 6
      max: 16
      step: 0.25
    - name: evcc_buffer_soc
      unique_id: uniqueid__evcc_buffer_soc
      icon: mdi:label-percent-outline
      state_topic: "evcc/site/bufferSoc"
      command_topic: "evcc/site/bufferSoc/set"
      min: 1
      max: 100
      unit_of_measurement: "%"
    - name: evcc_priority_soc
      unique_id: uniqueid__evcc_priority_soc
      state_topic: "evcc/site/prioritySoc"
      command_topic: "evcc/site/prioritySoc/set"
      min: 1
      max: 100
Hey @ptrrtpptr,
you missed to post the most important screenshot, and that is I think where your solution lies.
Data is communicated by EVCC to MQTT, and HA reads those values via the configuration I provided here in this thread. Simply connect to your MQTT server directly (e.g. with the software MQTT Explorer) and check whether the topic evcc/site/bufferSoc exists, whether it was renamed, and which values it holds.
Is there a solution yet? I would also like to have the evcc_charged_energy_kwh as an entity for my energy dashboard. But as far as I understood the documentation this value is not really suited to be used as such, since it needs a form of reset timestamp. Has anyone done this up to now?
first of all: Thanks for you’r work :slight_smile:
As I understand @nicx, and as I’m looking into using evcc’s mqtt data, he aims to use evcc as a proxy for all connected sources and drains. Including evcc as a source for inverter production to use as a source for the energy dashboard. The evcc_charged_enegry_kwh does only reflect the total consumption of the charging station and not the production of the pv (just the current flow). As @Bimbo009 pointed out it is possible to convert the necessary values (evcc/site/N/power and evcc/site/battery/N/power) from W to Wh using the gear wheel (which I can’t reproduce/find… and doubt that data would be correctly converted given the bedirectional nature of grid consumption with pv feed-in).
That said, @nicx provides a solution to convert these values in a way to be able to use these values correctly as a source for general consumption / production for the energy dashboard.
I think this approach is usefull because you need only one software to connect to your inverter / bms.
In my case I have a LG ESS Home, which is not directly supported by HA (but by evcc). In order to use it I would need to use thirdparty software as pyess for example which is not available as an addon (or atleast need to be created) for HAOS and therefore would need additional hardware to run.
Seems like there have been some renames going on in the meantime
phases → phasesEnabled
activePhases → phasesActive
You might want to update this. Thanks for the detailled config to copy/paste!
