riston
(Risto Novik)
October 6, 2019, 2:36pm
64
Hello, I did the same thing and the new name cube_rotation
isn’t exposed in the deconz_event
. Is there a way to refresh device metadata?
"event_type": "deconz_event",
"data": {
"id": "mi_magic_cube",
"unique_id": "00:15:8d:00:02:a3:76:9c",
"event": 6000
"origin": "LOCAL",
"time_fired": "2019-10-06T14:32:58.710379+00:00",
"context": {
"id": "6145043fdfe64d8595bfa15fc3c40394",
"parent_id": null,
"user_id": null
Hi
Great forum thread.
For those needing the renaming of the two cube devices in deconz I have summarized the workaround in another forum thread.
OK.
This is not perfect but here is a summary of the recipe to use the Mi / Aqara / Xiaomi Magic Cube in Home Assistant through Deconz. This is unique to Deconz!
First you pair the device in Phoscon. It seems to go best if you pair it while flipping and rotating it.
Deconz now actually created TWO devices. As they are created they will be called Switch## where ## is a number that depends on how many devices you have. Home assistant auto discover these.
It is a really good idea if you before …
Yves_IF
(Yves)
August 6, 2020, 7:36am
66
Hi @fantomnotabene
How do you get the Eventdata (this 4numbers) with templating?
I try to make a template sensor, but ehitout luck.
platform: template
sensors:
aqara_cube_01:
friendly_name: ‘aqara_cube_01’
value_template: “{{states (‘sensor.cube_01’)}}”
I created the name cube_01 when i had conneting the aqara cube in the deconz web interface. The battery-State is shown as entity: sensor.cube_01_battery_level So i just guess the name in the template sensor script. The result: the state of the template sensor are always ‘unknown’.
Can sombody help?
Inside of an automation, triggered by “platform: event”, you can use
{{ trigger.event.data }}
Event should be filtered by deconz_event
and your cube’s device id.
Yves_IF
(Yves)
August 9, 2020, 3:43am
68
thanks - but that aren’t i’m looking for. i like to have the sensor data…
You can use input_text
instead of sensor
(or create template sensor and sync their states) and set its value via automation. Don’t know if there’s a better way.
Yves_IF
(Yves)
August 9, 2020, 5:28am
70
Thanks - sounds good. Would you give me an example, to bring me on the right track?
Create an input_text entity.
Create a template sensor entity, which value_template
points to an input_text
's state (something like {{ states('input_text.cube') }}
Then create an automation like this one:
- alias: ...
platform: event
event_type: deconz_event
event_data:
service: input_text.set_value
entity_id: input_text.cube
data_template:
value: "{{ trigger.event.data.event }}"
Or you can even set text value to an input_text
accordingly to event number if you know how to use template conditions.
Yves_IF
(Yves)
August 10, 2020, 9:41am
72
Works perfect! Thanks a lot
vpa
(Vaclav Panenka)
September 27, 2020, 3:24pm
73
I’ve been tried code under, I have two cubes, but it doesn’t working. When I’ve been trying deconz_event, it shows me events with event and gesture elements, but all sensors has only value 0 and nothing has been changed.
input_text:
mi_magic_cube_1_event:
name: Mi Magic Cube 1 Event
initial: 0000
mi_magic_cube_1_gesture:
name: Mi Magic Cube 1 Gesture
initial: 0
mi_magic_cube_2_event:
name: Mi Magic Cube 2 Event
initial: 0000
mi_magic_cube_2_gesture:
name: Mi Magic Cube 2 Gesture
initial: 0
sensors:
value_template: "{{ states('input_text.mi_magic_cube_1_event') }}"
value_template: "{{ states('input_text.mi_magic_cube_1_gesture') }}"
value_template: "{{ states('input_text.mi_magic_cube_2_event') }}"
value_template: "{{ states('input_text.mi_magic_cube_2_gesture') }}"
automation mi_magic_cube_1_event:
- alias: Mi Magic Cube 1 event
platform: event
event_data:
entity_id: input_text.mi_magic_1_event
data_template:
automation mi_magic_cube_1_gesture:
- alias: Mi Magic Cube 1 gesture
platform: event
event_data:
entity_id: input_text.mi_magic_1_gesture
data_template:
value: "{{ trigger.event.data.gesture }}"
automation mi_magic_cube_2_event:
- alias: Mi Magic Cube 2 event
platform: event
event_data:
entity_id: input_text.mi_magic_2_event
data_template:
automation mi_magic_cube_2_gesture:
- alias: Mi Magic Cube 2 gesture
platform: event
event_data:
entity_id: input_text.mi_magic_2_gesture
data_template:
The second. How to create code which changes numbers to human text ie. 1 - Shaking etc.? Thank you
input_text
s has a _cube_
in their entity ids, but inside of an automations they are not.
Something like:
value: >-
{% if trigger.event.data.gesture == X %}
Sliding
{% elif trigger.event.data.gesture == Y %}
Shaking
{% elif trigger.event.data.gesture == Z %}
Dropping
{% else %}
etcetera...
{% endif %}
