[example] Indoor Air Quality text sensor using CCS811 sensor
only in rare cases when CCS811 has i2c 5B address instead 5A, but only changing letters
Hi @HFsi @Bouke_Regnerus @dhabib29,
I’m trying to set up my CCS811 sensor with ESPHome but I always recive the same errors:
Component ccs811.sensor was marked as failed.
Results from i2c bus scan:
Found no i2c devices!
Communication failed! Is the sensor connected?
This is the connection:
SDA => 21
SCL => 22
And this is the code:
esp32:
  board: nodemcu-32s
  framework:
    type: arduino
# Enable logging
logger:
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: true
  - platform: homeassistant
    entity_id: sensor.broadlink_ir_salon_temperature
    entity_id: sensor.broadlink_ir_salon_humidity
  - platform: ccs811
    eco2:
    tvoc:
    temperature: living_room_temperature
    humidity: living_room_humidity
    baseline: 0xD3BE
    address: 0x5A
    update_interval: 60s
Could you help me, please?
Do you have another I2C sensor to test it out?
Maybe some pin is dead
For future reference because I had the exact same error and it took me about an hour to figure out.
My CCS811 sensor needed the i2c Bus to be set to 400kHz via the “frequency” variable. Wasn’t mentioned anywhere in the docs and in the end I found it on the Amazon page in the product details section.
i2c:
  sda: GPIO21
  scl: GPIO22
  frequency: 400kHz
  scan: true
