Ty @Kermit
Its work well. I just adjust it to my needs.
@Kermit im trying to get work smthg like this⌠so far no success⌠is it possible at all this way?
(?:^switch\.laund_toide$|binary_sensor\.akenlwc_.+)
i love you
One more thing.
How to get notify about battery lever of entities by friendly name?
I mean i have 23 âbatteryâ sensors. how to use get entity to make me know what of them are low than 20% for example, bu using firndly name in notification?
I would love to have something like this too!
This was perfect, and exactly what I was looking for. Thanks heaps!!
isnât friendly name one of entity attributes? If so having access to entity object you should be able to use obj.attributes.friendly_name
Possibly itâs passed with a message too.
That is exactly what I use to check my battery devices. I use the device class property to get all the devices and friendly name property to exclude the specific devices I am not interested in (phones, tablets and Roomba). Works great.
https://zachowj.github.io/node-red-contrib-home-assistant-websocket/guide/jsonata.html
$entity().attributes.current_temperature
Am I missing something with the get entities and getting the contents of a group?
Nevermind, looks like I choose the wrong time to play with the code as there was a bug which was just resolved with the latest companion update.
Hi there!
Im ok with the Get entities node, its working well, but now i want to do this:
Get âwater_leakâ entities that are âwetâ and then send me a notification like this: "Attention theres a leak on âdevice xâ.
I need help in the notification âexpressionâ data part, to tell me exactly whats the device that detected water.
Can someone help?
Thank you!
example 1 shows you how to combine the friendly names
https://zachowj.github.io/node-red-contrib-home-assistant-websocket/node/get-entities.html#examples
I want to use the âget entitiesâ node to identify the entity that was last changed in a given (binary sensor) group. Is that possible?
Hi
const globalHomeAssistant = global.get('homeassistant');
const ha = globalHomeAssistant.homeAssistant;
const groupEntity = ha.states['group.person_home_away'];
Hey,
Iâm trying to do the following (someone shared the code here in the forum) Iâm trying to make an adjustment to my system,
Iâm trying to make Boolean receive an update who is at home,
Of course I have the group set, and also the Boolean of each person.
can you help
How do I get the same result as the template below in a function on node red?
{{states
| selectattr('entity_id', 'search', 'quarto')
| map(attribute='entity_id')
| reject('search', 'wifi')
| reject('search', 'ssid')
| list }}
regex: ^(?!.*wifi|.*ssid).*quarto.*
This! found this looking for a way to turn off all lights that are on. And of course, at the center of any higher level Node Red question, there is Kermit, spitting out answers like Ninja stars HAHA
Though I guess something has changed? Im getting this error with the âturn off lightâ node
âHomeAssistantError: not a valid value for dictionary value @ data[âentity_idâ]â I was using the one that has {{payload.entity_id}}
EDIT
This worked
{"entity_id": $join(payload.entity_id, ",")}
Kermit the Node Red Ninja
For anyone looking to get all lights that are on and turn them, off, this the one that works;
[{"id":"cd6fc2911452f914","type":"api-call-service","z":"4f47f2fd.a611fc","name":"Turn off Light","server":"d272ac3c.e0735","version":5,"debugenabled":true,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":[],"data":"{\"entity_id\": $join(payload.entity_id, \",\")}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","output_location":"","output_location_type":"none","x":630,"y":2740,"wires":[["571ea2756d3975fc"]]},{"id":"571ea2756d3975fc","type":"debug","z":"4f47f2fd.a611fc","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":780,"y":2580,"wires":[]},{"id":"25835b72.64f7a4","type":"ha-get-entities","z":"4f47f2fd.a611fc","name":"","server":"d272ac3c.e0735","version":1,"rules":[{"property":"entity_id","logic":"starts_with","value":"light.","valueType":"str"},{"property":"state","logic":"is","value":"on","valueType":"str"}],"outputType":"array","outputEmptyResults":false,"outputLocationType":"msg","outputLocation":"payload","outputResultsCount":1,"x":374,"y":2580,"wires":[["cd6fc2911452f914"]]},{"id":"295c21dc.5cb70e","type":"inject","z":"4f47f2fd.a611fc","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":2580,"wires":[["25835b72.64f7a4"]]},{"id":"d272ac3c.e0735","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
