Exchange Conbee 1 by version 2 or 3
Hey together,
I think about to exchange my old conbee 1 stick with a new one.
Is this an easy going?
Menas just plugout the old one and plugin the new?
Thanks.
My understanding with the Zigbee system is that the config / paring info is saved on your system rather than the Zigbee coordinator, so it should be a case of simply swapping them out.
(hopefully I haven’t got that mixed up with Z-Wave as I remember one of them has it saved on the stick, the other on the HA config. Should be easy enough to search the forum to confirm)
Thank you for the searching hint :wink:
Will do in that way.
Edit:
Did a quick search and found that:
https://www.reddit.com/r/homeassistant/comments/yjcvij/how_is_zigbee_and_zwave_network_stored/
So should be possible to just exchange.
In case you are using deCONZ, please consider this:
tl;dr
Wait for the release of deCONZ addon 2.24.x (currently: 2.22.2).
Sure, I read that there is currently an issue.
I only wan’t to know if it works in general.
Thanks.
