Unfortunately my switch is a (ZigBee) remote with programmable buttons. There´s no physical switch or “light state” I can detect and use. So I´m going to live with my current workaround for a while.
I don’t have Adaptive Lighting installed. But from the integration’s description, it’s not compatible with this blueprint. This blueprint monitors target entity’s state. So you are right, if other automation is changing the light’s brightness, this blueprint may not work. I will think about a solution if possible.
Regarding the original issue you mentioned, you can create a helper entity to mock the physical switch. Basically you need to create a input_booleanInput Boolean - Home Assistant, then use your zigbee remote to toggle this input_boolean. Then in the blueprint, use this as blocker_entity.
But I still don´t get it: what is the target_entity_state: '' ((Optional) Target Entity Desired State) for? Because it simply is NOT working as described in the blueprint:
→ That just don´t work. If it would work, I would not need to have the blocking entity. So I still believe something´s not working as intended/described/designed.
That would be awesome! Would reduce the complexity around the blueprint a lot (and I don´t think my usecase is that special, so others will benefit from such a solution too)
Sorry to bother you once again, but as I´m using this great blueprint more and more for different things in my home, I not only run into limitations or discover bugs but also imagine optimizations/feature enhancements, some by little to no cost. Here´s one:
Could you add the option to support (select/enter/use) multiple illuminance sensors?
I already experimented with a group but illuminance sensors are not supported according to domain list at Group - Home Assistant and therefore group value was “unknown”. And a second automation is neither smart nor trouble-free. So:
I have a valid use case for this and you have already implemented the basic feature for other parts of the blueprint, e. g. (OPTIONAL) Alternate Trigger Timeout. This could look like…
A) …when keeping the current structure:
B) …after merging (Optional) Illuminance Sensor and (Optional) Illuminance Below to one field (like already done with (OPTIONAL) Alternate Trigger Timeout):
→ The automation should work, if ANY of the listed illuminance sensors provided is below the corresponding value (sensor.illuminance1 below value1, sensor.illuminance2 below value2 and so on). I´d be happy to test that!
Nice But a) every sensor has its own cutoff value so just going for the lower one is not sufficient and b) why not have it in the blueprint so more people can use it (much more handy without templating and stuff)
Gotcha, but I didn’t say it shouldn’t be added. I was offering an alternative (albeit a bit different). I understand your main use case and it seems entirely valid.
You also mentioned groups and to me it seems the only way groups could work is if there is some rule to combine/fuse sensors (min, max, avg) — should the HA team see a need to implement such a feature for groups. I was thinking about this when I made my previous post.
Are you using the latest home assistant? If yes, you can go to the corresponding automation and click “show trace”. At the trigger layer click “show changed variables”, from there I can tell what conditions are not met.
It’s weird. Could you check the light’s state in Developer Tool in Home Assistant when it happens?
The trace info you posted showed the light.switch_kitchen_0x00158d00054408ee is already on
PROBLEM / BUG: Optional condition is not re-evaluated
Situation:
I have a trigger entity (presence sensor) and an illuminance sensor.
Problem:
automation is triggered on every trigger entity state change (good), BUT the illuminance sensor value is not re-evaluated anymore:
In detail:
It’s dark. I enter the room, light (target entity) is being turned on. Good.
Now after some time while still in the room and constantly triggering the automation (presence sensor/trigger entity) it’s getting bright so we jump over the illuminance sensor threshold.
BUT the light is still and stays on!
I need to either manually turn it off once or leave the room until the light gets turned off automatically (timeout).
After that, on next automation trigger the illuminance sensor value is correctly re-evaluated and light stays off.
So it looks like only the trigger entity is monitored OR the illuminance sensor is only used ONCE (on first automation trigger).
We could have a deeper look at this by diving into the automation trace logs but hopefully you can confirm and fix this without more data.
@kevinxw: Let me know if you need more information, consider this as a bug you can confirm or maybe something with my automation configuration is totally wrong.
This behavior is exactly what I expected. It make no sense to me that if a people enter a room when it’s dark, then the light got turned on so it’s no longer dark enough, and the light got turned off… you will find yourself in a loop of the “light on → light off → light on” situation.
This blueprint is great! Only thing I’d love to add, is being able to send data to the turn_on service. Specifically, I’d love to be able to set the brightness of the lights to a number which is derived from a calculation based off of my light sensor. So that when it’s very dark (middle of the night), it sets brightness to 10%, but when it’s just slightly dark, set it to 30%.
Something like (sensor.light_sensor.state / 10) * 3
OK. When I enter the room and it’s dark, light turns on. But NOW I
a) open the blinds or
b) switch on another light manually or
c) …
and it’s not dark anymore, but light is still on.
It also depends where you locate the illuminance sensor.
While I understand the basic deadlock situation, on the other hand there are use cases where it is annoying. Therefore I propose to add a „take optional brightness sensor into account“ option, turned off by default. If activated, entity is used together with trigger entity to decide if target entity will be changed.
Is it possible to implement this please @kevinxw ?
