I use the type: entities with state_color: true and entity: cover.garage_door. The up and down arrow for the buttons both enable. Is there a way to make the down arrow disable when garage door close and up arrow disable when garage door is open.
As per above.
Do you have a sensor to provide feedback of at least one position? (open or closed)
The sensor does provide the open and closed. All sensors are fine. It just the GUI I have problem with. I seen some sample HA GUI on the web the disable those up/down arrow base on the door status.
Show us your code for the cover:
This is in the lovelaceUI
- entity: cover.small_garage_door
name: Small Garage Door State
secondary_info: last-changed
icon: mdi:garage
I am using ESPHome. Here is the partial codes:
cover:
device_class: garage
name: “Small Garage Door”
lambda: !lambda |-
if (id(small_garage_reed).state) {
return COVER_OPEN;
} else {
return COVER_CLOSED;
open_action:Turn the OPEN switch on briefly
- switch.turn_on: small_garage_relay
- delay: 0.5s
- switch.turn_off: small_garage_relay
close_action: - switch.turn_on: small_garage_relay
- delay: 0.5s
stop_action: - switch.turn_on: small_garage_relay
- delay: 1s
optimistic: true
assumed_state: true
Thanks!
Can you confirm that the ESP is correctly receiving the open / close feedback?
Yes. I been using it to open and close and it also show the status of garage door open or close. I just want the arrow up and down icon to disable if garage door is close the down arrow icon should be disable or hide.
I realise that is what you want, and that is supposed to work which is why I’m trying to help you figure out why it isn’t.
This is all I have for my garage door in Lovelace:
type: entities
entities:
- entity: cover.garage_door
show_header_toggle: false
…and it behaves as you describe:
This is why I wanted you to confirm that the open/close position feedback is working because without it, HA and therefore the card will not be able to display the position status
The difference between us is that I use a template cover vs you using ESPhome. It seems that maybe the status (for showing the correct symbols) is dealt with differently.
I use your sample lovelace file
Both up and down arrows is enable.
Can you show me your configuration esphome file to see what is the differences between mine?
Thank you
I don’t use ESPhome for my garage door, my config is done with an MQTT cover using data from an alarm system
