@andriej Andriej, you found the community guide already, but perhaps we could discuss your specific questions here…
You can set a max file size and implement log rotation for your rsyslog files.
You can also check your current journalctl size, and restrict that if necessary.
journalctl --disk-usage : check current disk usage
journalctl --vacuum-size=1GB : clean up and reduce size to 1GB
journalctl --vacuum-time=1w : remove all messages prior to the past week
Home Assistant makes use of the journald log driver, and to my understanding we can’t change this. But you can configure how the journald messages are parsed and written to the files in /var/log.
The Supervisor log level can be set from the command line using the HA CLI. So if you don’t care for all those debug and info messages, you can start by filtering them out by changing the Supervisor log level to e.g. “warning” or “error”.
# Change hassio_supervisor log level
ha supervisor options -l warning
If you want to change the log level of homeassistant it can/must be done in configuration.yaml using the Logger configuration:
logger:
default: critical
logs:
# log level for HA core
homeassistant.core: fatal
The messages in journald are by default split out to different log files based on the configuration in /etc/rsyslog.conf. Eliminating duplication can be done rather easily by changing this file (and then restarting rsyslog).
The duplication and how to change/prevent it is explained in the E. rsyslog section of the community guide. Because rsyslog by itself is OS-specific (operating system) and not directly related to Home Assistant, you can find many articles on internet how it can be configured, starting with the RSyslog official website.
First concern here is that unfortunately Home Assistant logs ALL messages as errors, even debug and info messages. This makes journald and rsyslog filtering on log level impossible.
To filter out specific messages you need a reliable handle that can be used to identify them uniquely, without filtering out wanted messages by mistake. You could add a new rsyslog filter by adding up a combination of filters that accurately identifies your unwanted messages:
# Ignore all messages containing <string a> and not containing <string b>.
if ($msg contains "string a") and not ($msg contains "string b") then { stop }
I assume you already tried to filter the logging for these addons using the HA Logger settings in configuration.yaml?
