True true, however it seems like --include doesn’t work on the version included with HassIO
Result (it's long)
➜ /config git:(master) ✗ grep -r --include='*.yaml' device: .
grep: unrecognized option: include=*.yaml
BusyBox v1.28.4 (2018-12-06 15:13:21 UTC) multi-call binary.
Usage: grep [-HhnlLoqvsriwFE] [-m N] [-A/B/C N] PATTERN/-e PATTERN.../-f FILE [FILE]...
Search for PATTERN in FILEs (or stdin)
-H Add 'filename:' prefix
-h Do not add 'filename:' prefix
-n Add 'line_no:' prefix
-l Show only names of files that match
-L Show only names of files that don't match
-c Show only count of matching lines
-o Show only the matching part of line
-q Quiet. Return 0 if PATTERN is found, 1 otherwise
-v Select non-matching lines
-s Suppress open and read errors
-r Recurse
-i Ignore case
-w Match whole words only
-x Match whole lines only
-F PATTERN is a literal (not regexp)
-E PATTERN is an extended regexp
-m N Match up to N times per file
-A N Print N lines of trailing context
-B N Print N lines of leading context
-C N Same as '-A N -B N'
-e PTRN Pattern to match
-f FILE Read pattern from file
Just kidding. (Well, …) Actually I’m sure there must be good reasons for it, but I’ve never gone down that path, and I’m happy I never did. I guess you don’t miss what you don’t know, and I’ve just seen it make it hard to do simple things.
I ended up clearing my MQTT persistence DB. Did the trick. HA should make the error clearer, though. I spent a fair amount of time trying to figure it out by trial and error. Especially if it’s some sort of thing that will break things later.
Here’s script I found somewhere that worked beautifully.
That’s probably because the lines weren’t properly formatted in the post. I don’t use mqtt, but I would assume this (just fixing the double-quote characters):
@maurizio53 Edit: Missed the fist message. You have to put your HA IP address on the command line. i.e. “./cleanmqtt.sh localhost” assuming you called the script “cleanmqtt.sh”.
Also, try stopping HA and removing old entries from .storage/core.entity_registry. I did have a few old locks in there that I removed as well.
@nickrout I have setup mqtt discovery and dafang picks it up and communicates with my HA i.e. without the need to have the mqtt component setup in my configuration.yaml.
I am running everything in docker including mqtt and HA.
How do I resolve this issue?:
WARNING (MainThread) [homeassistant.helpers.config_validation] Your configuration contains extra keys that the platform does not support.
Please remove [device].
I also have a similar one to the above and its for icon.
Please remove [icon].
Ok i did it and this is what i get in the terminal:
Error: Invalid input. Does your topic contain '+' or '#'?
Error: Invalid publish topic 'G0JUZAYkWAcLdlNNCSAsM1QGX38+RG8XAgBMAB4qV05WTiNOGhoxBDNFIS0zWA5CJgMfWlcfOksb', does it contain '+' or '#'?
Use 'mosquitto_pub --help' to see usage.
Error: Invalid publish topic 'ESgoUU5+PiRFCA0/AAENEDEzUBpfMBJJCQlEUAlFQX0JBTNRaAVFTCQbCgwqMCJfC042PQZCTAU6', does it contain '+' or '#'?
Error: Invalid publish topic 'BSRNEB4rY0l4BDFaS1R2XE1GbREGfDt+CyVLYFEWC1ESHidRU35BHVgdBzsHTzkqLDReGgl/BApf', does it contain '+' or '#'?
Error: Invalid publish topic 'SxRJGhMSKlVPaw0PRB0PJh0wGSowMVgLTjY9GEpLBQBVKwQwUU9+FCAVUxomHApGbTEiXwxpJBYf', does it contain '+' or '#'?
Error: Invalid publish topic 'Dh8aFAFRACgwVUV+PiBeChohGwo1JiwzVBpdJA5JCRpHVRpYVTRCWGwEIlIHDTEaMB4uKSJuGEIm', does it contain '+' or '#'?
Error: Invalid publish topic 'CScdMVAEXiA+SQlkUzkaWCtmXVx+AjhoHRckDDNIdXJrbUpYLQ0cfVcFDF4dFCVEVGUPDBVTGiYc', does it contain '+' or '#'?
Error: Invalid publish topic 'CkYTYCleHEIjCwhSTBgKVicYMV5ZVkNqa0sNOwcbDyE2fW00d2o+N28XAgBMAB4qV05WPQwYGhcn', does it contain '+' or '#'?
Error: Invalid publish topic 'RAxCCEsDCzw2EVAEXiA+SQlkUzkaWCtmXFx5FQVHDQ8gDDNIdXNyBV4TclJdBgpCVQpYK2ZZTk8P', does it contain '+' or '#'?
Error: Invalid publish topic 'FChVN1FEVkNqUQgCJwwSRhNgdW1KET4+SVpcLUcCRlsYElNrDDVrS1QISxweLjYyQjQJaT5JWksi', does it contain '+' or '#'?
Error: Invalid publish topic 'NAkjCwdWaBARUChVfmwfVkN8a0sYOwAMDwwtKlwJRSE+SQlkUzkaWCtmQFxzDT9WDSgmBgI8ICsk', does it contain '+' or '#'?
Error: Invalid publish topic 'CEtVWH5uGxMERCsFAkdNFQBkVk11AxM+UmABXldgRTNIIyMzWBxeIQc3EQJFVxZEQ3MCCDxUfGtL', does it contain '+' or '#'?
Error: Invalid publish topic 'WxUDLV9TVQA+UxsBPQ1NUDswMlRECSAMClFUFCNxOjNmCltrDSNSRUwnDAEOCDI0fQdIJBYCXFZT', does it contain '+' or '#'?
Error: Invalid publish topic 'SgcASisHK0JJKFtyBlFWZ0tDSDktLlINaCoPBlJWFTFsJ1V+VlxmEjUbSws5HAMLOycIRgZfNwMI', does it contain '+' or '#'?
Error: Invalid publish topic 'Xl0tRwIoVQBVS2MCNRcgADIGM0hjHmVYG3g8ER9WVS1HAhIWKENYJj1yWwgdID8OBjonGxNSd2c+', does it contain '+' or '#'?
Error: Invalid publish topic 'HkopFw5vGks5GihVaGwfZwAkVAExIBAfDxNgfQFEd2cRA1xPPwpMHREtU1x+CD9ZNUxuHR0fKm4b', does it contain '+' or '#'?
Error: Invalid publish topic 'NiZYBk4hPkkJXhAJSxFbGBJNaxg8WAgKCEtVNm0eZR00CSMLB1ZoEBFQKFV+bB9WQ3xrSxg7AAwP', does it contain '+' or '#'?
Error: Invalid publish topic 'CQsjMSIdNAkpAxhHbhAJTRErZgphKD1yGzVMOAgcHhoyI1AcThlAUQINQlUMQUB3AQ0+V2gbNUw9', does it contain '+' or '#'?
Error: Invalid publish topic 'Dj5+CgE6NU1QE2AbE0R3ZwsYYV0FBFEaEiBsHzAHMVsaC3g1TRouOyteCU8ZQFFvGi1HFChVIllR', does it contain '+' or '#'?
Error: Invalid publish topic 'azs5GBIHfhMlUkUydiM8JQEJIkg0CX8+SW8aXTkaGRYwU1VVFzFbHAsIS1U2bR5lHTQJKAMfUFAu', does it contain '+' or '#'?
Error: Invalid publish topic 'LUdbGxkwVVN+WwxrNUEINTNFPCczRQFFIhE3b2ReFkEHAyFdYVY9f1kGGj0PBgkuNi5eBnQ2DR5d', does it contain '+' or '#'?
Error: Invalid publish topic 'XFkVORpOK2ZsHyY9clEAAjE5Dh4nHmULNAkZQEdvGgcKURcSB19QZwA+UzVMbjVNNm1uGxMYSjwO', does it contain '+' or '#'?
Error: Invalid publish topic 'fFBFAg5JSwlaRX0SESgMIUMdMScMHRwqMBhEG043QFERUB4IXRUEN1lOfgA+Q0tCdgUOGTsAMlgE', does it contain '+' or '#'?
Error: Invalid publish topic 'VwlHNgdHEV8BFnUdGS1dSGclOUQdDzoKCkh1YHYBSgdnEQ5dXDYVSzgYJ1FJYw4+FVMaJhwKRm0n', does it contain '+' or '#'?
Error: Invalid publish topic 'KVAKRyAhCl5dAwQaTgM2RVgmQyNSGxg9Cgo1IyM0RTdfNwMIWFEfAmcHAyVCSX8Rcg1YW2FZVlJ+', does it contain '+' or '#'?
Error: Invalid publish topic 'eQQ+UzYdORowBCA2LlcBSCQWAlxWLgRWEAUrWVkoWyRFHAt4SwIbOzYYQg1ZMwcZbEgQFksDGDZU', does it contain '+' or '#'?
Error: Invalid publish topic 'SU5+BD1rRg84CB0HECMrVBpfZ05JQ0oUA10GEipTWHk+OFIIHCALCgs7YH1XCUc2B0cRVRAVSysV', does it contain '+' or '#'?
Error: Invalid publish topic 'AFkGAyZVXH4+OVkdCyYfDgZteGUIWAlpQBhEUQUGUCAWL1VtYwIkQhsLJ0tVDC4uNFRECTUQDlVd', does it contain '+' or '#'?
