Extra keys not allowed @ data['min']
Getting there but looks like a problem with the set command as nothing happens when changing the value and it doesn’t log anything either.
I think this might not be working as expected:
rest_command:
  openevse_rapi:
    method: post
    timeout: 30
    username: !secret OPENEVSE_USERNAME
    password: !secret OPENEVSE_PASSWORD
    url: "{{ url | default('http://' ~ host ~ '/r?json=1&rapi=' ~ rapi, true) }}"
Essentially the set above should create a url like so:
http://192.168.0.100/r?rapi=%24SC+10 as when I run this in my browser it actually applies the changes. The 10 is the value I can pass in from that number template just created.
I just looked at your script and you had errors, updated the post
No luck, I think the rest_command is just not executing or at least not applying.
And this should lose the last part
set_value:
      - service: rest_command.openevse_rapi
          host: !secret OPENEVSE_HOST
          rapi: >
            $SC {{ value }} {{ '' if is_state('input_boolean.openevse_save_current', 'on') else 'V' }}
and become
set_value:
          rapi: >
            $SC {{ value }}
According to GitHub - OpenEVSE/ESP8266_WiFi_v2.x: ESP8266 WiFi for OpenEVSE Version 2.x at least.
Ok figured out the issue, it’s a GET instead of POST even though the official docs above say it’s a POST :man_facepalming:
Almost done but, I am not seeing the value change on the UI.
So I change the value by dragging here and you can see behind it still shows 16 even though it was changed to 11 successfully.
Any idea why?
because it gets it’s state from
Correct and it looks like that value is the max value not the current one.
The correct value can be seen in this sensor here, the 13:
Any idea how to set the value of the number template to that?
did you make the min/max tempaltes?
No but they are also not needed, I set them to min 6 and max 16.
I believe this should do the trick for the state to give me that 3rd number:
{% set val = states('sensor.openevse_rapi_gc').split(' ')[3] %}
{{ val }}
Final result:
template:
- number:
  - unique_id: openevse_max_current
    step: 1
    state: >
      {{ val }}
    availability: "{{  states('sensor.openevse_rapi_gc') not in ['unavailable','unknown'] }}"
    min: 6
    max: 16
    set_value:
          rapi: >
            $SC {{ value|int }}
And all works as expected, many thanks for the assist.
