Hey everyone, hoping for some feedback on this new feature I’ve been working on before I push a beta build.
To make this application more secure, I wanted to add basic authentication to it. This would allow users to safely run it behind a reverse proxy as well. I was going to have it enabled by default, unless others thing it shouldn’t be. It’s easy to turn off if you want as well.
Authentication Features:
Requires password to be set before using
All API routes except login require an JWT authorization token or long term access token to be passed
MQTT payloads will include a token that will allow HA notifications to still render the image
Ability to create / delete long term access tokens
Ability to disable authentication all together by adding auth: false to the config.yml
Hey, thank you for the kind words. I’m glad you are finding it useful. The face detection limits would probably vary depending on which detector you are using. To my knowledge only Facebox has some limits for how many faces you can train. CompreFace and Deepstack don’t have any limits to my knowledge.
Here’s a sample image I processed with a bunch of people to show it can handle more than just a couple faces.
thanks jako for replying me
I am very satisfied with this system
i only use frigate and compreface-fe i dont use deepstack
identification results are quite fast
I got Double Take up and running this week. This is one of the most underrated developments in progressing forward AI / facial detection. The GUI is just incredible and elegant, it’s very refreshing to see in the HA ecosystem.
I agree, unfortunately I can’t get deepstack to actually do a decent job at recognizing faces.
I’ve trained it with high quality images but it doesn’t match them up with what’s seen by the camera.
Hey @stizzi, thank you for the kind words. I’m glad you are enjoying the project. Please reach out if you ever run into any issues or have a feature request.
hello do you have a way for compreface-fe . system
Does it run automatically after every shutdown or power failure?
I have to go to portainer to run it manually. there are a lot of software that run automatically when power is restored
@Cao_Hoa make sure in your compose files you have restart: unless-stopped set for the containers you want to start back up. That should solve your issues during power failures / reboots.
Agreed! Double Take is awesome but I have been suitably unimpressed by Deepstack. Have trained it with 30+ high-res images and it still thinks the gf is me and I am her about 80% of the time, rendering the whole thing pretty unusable.
I tried installing Compareface but had some issues getting the container to work and gave up. Will need to give it another go and see if I can get better results that way…
thanks jako it worked for me
I like it very much it received very fast and accurate
did you create additional sensor binary_sensor
for homeassistant .because i find it fast but
If I go in and out, it doesn’t output and automate
inactive.have a nice day
Hey guys, can someone help me automate this?
when it detects a trained face play a music
When it can’t play, play another song
i did the following automation: when calling the test service there is only the track
the face doesn’t know how to play music and the other faces can’t
no music is playing
@Jako Is it possible to re-run matching to an image under Matches?
For example, I have an image that seems to be clear but it doesn’t currently match.
If I upload and Train a new image for that person, I’d like to see if the selected image in the Match view would match with the newly added Trained image.
Hey @surge919, I know we chatted on discord about this, but wanted to also post an update here since I pushed a new feature to the UI to help with this.
Here’s a little gif demonstrating how I’m handling the reprocessing of the images. Currently you have to do it on an image by image basis. There is a button in the bottom right of every match image. Clicking this will reprocess that image and update the results.
In this gif you can see the first image was for an unknown user. I train it for myself, then reprocess the image to show it has the updated results.
