Apologies for resurrecting this topic, but is this custom component still a working solution 2.5 years later?
I’ve finally updated my Home Assistant and have also updated the code in the repo to work with the newer versions ( 2023.11.3).
This is great, thank you. I’m also running a setup with just one magnetic reed sensor for closed and with your component I’ve got this faking the opening and closing status.
This is the code that I’m using:
cover:
- platform: pcc
covers:
garage_door:
device_class: garage
friendly_name: "Garage Door"
unique_id: garage_door_cover
# travelling_time_down: 17 #not needed with closed sensor
travelling_time_up: 15
value_template: >-
{{ is_state('binary_sensor.garage_door_garage_door_contact', 'on') }}
open_cover:
service: switch.turn_on
entity_id: switch.garage_door_trigger
close_cover:
service: switch.turn_off
stop_cover:
Two things that I’ve noticed:
- While home assistant is booting, the cover shows as
openwhilebinary_sensor.garage_door_garage_door_contactisunavailable. I would have thought the template would return false in that condition. travelling_time_up: 15seems to overridevalue_template:- I can see this by closing the door shortly after opening it. The state stays asopeningfor the full 15 seconds, then goes straight to closed.
Great custom component, maybe this can be done with the template platform but I wasn’t able to achieve it - thankyou
For anyone using this in late 2024. ( me, I just started using it. =) )
Noted that when I tried to use it the PCC-entity was not created.
Found in the logs that it had some deprecation warnings and was not thread safe.
Created a pull request that solves these issues and now the entity is created successfully.
Removed SUPPORT_* will be deprecaded in 2025 warning
Note: There is still a unfixed issue when restarting HA that I did not solve (noted in the pull req).
How would I make use of the opening / closing state in a cover template? Template cover - Home Assistant
I do have a MotionBlind in use, unfortunately it only reports the states open / close along with the current position. opening/closing are not reported.
My goald would be to show the state “closing” when it goes from 100% do anything lower and reaches the set position for x-amount of seconds.
And vice versa, for “opening”.
Any ideas?
Start by testing if changing the entity’s Show as to Window. This option is available by selecting the entity in Devices & Services then clicking the gear in the top right corner.
That would have been a neat fix! Unfortunatley, no change, still reporting open/close but not opening/closing… Will need to start looking at the value_template documentation, I think that “last_updated” of the entity can be used, but will need to investigate more deeply. What would be great if there is a way to easily-judge if the attribute-value is decreasing or increasing in a template (without a helper)
You’ll have to follow this for that option
value_template template (Optional)
Defines a template to get the state of the cover. Valid output values from the template are open, opening, closing and closed which are directly mapped to the corresponding states. In addition, true is valid as a synonym to open and false as a synonym to closed. If both a value_template and a position_template are specified, only opening and closing are set from the value_template. If the template produces a None value the state will be set to unknown.
In an admittedly over-ambitious attempt to make this work with the latest version of Home Assistant, I’ve updated my fork of PCC that can now be added directly via HACS.
Once installed, you can add it through Integrations and still define your own templates for it.
Check it out here: GitHub - Caine72/pcc-cover: Home Assistant custom components
Hi Caine,
thank you very much for your effort!!!
I’m still new to HA and I’m struggeling a bit…
May you have a short tip for me?
I have a shelly device with one reed contact (like above).
After integration of PCC via your github link i was wondering if i have to add for all (open_cover, close_cover, stop_cover) the same shelly switch (using toggle button) and at the end: what value_template are you using?
Thanks a lot in advance!
Hi!
Happy I could help out in some way! =)
Oh! … I do realize now one cannot go back and re-open the config one has created for the entry. That is not optimal… Need to revisit that. ![]()
To answer your question:
No, you do not. It is only if you want/need to trigger some certain action for stopping.
Myself I only use Up and Down, not Stop.
So, as I cannot see (or validate) my exact config this is from memory. But it should provide you with the what I did.
Template: {{ 'true' if is_state('binary_sensor.garage_door', 'on') else 'false' }}
Open Action: switch.turn_on
Entity_id: switch.garage_door
Close Action: switch.turn_on
Then I have a travel up/down time of 25 seconds.
