not sure, try it from the command line. But it looks promising.
Works from the command line as well. Even without running the virtualenv, so I don’t know how it works.
$ python
Python 3.5.2+ (default, Sep 22 2016, 12:18:14)
[GCC 6.2.0 20160927] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> from homeassistant.util import location
>>> def loadHAconfig():
... haConfig={}
... locinfo=location.detect_location_info()
... haConfig["IP"]=locinfo.ip
... haConfig["country_code"]=locinfo.country_code
... haConfig["country_name"]=locinfo.country_name
... haConfig["region_code"]=locinfo.region_code
... haConfig["region_name"]=locinfo.region_name
... haConfig["city"]=locinfo.city
... haConfig["zip_code"]=locinfo.zip_code
... haConfig["time_zone"]=locinfo.time_zone
... haConfig["latitude"]=locinfo.latitude
... haConfig["longitude"]=locinfo.longitude
... haConfig["metric"]=locinfo.use_metric
... return haConfig
>>> hainfo=loadHAconfig()
>>> print("hainfo={}".format(hainfo))
hainfo={correct result redacted}
Edit:
I found I had the location of homeassistant in my PATH environmental variable. If I take that out, I get
graham@lubuntu1610-VirtualBox:~
$ export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
$ python
Python 2.7.12+ (default, Sep 17 2016, 12:08:02)
[GCC 6.2.0 20160914] on linux2
File "<stdin>", line 1, in <module>
ImportError: No module named homeassistant.util
thanks,
I’m trying to understand the common thread why its in some people’s path and not in others. Did you do the manual install into the virtual environment?
Yes, its just a test box, not running as a special user.
Edit:
So I tried it on my working Pi.
homeassistant@raspberrypi:~ $ python
Python 2.7.9 (default, Sep 17 2016, 20:26:04)
[GCC 4.9.2] on linux2
homeassistant@raspberrypi:~ $ set -o vi
homeassistant@raspberrypi:~ $ source /srv/homeassistant/bin/activate
(homeassistant) homeassistant@raspberrypi:~ $ python
Python 3.4.2 (default, Oct 19 2014, 13:31:11)
[GCC 4.9.1] on linux
So it has to be within the virtualenv to work. And as with my test machine, both appdaemon and homeassistant are in the same virtualenv.
Virtual Environments - would be my guess.
A lot of users (AIO included) install HA in a virtual environment. That means it is not visible from AppDaemon’s environment.
I should have spotted this when you were previously asking about this error.
It’s a mute point now really since I see you are giving me the infromation in AD now.
Well since you are my power user number 2 along with Rene, I take your requests seriously!
