I have a Nilan Compact P GEO3 and I’m trying to set everything up. The Nilan is connected to my network and I’m using TCP modbus. The registers that are in the code of Jakob Moll work, but I’m trying to add others like CO2 (register 4712), floor temperature setpoint (T18, register 5169) and others. CO2 and T18 both return 0.
EDIT: The CO2 sensor is an option that I probably don’t have. The floor tmperature setpoint is on slave 4 instead of slave 1. So this is solved! Below you can see my correct config.
stream:
modbus:
- name: nilanmodbus
type: tcp
host: 192.168.0.254
port: 502
sensors:
- name: nilan_floor_temperature_setpoint
unit_of_measurement: '°C'
slave: 4
address: 5169
scale: 0.1
count: 1
data_type: int
- name: nilan_humidity
unit_of_measurement: '%'
slave: 1
address: 4716
I have another question:
I can’t seem to change any values. For example the air temperature setpoint. Below you can see the config of that one. When I add that entity as a card on my dashboard, I can’t change it. Any idea on how to do that?
EDIT: also solved. See below how I did this. This allows me to put a slider. The slider is not set automatically to the right value at start so I should find a way to do that.
automation:
- id: Ventilation_speed
alias: Ventilation speed
platform: state
entity_id: input_number.slider1
service: modbus.write_register
data_template:
hub: nilanmodbus
unit: 1
address: 4747
value: "{{ states.input_number.slider1.state|int }}"
- id: Room_temperature
alias: Room temperature
platform: state
entity_id: input_number.setpoint_room
data_template:
hub: nilanmodbus
unit: 1
address: 4746
value: "{{ states.input_number.setpoint_room.state|int * 10 }}"
input_number:
slider1:
initial: 25
min: 20
max: 100
step: 1
setpoint_room:
name: Room temperature
min: 18
max: 26
step: 1
There are broken links in this thread to the nilan modbus documentation. This is a link that does work atm: https://symlink.dk/stuff/CTS700_MODBUS-rev%202.01.pdf
This is what my cards look like now:
You can see three different temps for the floor, I’m not sure what each one means yet (T16 temp before condensor, T17 temperature flow outdoor unit and T18 supply temp central heating)
