Hi, I’ve made an integration for Nilan, take a look at GitHub - veista/nilan: Nilan integration for Home Assistant
…and I’ve made an integration for the older CTS600 controller: GitHub - frodef/nilan-cts600-homeassistant: Home Assistant integration for Nilan ventilation units with CTS600 controller.
Hi.
Nice card. Did you make it your selv or did you find it somewhere. I would very much like to ad i to my own dashboard.
Kind regards
Christian
Hi Jakob ,
I am trying to make my Nilan Compact P with C700 work in Home Assistant. But when i add your code to my configuration.yaml i get errors on all the data_type: int lines.
Has anybody else experienced that, and do you have an idea of what i may be doing wrong?
Best regards,
Kasper
Try this : Jopand · GitHub
I’m using this code in esphome
An updated code, matching at Home Assistant 2024.9.3 is here:
I’ve moved away from the custom configuration for the temperature, and are now using the modbus climate entity for managing heat, fan and set temperature
