Fixed with 91.0! FFmpeg isn't running! hass.io
I have a problem with setting up my onvif camera. I’m running hass.io and added this to my configuration
ffmpeg:
camera:
  - platform: onvif
    host: 192.168.0.85
    username: USERNAME
    password: PASSWORD
    port: 8080
Now I’m getting this error message
2019-01-17 21:22:50 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running!
On the component site (https://www.home-assistant.io/components/ffmpeg/) i read this:
If you are using Hass.io then just move forward to the configuration as all requirements are already fulfilled.
So I can’t figure out what’s wrong with my configuration
Hi. I am having exactly this same issue. Just added ffmpeg: to the config, but got the same error message.
Running 0.84.6
Same issue here
any traction on this issue? I’m facing it as well
Hi
Same issue.
after updating to the version 0.88.1
camera YI
Same issue here; hasn’t worked for me in some time.
same here, FFmpeg isn’t running, didn’t ever got it working
this works for me with a Wansview W2
platform: ffmpeg
input: rtsp://user:password@ip:554/live/ch0
Well since 91.0 it is working like a charm!
Seems it was fixed with it!
