That’s a shame, I’m not familiar for LimitlessLED.
How does HomeAssistsnt communicate with them? via a gateway over IP? Might just be a latency thing?
Is there any firmware out there that lets you flash the bulb to connect directly to WiFi? Do the bulbs communicate with the gateway/remote via WiFi?
Just had a look at the product page and interested to see GU10’s I need a RGB GU10 solution for my kitchen and AILight only compatible with E27 Screw bulbs at the moment.
the communication is handled over a server hub device, I am using the v3 version of the hub. The current version is 6, it might have a better chance with the dimming scripts/system. I am not sure.
I also have the limitlessled component on homebridge. In that package the delay and repetition can be entered in the configuration. That same functionality if it were available here in homeassistant too, might do the trick. As before just speculating here.
I have v4 limitlessled and haven’t been able to get this working either, I assumed I’d made a mistake in copying the code somewhere, thanks for posting that @sendorm
I also have lifx and xiaomi philips bulbs so might give it a shot with those instead. I was just trying to get it working on one bulb first before mass replicating.
Not all smart bulbs are as good at handling a steam of brightness change requests,
I just received a colour yeelight yesterday from China, and I found it was not as responsive to successive brightness changes as my hue bulbs.
How did you connect the button to HA, did you use a zigbee receiver or the xiaomi gateway?
I’m using a gateway
Hi, I’m very new with home assistant, and I’m very confused with the syntax, on one side you need to make a Jason template you use the configuration tools how ever, you use yaml on the configuration and not everything is supported through the configuration assistant.
Anyways, I want to use your script, and I can’t find a way to make work beacuse I don’t know how to translate it to the new “automation”, “script” files syntax.
any help how to will be appreciated.
also, I want to add that I have some simple automation working turning on and off light
Note: running Home Assistant v0.57.3 Docker Container on Synology NAS
For all of those yaml noob - like me, I have created package for this automation.
Here is what you have to do:
In your config folder you can create a packages folder, and add this entry in your configuration.yaml:
packages: !include_dir_named packages
Here is the configuration.yaml example .- !include_dir_named packages` has to be under homeassistant!
homeassistant:
latitude: !secret lat
longitude: !secret long
elevation: 110
unit_system: metric
time_zone: Europe/Zagreb
customize: !include customize.yaml
inside packages folder create new yaml file for example dim_light.yaml, and copy this in there
automation:
- alias: xiaomi brighten on
initial_state: 'on'
- platform: event
event_type: click
event_data:
entity_id: binary_sensor.switch_YOURSENSORID
click_type: long_click_press
condition:
condition: and
conditions:
- condition: state
entity_id: input_boolean.rgb_dim
state: 'off'
- condition: state
entity_id: light.YOURLIGHT
state: 'on'
- service: script.turn_on
entity_id: script.brighten_rgb_traka
- alias: xiaomi brighten off
initial_state: 'on'
- platform: state
to: 'off'
condition:
condition: and
conditions:
- condition: state
state: 'off'
- condition: state
state: 'on'
- alias: xiaomi dim on
initial_state: 'on'
- platform: event
event_type: click
event_data:
condition:
condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'on'
entity_id: script.dim_rgb_traka
- alias: xiaomi dim off
initial_state: 'on'
- platform: state
to: 'off'
condition:
condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'on'
- service: input_boolean.turn_off
script:
dim_rgb_traka:
sequence:
- condition: state
state: 'on'
- service: light.turn_on
data_template:
brightness: '{{states.light.YOURLIGHT.attributes.brightness - 10}}'
- service: script.turn_off
brighten_rgb_traka:
sequence:
- condition: state
state: 'off'
data_template:
brightness: '{{states.light.YOURLIGHT.attributes.brightness + 10}}'
input_boolean:
rgb_dim:
name: RGB traka Dim
initial: off
Just replace:
YOURSENSORID with - your sensor ID
light.YOURLIGHT with your light.entity_id
Thanks a lot for this thread, got it working after a little bit of troubleshooting - trying it on a yeelight strip gave this error:
(MainThread) [homeassistant.core] Invalid service data for light.turn_on: expected int for dictionary value @ data['brightness']. Got '245.0'
A little bit of searching found this thread with a solution that worked:
{{ (states.light.kitchen_light_1.attributes.brightness | round(0)) - 25 }}
Hope this can help any other confused newbies like me
Is there any possibility to set a max and min value?
If I dim down to long my 0-10 switch will be recognized as off in HASS and I cant dim it up until I shut it off and on again…
brightness: ‘{{states.light.YOURLIGHT.attributes.brightness - 10}}’
If you could set the minimum value for that?
Thanks mate, really nice script
I have the same problem!
Going to give this a try now… my only problem is that i actually have 2 lights and 2 switches… i’m guessing i’ll need to put this in twice and change quite a lot of it to keep things unique?
brightness: >- {% if states.light.stand.attributes.brightness > 10 %} {{states.light.stand.attributes.brightness - 10}} {% else %} {{ 10 }} {% endif %}
this will work!
Hi there, can some one help me with this? I’m not able to dim the light, it work only one time…
automation:
- id: comodino_andrea_brighten_on
alias: Comodino Andrea brighten on
initial_state: 'on'
- platform: event
event_type: click
event_data:
entity_id: binary_sensor.switch_158d00012641b4
condition:
condition: and
conditions:
- condition: state
entity_id: input_boolean.comodino_andrea_dim
state: 'off'
- condition: state
entity_id: light.comodino_andrea
state: 'on'
entity_id: script.brighten_comodino_andrea
- id: comodino_andrea_brighten_off
alias: Comodino Andrea brighten off
initial_state: 'on'
- platform: state
to: 'off'
condition:
condition: and
conditions:
- condition: state
state: 'off'
- condition: state
state: 'on'
- id: comodino_andrea_dim_on
alias: Comodino Andrea dim on
initial_state: 'on'
- platform: event
event_type: click
event_data:
condition:
condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'on'
entity_id: script.dim_comodino_andrea
- id: comodino_andrea_dim_off
alias: Comodino Andrea dim off
initial_state: 'on'
- platform: state
to: 'off'
condition:
condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'on'
script:
dim_comodino_andrea:
sequence:
- condition: state
state: 'on'
data_template:
brightness: '>-
{% if states.light.comodino_andrea.attributes.brightness > 10 %}
{{states.light.comodino_andrea.attributes.brightness - 10}}
{% else %}
{{ 10 }}
{% endif %}'
brighten_comodino_andrea:
sequence:
- condition: state
state: 'off'
data_template:
brightness: '{{states.light.comodino_andrea.attributes.brightness + 10}}'
input_boolean:
comodino_andrea_dim:
name: Comodino Andrea Dim
initial: off
The problem starts with sram bulbs, with hue everything is working. Maybe sram lightly doesn’t play well with dimming?!
I love packages @INTEL! It’s really a nice way of including new smart features in HASS without messing around in several different configurations files.
However, I can’t get your package to work.
I’m trying to dim a Z-Wave ligh included through a Vera. Maybe this way of using Xiaomi switches only works for light devices directly included in HASS that have the dim feature?
Glad I could help
If your lights or component you are using doesn’t support dim, you cannot use this.
The lights are of course dimmable! I’ve added the package as written and switched the parts with my own devices. However, nothing happens when I press the button. If I turn on the dimmable light and long press the light dim down to 0%. If I press again it never turn on or dim up.
