I hope so, but I’m suspecting he’ll kill the plm devices and focus on extend the hubs versions to better response.
After connect my plm to HA I programmed with houseLinc and I can’t understand why they discontinued a really good software like that. The scene triggering was perfect, the sinc too.
If HA can work like the HouseLinc in time of response was perfect.
Hate to resurrect an older thread but…
I am new to HA and have SwitchLinc Dimmer (Dual Band) 2477D. My PLM is 2413S. What I’ve just noticed is that if the switch brightness is manually set at the dimmer, the new status is not reflected in HA. Is this correct functionality for 2477D & 2413S & HA???
Thank you for responding but no, I do not have a favorite on level set up in a dimmer. If I toggle the light on at the switch, it ramps up to 100% and HA shows On, 100%. If I then dim the light at the switch, HA still shows On, 100%.
Also alternatively, if I turn on the light from HA and set it to 25% from HA and then change the brightness at the switch to 75%, HA still shows On, 25%.
I ran the service: insteon.add_default_links but same behaviour.
I stopped ha, deleted the database and restarted ha and insteon rebuilt the database but same behaviour.
It’s as if the 2477D does not report a brightness change to the controller…
