If will fail because the for-loop will attempt to access a list item that doesn’t exist.
You can use the count or length filter to get the number of items in a list.
value_json.result.records | count
Thanks again !
EDIT: updated
rest:
- authentication: basic
scan_interval: 3600
verify_ssl: false
headers:
Content-Type: application/json
User-Agent: Home Assistant
Accept-Encoding: identity
resource: "https://www.data.brisbane.qld.gov.au/data/api/3/action/datastore_search?resource_id=c6dbb0b3-1e00-4bb8-8776-aa1b8f1ecfaa"
- name: GarbageThisWeek
value_template: >
{% set y = value_json.result.records | count %}
{% for x in range(0,y) %}
{% set days = (( as_timestamp(strptime(value_json["result"]["records"][x]["WEEK_STARTING"], '%d/%m/%Y')) - as_timestamp(now()) ) / 86400 ) | round() %}
{% if days >= 0 and days < 7 %}
{{ value_json["result"]["records"][x]["WEEK_STARTING"]}} - {{value_json["result"]["records"][x]["ZONE"]}}
{% endif %}
{% endfor %}
- name: GarbageNextWeek
value_template: >
{% if days >= 7 and days < 14 %}
{% endif %}
{% endfor %}
If you’re interested, you can reduce the template to this:
rest:
scan_interval: 3600
verify_ssl: false
headers:
value_template: >
{% for x in value_json.result.records if 0 <= (strptime(x.WEEK_STARTING, '%d/%m/%Y')|as_local - now()).days < 7 %}
{{ x.WEEK_STARTING }} - {{x.ZONE}}
{% endfor %}
value_template: >
{% for x in value_json.result.records if 7 <= (strptime(x.WEEK_STARTING, '%d/%m/%Y')|as_local - now()).days < 14 %}
{% endfor %}
Thanks… so this will not crash past the 53rd block? Then this is another way to run through all without needing to know the ‘size’, true?
The one thing seemingly missing is the > 7 and <14 etc. as the result can be negative with historical data in the file…but maybe I donot get the jinja well enough
It effectively does a “for each item in the list”, whatever the list’s length may be, so it can’t run past the end of the list.
If you mean the day range test for GarbageNextWeek, it’s part of the for-loop’s if statement.
The if is used to reduce the number of items to be iterated by the for-loop. For example, if I have a list of used cars and I only want to iterate through the ones that are between 2 and 5 years old inclusively:
{% for car in used_cars if 2 <= now().year - car.year <= 5 %}
{{ car.year }} {{ car.model }}
{% endfor %}
So…all back to @AussieByrd now…enjoy the playing around ![]()
Thanks for everyone’s help on this… started getting to mostly what I wanted, but then found “Waste Collection Schedule” on HACS so have switched to that. Appreciate all the input tho… will likely com in handy in other stuff!
Hi Folks!
I’ve the similar problem so do not open a new topic.
Here is my json: https://mapq.waqi.info/mapq2/bounds
My “name” attribute is “Bdul. Dacia, Oradea, Romania” which has an id. It’s id’s attribute is “idx” the number is “6837”
The data what i need is the “aqi” attribute
My rest sensor:
- platform: rest
unique_id: bdul
resource: "https://mapq.waqi.info/mapq2/bounds"
method: GET
scan_interval: 3600
value_template: '{{ (value_json | selectattr("idx", "==", "6837") | list | first).aqi | float }}'
I’ve try many different approach, spent hours to find but no succes. Plese show me what I miss.
