Could you suggest the name of the CT clamp that works well?
Actually not true., This is a voltage sensor not a current clamp. Similar concept but different device.
Apologies. I was confused here.
I use ZMPT101B with D1 mini board.
- VCC to 5V
- Both GND to GND
- OUT to A0 (only analog pin on D1)
update_interval: where to change? if i want 60 sec
Could you suggest the update_interval: where to change? if i want 60 sec?
I want 3 phase votage data so , I am try with ESP32 with GPIO34 but reading is around 4000 V and same thing working ok with D1 mini
SO what is the problem with ESP32? Please help me about, Thank you.
Can u tell me this code work prefect for zmpt101b with esphome
