FIXED: Ecovacs Deebot 2019 & OZMO Series - Working Library
I’m new at homeassistant since a few days. Very nice tool. My Landroid is already working and also some Tasmota devices via MQTT.
I tried integration of “Deebot 960/950/920 vacuum” via HACS. My configuration.yaml:
vacuum:
  - platform: deebot
    username: !secret YOUR_ECOVACS_USERNAME
    password: !secret YOUR_ECOVACS_PASSWORD
    country: DE
    continent: DE
    deviceid: !secret YOUR_DEEBOT_TOKEN
    # Optional
    live_map: False                    # Enable Live Map.. may cause issues on low power hardware | Default: True
    show_color_rooms: False           # Enable draw room colors as in the app | Default: False
    livemappath: 'www/live_map.png'   # Path where to save live_map
However I see no entities for Deebot and get following error in log:
 Protokolldetails ( ERROR )
Logger: homeassistant.components.vacuum
Source: custom_components/deebot/vacuum.py:99
Integration: Vacuum (documentation, issues)
First occurred: 16:59:35 (1 occurrences)
Last logged: 16:59:35
Error while setting up deebot platform for vacuum
  File "/srv/homeassistant/lib/python3.7/site-packages/urllib3/connection.py", line 160, in _new_conn
    (self._dns_host, self.port), self.timeout, **extra_kw
  File "/srv/homeassistant/lib/python3.7/site-packages/urllib3/util/connection.py", line 61, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name or service not known
Has anyone an idea, why is not working?
Regards
Michael
Thank you Andrea for your work. I just bought a Ozmo 920, wich is a great device, and I was very sad to see it couldn’t work in Home Assistant (using ecovacs integration). I was deciding to give it back to the seller. Now wiht your library everything works fine (I didn’t test all) and i love my ozmo even more!
Thanks!
Hmm, seems I habe fixed mit by myself. Settings country and location to us / na.
Thx :slight_smile: @Micha70
Hey @Veuchez, did you work this out? I can’t seem to figure it out myself. Which yaml exactly do they get put in, I tried in the Lovelace yaml, didn’t work, also in the script, that didn’t work either.
Hi. Thanks for developing this and great thread by all! More of a question than issue … I have everything setup with specific icons in the Lovelace card in Home Assistant for each room. I also have HomeKit Bridge setup. I’m trying to figure out a way to get a switch to appear in Home app in iOS so that I can create a scene or ask Siri to clean a specific room by turning on that switch. I can’t seem to figure that out. Basically have a switch appear for each room that sends the Ozmo to clean that room. Any thoughts?
UPDATE: the simplest solution is the best. HomeKit integration will publish scripts as switches. Just check the box in configuration and voilà.
Hi all.
I am just trying to set this up for the first time after stumbling across it.
I am getting a heap of TypeError: argument of type 'NoneType' is not iterable errors
There are other examples of this in this thread, but all have been resolved by updating. Everything is up to date.
Do i just need to fiddle until i get the continent and the country correct ?
Hello!
Yes sure, if you look at a few posts below what you answered you will find my configuration!
Okay I’m making progress with this. I’ve now got the area cleans working. Now I want to add spot cleans, so I can select something like my lounge room rug, just the same way as I can select the rooms. The difference being that the command it sends is map instead of area.
I’m doing something wrong with the syntax because it fails to call the script saying “‘list’ object has not attribute ‘items’”. Obviously it appears the script isn’t populating the vacuum.send_command with any data but I can’t understand how to get to it.
vacuum_clean_zone:
  alias: Cleaning Zone
  sequence:
  - service: vacuum.send_command
    data_template:
      command: spot_area
      entity_id: vacuum.4c5b488e_71ab_4b1f_b14e_ad1b90f8b9d6_2
      params: >-
        {% if is_state('input_boolean.deebot_lounge_rug', 'on') %}
            map: >-
              {%- set x = "" %}
                {% set x = x + "200.0,2000.0,1800.0,-1300.0 " %}
              {% endif %}
            {{x[:-1]}}
        {% else %}
            area: >-
              {%- set x = "" %}
              {% if is_state('input_boolean.deebot_kitchen', 'on') %}
                {% set x = x + "5," %}
              {% endif %}
              {% if is_state('input_boolean.deebot_masterwir', 'on') %}
                {% set x = x + "2," %}
              {% endif %}
              {% if is_state('input_boolean.deebot_guest','on') %}
                {% set x = x + "4," %}
              {% endif %}
              {% if is_state('input_boolean.deebot_flynnbed','on') %}
                {% set x = x + "7," %}
              {% endif %}
              {% if is_state('input_boolean.deebot_masterbed', 'on') %}
                {% set x = x + "1," %}
              {% endif %}
              {% if is_state('input_boolean.deebot_mainbath', 'on') %}
                {% set x = x + "3," %}
              {% endif %}
              {% if is_state('input_boolean.deebot_lounge', 'on') %}
                {% set x = x + "0," %}
              {% endif %}
                {{x[:-1]}}
        {% endif %}
#        cleanings: >-
#              {%- if is_state('input_boolean.deebot_times', 'on') -%}2{%- else
#              -%}1{%- endif -%}
  - service: input_boolean.turn_off
       entity_id: input_boolean.deebot_kitchen
       entity_id: input_boolean.deebot_masterwir
       entity_id: input_boolean.deebot_guest
       entity_id: input_boolean.deebot_flynnbed
       entity_id: input_boolean.deebot_masterbed
       entity_id: input_boolean.deebot_mainbath
       entity_id: input_boolean.deebot_lounge
       entity_id: input_boolean.deebot_lounge_rug
vacuum_script_set_water:
  alias: set vacuum water level
  sequence:
      command: set_water_level
      params:
        level: low|medium|high
Took me some tries to get mine working, so here some notes for anybody interested:
I have a Deebot 900 - NO OZMO. Got it from Amazon.de a while ago: https://www.amazon.de/Ecovacs-Saugroboter-intelligenter-Navigation-Alexa-Steuerung/dp/B07BBZFRZG/
I use https://github.com/Ligio/hacc-ozmo which can be installed when adding manually in HACS as well:
configuration.yaml:
deebot:
  username: [email protected]
  password: mypassword
  country: us
  continent: na
Thank you very much @MaxW !
But are you sure it’s available in HACS becaus I am only able to find one Deebot related integration and it’s another one not working with the Deebot 900.
KR
Oh, it might be possible I added it manually a while ago. As there is no HACS related files in that repository it seems likely. Will edit my post later, thanks for pointing out :v:
@Andrea_Liosi
Hi, I search Deebot-for-hassio in my Hacs but I can’t find it.
Any clue? I wold like to try it. Thx
Anyone could explain me why my card is broken (no info and missing icon) after the xiaomi-vacuum-card upgrade?
Before it works like a charme.
Solutions? Thanks
Immagine 2020-09-18 133325
Thanks for all the help - I am new to Home Assistant and have just integrated the Ozmo950. I am hoping someone can help me with the card, so that my “quick spot zones” are displayes in a second row:
    - type: 'custom:xiaomi-vacuum-card'
      entity: vacuum.deedee
      image: /local/img/vacuum.png
      vendor: xiaomi
      state:
        status:
          key: robot_status
        mode:
          icon: mdi:robot-vacuum
          label: 'Fan speed: '
      attributes:
        filter: False
        sensor: False
        main_brush:
          key: component_brush
          unit: '%'
        side_brush:
          key: component_sideBrush
          unit: '%'
        water_level:
          key: 'water_level'
          label: 'Water level: '
      buttons:
        clean_hallway:
          icon: mdi:road-variant
          label: Clean Hallway
          tap_action:
          action: call-service
          service_data:
            command: spot_area
            entity_id: vacuum.deedee
            params:
              cleanings: 1
              rooms: 0
          type: state-icon
        clean_bedroom:
          icon: mdi:bed-empty
          label: Clean Bedroom
          tap_action:
          service_data:
            command: spot_area
            params:
              cleanings: 1
              rooms: 4
          type: state-icon
        clean_bathroom_toilet:
          icon: mdi:shower
          label: Clean Bathroom & Toilet
          tap_action:
          service_data:
            command: spot_area
            params:
              cleanings: 1
              rooms: 6
          type: state-icon
        clean_lounge:
          icon: mdi:sofa
          label: Clean Living Room
          tap_action:
          service_data:
            command: spot_area
            params:
              cleanings: 1
              rooms: 11
          type: state-icon
        clean_dining_room:
          icon: mdi:silverware-variant
          label: Clean Dining Room
          tap_action:
          service_data:
            command: spot_area
            params:
              cleanings: 1
              rooms: 9
          type: state-icon
        clean_kitchen:
          icon: mdi:toaster-oven
          label: Clean Kitchen
          tap_action:
          service_data:
            command: spot_area
            params:
              cleanings: 1
              rooms: 10
          type: state-icon
Hi, I took advantage of your setting x my 950, as soon as you solve x the second row I would be interested too!
Thank you!
for the Gods love I can`t setup this to run properly …
anyone can do a proper tutorial ?
I have the deebot 950
Has anyone got a deebot to work in HomeKit via h.a?
hey!
Yeah, I got it working for homekit and also a working card right now in HA.
  1. The card I have been using instead of the Xiaomi Vacuum card mentioned above (the one that is broken right now for the OZMO 950) is this one: https://github.com/denysdovhan/vacuum-card. Just install it via HACS.
  • It does work, but I did not get it to display sensor information on the brushes - as I do not really care about that, I did not investigate further. Here is the code in my configuration.yaml:
vacuum:
    - platform: deebot
      username: insert your e-mail here
      password: insert your password here
      country: DE
      continent: EU
      deviceid: insert your device ID here
This is the lovelace UI code, just add it via the GUI and then “manual code”:
actions:
  - icon: 'mdi:silverware-fork-knife'
    service: script.vacuum_clean_kitchen
  - icon: 'mdi:hanger'
    service: script.vacuum_clean_lounge
  - icon: 'mdi:paper-roll-outline'
  - icon: 'mdi:desktop-classic'
    service: script.vacuum_clean_study
buttons:
  locate: true
  start: true
  stop: true
entity: vacuum.juan_son
icons:
  start: 'mdi:some-icon'
  stop: 'mdi:other-icon'
labels:
  battery: Battery
  filter: Filter
  main_brush: Main Brush
  mode: Mode
  side_brush: Side Brush
  water_level: Water
type: 'custom:vacuum-card'
vendor: deebot
And then it looks like that in HA:
If the integration via the configuration.yaml of the deebot worked, you can click on it and should see something like that:
These numbers behind lounge or living room are important, as you need them for the stand-alone scripts to e.g. clean your bathroom via a HA script. They are the content of the scripts below:
And, here are these scripts:
script:
  vacuum_clean_kitchen:
    alias: clean kitchen
    sequence:
        data_template:
          entity_id: vacuum.juan_son
          command: clean
          params:
            act: start
            content: '2,'
            count: 1
            type: spotArea
  vacuum_clean_lounge:
    alias: clean lounge
    sequence:
        data_template:
          command: clean
          params:
            act: start
            content: '15,'
            count: 1
            type: spotArea
  vacuum_clean_study:
    alias: clean office
    sequence:
        data_template:
          command: clean
          params:
            act: start
            content: '13,'
            count: 1
            type: spotArea
  vacuum_clean_bathroom:
    alias: clean bathroom
    sequence:
        data_template:
          command: clean
          params:
            act: start
            content: '5,'
            count: 1
            type: spotArea
Basically, this is everything you need to integrate the deebot, display it via lovelace and add scripts to it to clean different rooms. Everything else (start, stop, pause, return to base) I handle via the official Alexa skill from Ecovacs for the OZMO 950 which is dumb, but does the trick for the basic functions.
  1. Adding these scripts to Homekit is pretty straightforward as well. I just installed the Home Kit Bridge via Settings --> Integrations --> Plus Button --> Homekit Bridge. This will take you through everything. via the GUI. You do need an Apple TV or iPad as a hub I think. Then you can decide what you want to expose to Home Kit and you can see the scripts (e.g. clean bathroom) right in Homekit on your iPhone.
I hope I answered all of the questions!
Hi @XRyu ,
I have T8 AIVI and ECOVACS Home app connect to China server. I have some confusing in my configuration:
username : ECOVACS ID (ECxxxxBH)
country : CN
continent: ww
deviceid: SERIAL NUMBER (E09Axxxxxxxxxxxx0100)
With this config I have error log:
  File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 159, in _new_conn
    conn = connection.create_connection(
  File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 61, in create_connection
  File "/usr/local/lib/python3.8/socket.py", line 918, in getaddrinfo
socket.gaierror: [Errno -2] Name does not resolve
Can you help me
ecovacs_id is not good, you have to put your login credentials that you use for the mobile application and you must also add the password.
see if below
deebot:
  username: YOUR_ECOVACS_USERNAME
  password: YOUR_ECOVACS_PASSWORD
  country: YOUR_TWO_LETTER_COUNTRY_CODE
  continent: YOUR_TWO_LETTER_CONTINENT_CODE
  deviceid:
    - YOUR_ROBOT_ID
