Hi - should this work with the flic twist?
I can see it is sending push button events, but not sure it is picking up any twist events?
No HubLR SDK support for the twist action yet
Message malformed: required key not provided @ data[‘action’]
Sorry for beeing a spamming useless noob
But I copied the code exatly and even called the button “button1” but I get the error message shown on the top.
Can you post the file that you put the code into, there is probably a YAML formatting problem.
I’m having exactly the same issue when I try saving the automation. Here’s the YAML code I pasted into the new automation window:
automation:
- id: flichub_click_webhook
alias: Flic button events from Flic Hub - Webhook
mode: parallel
description: >
Flic Button commands from flic hub
Receive as Webhook
- platform: webhook
webhook_id: abcd1234-flic
variables:
button_name: "{{ trigger.json.button_name }}"
click_type: "{{ trigger.json.click_type }}"
- choose:
- conditions: "{{ button_name == 'button1' and click_type == 'click' }}"
sequence:
- service: counter.increment
entity_id: counter.button_1_clicks
- conditions: "{{ button_name == 'button1' and click_type == 'double_click' }}"
sequence:
entity_id: counter.button1_double_clicks
When I try to save, it generates the error:
If you are pasting it i to a new automation it probs it doesn’t need the
Automation:
Line at the top.
That is there because I use “packages” to manage my yaml.
Try removing it.
