You can use iframe widget, works like charm.
Perfect, I’ll give it a try.
OK, this might sound simple to people, but took me some time figuring out. Using the first method wasn’t working for me, basically because I already have a lot of views. I ended up fixing my 2 floorplans by using:
# groups.yaml
floorplan:
view: true
entities:
- group.floorplans
floorplans:
view: false
entities:
- sensor.last_motion
- binary_sensor.groundfloor
- binary_sensor.firstfloor
Not doing so and only the part ‘floorplans’ with the view on true gets me two sensors and svg’s inside the modal popping up. Glad I fixed it know (and yes I am using both methods). Nice work @pkozul, I really like this addition to my setup.
Will need to play with the group thing though
It would be great if we can add the logging as a debug option.
Sometimes I like to add more entities into the yaml file since it requires a reboot before actually adding them into the svg file. It would be great to have the missing svg entries be optional.
Maybe a
Warnings: entry in the yaml?
Yep, warnings: is now an option in the config. GitHub repo updated to cater for this.
In my configuration.yaml I have the following -
binary_sensor:
- platform: mqtt
state_topic: “home-assistant/window/contact”
How would I go about visualising this sensor in floorplan?
When I have seen this in the past, it was due to an open tag or something in the SVG. Best bet is to start rolling back changes to a known good config. and then build from there.
I keep getting this error:
Failed to load resource: the server responded with a status of 404 floorplan.css?cacheBuster=1498749059177
Is it possible to make grouping optional as well? I was using groups in configuration before as following (the only problem is that toggle service wasn’t working)
- name: DefService
entities:
- group.vlad_restroom_lights
- group.living_room_fan_lamp
states:
- state: 'on'
class: 'light-on'
- state: 'off'
class: 'light-off'
But with recent update I need to represent each object from group separately, which I don’t want to do
I don have them on SVG file grouped together just for visual representation, but I don’t want to control them separately.
Something like
unwrap: false
would be great.
I did not change in original files, just follow mentioned steps.
I tried from begin but no luck.
I think there’s an error in last commit. In ha-floorplan.html change line 636 to be
if ((this.config.warnings === null) || (this.config.warnings !== undefined)) {
Now fixed in the GitHub repo. Thanks for letting me know!
@vkorn, I think the latest version supports groups again. You should be able to toggle them on/off.
Hmm … after testing though, I see the toggle get sent to HA but HA is not shutting down the groups.
A work around is to build an input_boolean and use that a a trigger to shut down a group of lights.
Hi, I have changed line 636 but same problem?
I have Home Assistant ver 0.41.0
Okay, I figure out, problem is chrome. It not loading in chrome browser, work well in fire fox.
Thanks,
@vkorn, thanks
problem solved. after change the line, I just removed browser cache. its working on all browsers.
@mudasar8k, glat it helped, I think pkozul already pushed changes to the repo.
P.S, finally I’m close enough to saying that I’m satisfied with my current setup
Managed to tweak styles depending on device, so on wall-tablet black background and no menu/header.
Thank you for this project!
@vkorn How did you get rid of the top menu bar?
In panels/floorplan.html you’ll need to do following:
Add new style
[hidden] {
display: none !important;
Add new property
showHeader: {
type: Boolean,
value: true,
New attribute to the toolbar element
<app-toolbar hidden$='{{!showHeader}}'>
And do whatever you want inside attached method. In my case I have extended original config and checking who is using UI (looking up IP address of caller) so only on my wall-mounted dashboard I’m changing appearance:
attached() {
var self = this;
var cfg = this.panel.config;
$.getJSON(cfg.ip_service, function (data) {
if (cfg.fs_sources.indexOf(data.ip) != -1 ||
(data.name !== '' && cfg.fs_sources.indexOf(data.name))){
document.body.style.backgroundColor = cfg.fs_color;
self.showHeader = false;
