I think you have done something wrong in inkscape/svg editor then. If you try again:
Make some text in inkscape, and give the correct entity_id to that text. Must be in the top in the layer (not buried in multiple groups etc). Just try again, and see if it works. If you have done anything to the text (combined with the rectangle or something, it is kind of ruined).
To show the temperature multiple places, in inkscape, you just copy and paste the text to the sensor, then group those two texts, remove the entity_id from the original text, and give the group that entity_id instead.
You are right. I tray to create two new object and I grouped this object together and its working.
But I still have another problem both rectangle and text changing colors together. I only wanna have rectangle to change color and text must have always black color? How
Make a template of your sensor, then make a group in floorplan.yaml with that sensor. And for that sensor, use only the text_template. Then change the entity_id of the text in inkscape, to the template sensor.
unfortunately, not as far I know. You can do it with switches by having one switch in a group, then use the group as the other entity_id in the svg. But that’s not possible with sensors. What I do is just make the text change colour instead.
The problem is that you tell that this entity_id should change colours, but what you want is that one of them should change colours, and one of them not. You could use stroke fill instead of fill, then group them, and have just one entity_id on them (then the fill colour of the rectangle would stay the same and just the text and stroke on the rectangle change) but I haven’t testet if this works myself.
Just change the stroke-with in inkscape to have it as thick as you want.
And group rectangle and text template, then give the group the entity_id name.
Then you get colours at both the text and the outlines of your rectangle with one entity id.
It is possible to have one main floorplan for complete apartment and then separate detailed floorplan for each room. When I click on chosen room on main floorplan I get floorplan of room? How?
Hi @Zepixir, is there a way to call out a service?? I would like to have separate icon to control my cover up/close/down instead of the traditional popup menu
Yes, absolutely.
The action part in floorplan.yaml control what action to take.
Like this for my zwave thermostat:
- name: Varme Zwave
entities:
- switch.termostat_stue_switch_svg
states:
- state: 'on'
class: 'heat-on'
- state: 'off'
class: 'heat-off'
domain: switch # This optional parameter allows you to use other services such as homeassistant.toggle like here.
service: toggle
If the action part is missing, the pop-up info window shows up instead.
You probably want to make 3 scripts that do the actions you want, then give the entity_id of that scripts to the buttons you make in your svg-file.
I just upgraded to HA 0.65.6 and the latest version of Floorplan. I have three floor plans set up where I used to be able to click entities to toggle input_booleans. Now all three of them are showing the more-info window instead. I have actions defined for each entity. Does anyone have any idea what could be causing this?
