Floorplan for Home Assistant
Just started with floorplan… I get this error
TypeError: a is undefined
URL: http://192.168.0.205:8123/static/webcomponents-lite.js
Line: 129, column: 615
Error: {}
What could it be ?
Anybody already solved this? Totally annoying bug!
@Thorbeen Just updated some of the code to keep in sync with the HA 0.70 changes.
Can you try Floorplan v1.0.10?
https://raw.githubusercontent.com/pkozul/ha-floorplan/master/www/custom_ui/floorplan/ha-floorplan.html
Using that HTML produces this error message:
Uncaught ReferenceError: className is not defined
URL: http://<HA IP>:8123/local/custom_ui/floorplan/ha-floorplan.html
Line: 593, column: 12
Error: {}
Exact same error with mine - HA 0.70
This is what custom panel throws as an error :
URL: http://:8123/local/custom_ui/floorplan/ha-floorplan.html
Error: {}
Having said do, custom state card throws below being different than above;
URL: http://:8123/frontend_latest/app-653721033e62144d6a686dab25ef1429.js
Line: 2, column: 12049
Error: {}
@Uns which browser are you using?
I also am trying v1.0.10 and receiving the same error shown below. I am still on HA v0.67.1 however, not sure if that should matter. I am using chrome.
Error: {}
OK, found a bug and now fixed. Try Floorplan v1.0.11.
Hmmm, now I have this error:
Uncaught ReferenceError: imageUrl is not defined
URL: https:/redacted/local/custom_ui/floorplan/ha-floorplan.html
Line: 449, column: 22
Error: {}
OK, try Floorplan version: 1.0.12 :slight_smile:
That seems to have worked.
Thanks!
Hi pkozul
This fixed it for me and 0.70 :slight_smile:
Love floorplan just one issue, I’m using the camera fork and the to display feed from camera, problem is the camera doesn’t refresh and just stays the same image unless I refresh the page. do you think this is possible to fix maybe have similar to the HA front-end 10 second intervals ?
thank you
Updated to 1.0.12, and now get the following error:
Uncaught TypeError: Cannot read property ‘entities’ of null
URL: http://redacted/local/custom_ui/floorplan/ha-floorplan.html
Line: 135, column: 60
Error: {}
I have updated to 0.70 Hass.io and version 1.0.12 of FloorPlan but getting this error:
https://my.website.org/local/custom_ui/floorplan/ha-floorplan.html:375:25 Uncaught TypeError: Polymer.dom is not a function
What does that mean?
Its to do with changes to custom-ui in the new update
If you have updated to latest ha-floorplan.html (linked above) and cleared cache and its still doing might have to wait for a fix. I’m using hassio 0.70 and updated to latest floorplan and its working for me, I’m using panels not state cards though.
I have another issue, not sure if its HA 0.70 or 1.0.12 floorplan related, but my weather Images are’nt loading anymore, see image below
The grey squares are supposed to be the weather icon SVG’s both are sunny, you can see one is working but it still shows the grey rect below (didn’t previously) The second weather icon doesnt show at all bottom right corner.
This (1.0.12) has fixed the issue for me (Chrome) - after clearing browser cache. Thanks again for the great work.
I was also getting that error with the same setup. Let me second the suggestion that you clear your browser cache and reload. Worked for me.
I have updated to 1.0.12 and cleared my cache and am still receiving the following error. any ideas?
URL: http://redacted/local/custom_ui/floorplan/ha-floorplan.html 1
Error: {}
