It’s possible, but it’s the same one that works in the original Floorplan and the previous version of this card
Find finds it, which doesn’t surprise me, but I can try removing and adding a fresh one, and worst case rebuild the whole thing
Welll, bleep me, that worked…
WTF
At least now I “only” have to go and re-create a few dozens of carefully placed shapes
I tried all that but it still stays cut off. I don’t know if something else is interfering with this but I don’t have any modifications on that particular view. It’s these from HACS:
battery-state-card.js
floorplan.js
card-mod.js
fold-entity-row.js
hui-element.js
layout-card.js
multiple-entity-row.js
mini-graph-card-bundle.js
stack-in-card.js
text-divider-row.js
banner-card.js?v=1
button-card.js
button-text-card.js
card-tools.js
custom-header.js
swipe-card.js
Thanks for the advice on making it bigger, I’ll definitely do that when this works haha.
So it works fine without the vertical stack? I just tried adding an entity and it is working fine for me with or without the vertical stack. There is something unusual about your SVG I thnk because of how it gets clipped if full_height: true
isn’t added.
Unfortunately I have to sign off for two days as I am going away so hopefully someone else might chime in.
The only other thing to perhaps do just to get it working is I assume this is the background of your floorplan and you will put all the inteactivity on top? If so you can just screen capture the image and save as PNG or export it to PNG from within Inkscape. Then create a new SVG in inkscape and import the PNG as the background image and then go from there. This is how I started my floorplan because I created it in SweetHome3D first. I now just have a bunch of icons and other elements layered on top of it.
Someone else more knowledgable about SVGs might pop in with some better assistance if that won’t work for you. Good luck!
It doesn’t work now with or without the vertical stack. Still clipped on the side. I’ll try to redo the svg file with your instructions, we will see if that helps
Edit: It helped, now I can see the whole plan. Procedure was: Export to PNG > Import back in inkscape > save as SVG.
Now onto making it big
Help please, is it posible to make svg zoom in/out in mobile app (with two fingers)?
In first floorplan version was a key, but it’s missing in ha-floorplan ??
If you want to support panning and zooming within your SVG file, add the following:
pan_zoom:
Look in the app settings. It is in GENERAL in the IOS app
Hi, you speak about zoom? I use an Android app and haven’t this feature…
A quick Google search suggests it doesn’t work on the Android app.You will need to open a discussion in that forum Home Assistant Companion for Android - Home Assistant Community
Hi guys, this would be my first posting here
So i’ve spent many hours getting my floorplan up and running and by now I’ve got one floor of my house pretty much operational. I went over to my phone in the companion app to look at it and in the companion i’m getting an error:
WARNING CONFIG Cannot find element ‘sensor.some-element’ in SVG file
It’s stating that it can’t find a total of 5 elements (a washing machine, a binary sensor from my PC, a group for my window covers, the climate Dyson fan and a media player) out of a total of about 10 (some lights, switches and sensors including that Dyson fan) elements i have implemented by now.
The weird thing is, my HA in chrome can find all of those elements and provide information or toggle them and so on.
What am I doing wrong here?
Could be a caching issue. Do you have the cache: false
option
image:
cache: true
Nope, I didn’t have that option so added it to the yaml code, restarten HA and the companion but had the same result, the same “elements” are somehow still not available in the companion. I also decided to open HA from the mobile device’s browser, in there the entities DO show up…
Looks like an issue with HA floorplan and companion?
Are you using a different SVG for mobile devices?
Ok, so somehow i sort of solved it. Mind you I’m stating a SORT OF…
After adding a new integration to HA i wound up adding NGINX (combination of companion app, smartthings and google nest did not work properly without it).
Now that I’ve got NGINX operational i see ALL of the elements/entities in HA-floorplan in the companion app
Yeah OK it doesn’t appear this is a HA problem then… For what its worth I use the IOS ap and Android app and they both work fine for me…
Ok, so here’s another few questions.
Before i ask them, here’s my setup, for now it’s just the 3rd floor:
And the YAML code that goes with it…
- title: Floorplan
path: floorplan
theme: transparentblue
type: panel
icon: mdi:floor-plan
badges: []
cards:
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: custom:floorplan-card
full_height: true
config:
image: /local/floorplan/zolder/zolder_opt.svg
stylesheet: /local/floorplan/38.css
log_level: info
console_log_level: info
defaults:
hover_action: hover-info
tap_action: more-info
rules:
- name: media players
entity: media_player.spotify_george
state_action:
action: call-service
service: floorplan.class_set
service_data: media_player media_player-${entity.state}
- name: FAN set state
entity: fan.pure_hot_cool_link
state_action:
service_data: fan-${entity.state}
tap_action:
action: toggle
- name: LIGHT set state
entities:
- light.canvas_wall_kantoor
- light.zoldertrap_led
tap_action: false
state_action:
service_data: light-${entity.state}
- name: SWITCH set state
entities:
- switch.wall_plug_switch
- switch.light_switch_2_ch
tap_action: false
state_action:
service_data: switch-${entity.state}
- entity: climate.pure_hot_cool_link
state_action:
service_data: climate-${entity.state}
tap_action:
action: more-info
- name: Cover (zonwering) set state
entity: group.kantoor_zonwering
tap_action:
action: toggle
hold_action: more-info
state_action:
service_data: cover-${entity.state}
- name: LIGHT overlay management
entities:
tap_action:
action: toggle
state_action:
service: floorplan.style_set
service_data:
element: >-
${entity.entity_id.replace('light.',
'light_overlay.')}
style: |
if( entity.state !== "on" )
return "display: none;";
let hue = 0;
let sat = 0;
if(entity.attributes.hs_color )
hue = entity.attributes.hs_color[0];
sat = entity.attributes.hs_color[1];
if( sat < 10 )
return `
display: block;
filter:
brightness(calc( ${entity.attributes.brightness} / 255));`
return `
display: block;
filter:
sepia(100%)
hue-rotate(calc( ${hue}deg - 55deg ))
- entities:
tap_action:
action: toggle
state_action:
service_data:
element: >-
${entity.entity_id.replace('switch.',
'switch_overlay.')}
style: |
let hue = 0;
let sat = 0;
if( sat < 10 )
return `
display: block;
filter:
return `
display: block;
filter:
sepia(100%)
- entities:
- sensor.z_wave_room_sensor_air_temperature
- sensor.pure_hot_cool_link_temperature
state_action:
- service: floorplan.text_set
service_data: >-
${(entity.state !== undefined) ?
Math.round(entity.state * 10) / 10 + "°C" : ""}
- service: floorplan.class_set
service_data:
class: static-temp
- entity:
- sensor.z_wave_room_sensor_humidity
state_action:
service_data: >-
Math.round(entity.state * 10) / 10 + "%" :
"unknown"}
service_data:
class: static-temp
- entity:
- binary_sensor.kantoor_power_status
state_action:
service_data: '${(entity.state === "on") ? "pc-on" : "pc-off"}'
- entity: binary_sensor.node_6_home_security_motion_detection
state_action:
service_data: motion-${entity.state}
- entity: sensor.wasmachine_washer_machine_state
state_action:
service_data: was-${entity.state}
animated_background:
default_url: https://cdn.flixel.com/flixel/ypy8bw9fgw1zv2b4htp2.hd.mp4
entity: weather.home
state_url:
sunny:
- https://cdn.flixel.com/flixel/hlhff0h8md4ev0kju5be.hd.mp4
- https://cdn.flixel.com/flixel/zjqsoc6ecqhntpl5vacs.hd.mp4
- https://cdn.flixel.com/flixel/jvw1avupguhfbo11betq.hd.mp4
- https://cdn.flixel.com/flixel/8cmeusxf3pkanai43djs.hd.mp4
- https://cdn.flixel.com/flixel/guwb10mfddctfvwioaex.hd.mp4
partlycloudy:
- https://cdn.flixel.com/flixel/13e0s6coh6ayapvdyqnv.hd.mp4
- https://cdn.flixel.com/flixel/aorl3skmssy7udwopk22.hd.mp4
- https://cdn.flixel.com/flixel/qed6wvf2igukiioykg3r.hd.mp4
- https://cdn.flixel.com/flixel/3rd72eezaj6d23ahlo7y.hd.mp4
- https://cdn.flixel.com/flixel/9m11gd43m6qn3y93ntzp.hd.mp4
- https://cdn.flixel.com/flixel/hrkw2m8eofib9sk7t1v2.hd.mp4
cloudy:
mostlycloudy:
- https://cdn.flixel.com/flixel/e95h5cqyvhnrk4ytqt4q.hd.mp4
- https://cdn.flixel.com/flixel/l2bjw34wnusyf5q2qq3p.hd.mp4
- https://cdn.flixel.com/flixel/rrgta099ulami3zb9fd2.hd.mp4
clear-night:
- https://cdn.flixel.com/flixel/x9dr8caygivq5secll7i.hd.mp4
- https://cdn.flixel.com/flixel/v26zyfd6yf0r33s46vpe.hd.mp4
- https://cdn.flixel.com/flixel/ypy8bw9fgw1zv2b4htp2.hd.mp4
- https://cdn.flixel.com/flixel/rosz2gi676xhkiw1ut6i.hd.mp4
fog:
- https://cdn.flixel.com/flixel/vwqzlk4turo2449be9uf.hd.mp4
- https://cdn.flixel.com/flixel/5363uhabodwwrzgnq6vx.hd.mp4
rainy: https://cdn.flixel.com/flixel/f0w23bd0enxur5ff0bxz.hd.mp4
And the CSS that works with that:
@keyframes fade-in {
from {
opacity: 0;
to: {
opacity: 1;
@keyframes dash {
to {
stroke-dashoffset: 15000;
@keyframes spin {
from {
transform: rotate(0deg);
to {
transform: rotate(360deg);
@keyframes speaker-pulse {
0% {
filter: unset;
stroke-width: 1;
stroke-opacity: 1;
100% {
filter: unset;
stroke-width: 6;
stroke-opacity: 0;
@keyframes active-pulse {
0% {
filter: unset;
stroke-opacity: 1;
stroke-width: 1px;
filter:blur(1px);
15% {
stroke-opacity: 1;
100% {
filter: unset;
stroke-opacity: 0.1;
stroke-width: 15px;
filter:blur(2px);
@keyframes tv-glare {
0% {
opacity: 0.95;
100% {
opacity: 0.1;
svg, svg * {
pointer-events: all !important;
cursor: auto !important;
svg path {
fill: inherit;
stroke: inherit;
stroke-width: inherit;
stroke-opacity: inherit;
Hover over, wat er gebeurt als je met de muis over een gebied schuift
.floorplan-shape:hover,
g.floorplan-hover > :not(text):hover,
g.floorplan-click > :not(text):hover,
g.floorplan-long-click > :not(text):hover,
:not(text).floorplan-hover:hover,
:not(text).floorplan-click:hover,
:not(text).floorplan-long-click:hover {
stroke: #f78b07 !important;
stroke-width: 5 !important;
stroke-opacity: 0.8 !important;
filter: blur(1px)
de kleur instelling van alle paths in de weergave
Afhankelijk van of een LIGHT of een SWITCH ON of OFF is wordt een andere afbeelding weergegeven
#light-overlays image {
display: none;
mix-blend-mode: lighten;
animation: 0.75s fade-in linear forwards;
#light-overlays image.light-on {
display: block;
#light-overlays image.switch-on {
display: block;
Wat er met de lijnen rond gebieden gebeurt indien hover - aan of uit
#areas {
fill: none;
g#areas path, g#entities path {
filter: blur(1px)
g#entities path {
stroke: blue;
stroke-width: 4;
stroke-opacity: 1;
fill: none;
g#entities path {
stroke: #f5a925;
stroke-width: 3;
stroke-opacity: 0.6;
fill: none;
Als een light of switch GEACTIVEERD wordt, geeft dit feedback (stroke kleur) en worden de PATHs van de AREAs voorzien van een andere kleur rand
g path:active, g use:active, .light-on:active .switch-on:active .cover-closed:active, g#entities > g:active path:not(.touch-area)
stroke: #00ff00 !important;
stroke-width: 5;
stroke-opacity: 0.9;
#areas .light-on {
stroke-width: 5;
stroke: #fcdf03;
stroke-opacity: 0.8;
filter: blur(2px);
#areas .light-off {
stroke-width: 5;
stroke: #f2dfc7;
filter: blur(1px);
#areas .switch-on {
stroke-width: 5;
stroke: #fcdf03;
filter: blur(2px);
#areas .switch-off {
stroke-width: 5;
stroke: #f2dfc7;
filter: blur(1px);
#areas .motion-on {
fill: #ff00002e;
stroke: red;
stroke-width: 5px;
stroke-opacity: 1;
filter: unset;
animation: fade-in 1s infinite alternate;
Wat er met de lijnen rond entities gebeurt indien aan of uit
#entities path {
#entities .switch-on {
stroke-width: 5;
stroke: #fcdf03;
filter: blur(2px);
#entities .switch-off {
stroke-width: 5;
stroke: #f2dfc7;
filter: blur(1px);
#entities .fan-on {
stroke-width: 4;
stroke: #eaff00;
fill: green;
fill-opacity: 0.5;
animation: fade-in 5s infinite alternate;
filter: blur(2);
#entities .fan-off {
stroke-width: 5;
stroke: #f2dfc7;
filter: blur(2);
#entities .pc-on {
fill: #00ff00;
fill-opacity: 0.4;
stroke-width: 4;
stroke: #0bfc03;
filter: blur(1px);
#entities .pc-off {
stroke-width: 5;
stroke: #97a197;
filter: blur(1px);
#entities .was-stop,
#entities .was-finish {
stroke: grey;
stroke-width: 4px;
stroke-opacity: 0.7;
#entities .was-run {
animation: 3s active-pulse infinite;
stroke: blue;
fill: blue;
fill-opacity: 0.4;
#entities .cover-closed {
stroke-width: 5;
stroke: #ab2503;
filter: blur(2px);
fill: grey;
fill-opacity: 0.9;
#entities .cover-open {
stroke-width: 5;
stroke: #f2dfc7;
filter: blur(1px);
#entities .climate-cool {
fill: blue;
fill-opacity: 0.5;
stroke: var(--cool-color, blue);
stroke-opacity: 0.5;
stroke-width: 5;
filter: blur(5px);
filter: unset;
animation: fade-in 3s infinite alternate;
#entities .climate-heat {
fill: #ff8100;
fill-opacity: 0.5;
stroke: #ff8100;
stroke-opacity: 1;
stroke-width: 3;
filter: blur(5px);
filter: unset;
#entities .climate-off {
stroke: #97a197;
stroke-width: 3;
filter: blur(2px);
#entities .media_player.media_player-idle,
#entities .media_player.media_player-standby,
#entities .media_player.media_player-paused {
stroke: var(--paper-item-icon-active-color);
stroke-width: 4px;
#entities .media_player.media_player-playing {
animation: 2s active-pulse infinite;
Temperature text
.static-temp, .static-temp tspan {
fill: #d4c8ba;
opacity: 0.7;
text-shadow: 2px 2px 5px #120c04;
Binary sensors oftewel de motion sensoren
/*svg#floorplan.show-motion-off .motion {
display: none;
svg#floorplan.show-motion-on .motion-on {
fill: red;
stroke: white;
stroke-width: 4;
filter: unset;
.binary-sensor-on {
fill: #f70707 !important;
fill-opacity: 0.5;
stroke: red !important;
stroke-width: 8
.binary-sensor-off {
fill: #8c765b !important;
transition: fill 5s ease;
/* Animation */
.spinning {
animation-name: spin;
animation-duration: 5s;
animation-iteration-count: infinite;
animation-timing-function: linear;
transform-origin: 50% 50%;
transform-box: fill-box;
/* Switches
.switch-on {
fill: blue !important;
.switch-off {
fill: white !important;
stroke-dasharray: 100;
animation: dash 200s linear;
And in the spirit of full disclosure, here’s the SVG file that’s loaded:
<?xml version="1.0" encoding="UTF-8"?>
<svg width="1920" height="1080" version="1.1" viewBox="0 0 1920 1080" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink">
<g id="background">
<image id="main-background" width="1920" height="1080" href="/local/floorplan/zolder/zolder-basis.png" preserveAspectRatio="none" xlink:href="file:///Z:/3D/zolder/zolder-basis.png"/>
<g id="light-overlays">
<image id="light_overlay.canvas_wall_kantoor" width="1920" height="1080" href="/local/floorplan/zolder/zolder-0002.png" preserveAspectRatio="none" xlink:href="file:///Z:/3D/zolder/zolder-0002.png"/>
<image id="switch_overlay.light_switch_2_ch" width="1920" height="1080" href="/local/floorplan/zolder/zolder-0004.png" preserveAspectRatio="none" xlink:href="file:///Z:/3D/zolder/zolder-0004.png"/>
<image id="switch_overlay.wall_plug_switch" width="1920" height="1080" href="/local/floorplan/zolder/zolder-0001.png" preserveAspectRatio="none" xlink:href="file:///Z:/3D/zolder/zolder-0001.png"/>
<image id="light_overlay.zoldertrap_led" width="1920" height="1080" href="/local/floorplan/zolder/zolder-0003.png" preserveAspectRatio="none" xlink:href="file:///Z:/3D/zolder/zolder-0003.png"/>
<image id="group_overlay.kantoor_zonwering" width="1920" height="1080" href="/local/floorplan/zolder/zolder-0005.png" preserveAspectRatio="none" xlink:href="file:///Z:/3D/zolder/zolder-0005.png"/>
</g>
</g>
<g id="areas">
<g id="area.kantoor_george">
<path id="path429" d="m932.85 338.68-4.0914-98.195 2.8474-4.9254 126.26-31.67-8.1446-23.396 215.6-58.802 155.29 363.85-53.615 72.03-330.33 97.361-3.4443 5.1241-29.458-91.802-0.4546-9.5467z" fill="none" stroke="#000" stroke-width="1px"/>
<use xlink:href="#path429"/>
<use id="binary_sensor.node_6_home_security_motion_detection" xlink:href="#path429"/>
<use id="light.canvas_wall_kantoor" xlink:href="#path429"/>
</g>
<g id="area.kantoor">
<path id="path431" d="m1003.3 558.71 0.4546 9.5467-115.68 33.079-2.2863-6.0732-154.6 44.07-15.601-34.804-5.477 1.6237-0.0118 4.8037-91.085 25.378-3.595-3.1652-4.4715 1.0462 0.42719 4.7652 3.7503 4.6506 2.9709 19.306 0.22113 6.1821-132.01 39.49-0.49922-3.3989 8.0586-2.6878-63.561-306.07 275.75-240.85 13.549 49.297 56.582-12.489 20.02 67.549 130.33-34.428 1.2769 4.5066 5.0218 108.64z" fill="none" stroke="#000" stroke-width="1px"/>
<use xlink:href="#path431"/>
<use id="switch.light_switch_2_ch" xlink:href="#path431"/>
</g>
<g id="area.zoldertrap">
<path id="path433" d="m888.09 601.34 60.088 200.69 0.65299 5.4486 121.06-36.307 1.3181-7.0263-34.538-109.21-3.4443 5.1241-29.458-91.802z" fill="none" stroke="#000" stroke-width="1px"/>
<use xlink:href="#path433"/>
<use id="light.zoldertrap_led" xlink:href="#path433"/>
</g>
<g id="area.washok">
<path d="m490.38 707.28 1.0004 3.6998 4.1473 6.8579 45.683 212.51 407.62-122.88-0.65299-5.4486-60.088-200.69-2.2863-6.0732-154.6 44.07-15.601-34.804-5.477 1.6237-0.0118 4.8037-91.085 25.378-3.595-3.1652-4.4715 1.0462 0.42719 4.7652 3.7503 4.6506 3.192 25.488z" fill="none" stroke="#000" stroke-width="1px"/>
</g>
</g>
<g id="entities" fill="none">
<path id="group.kantoor_zonwering" d="m1409.7 477.45-36.809 48.526-132.4-320.73 22.905-70.459z" stroke="#000" stroke-width="1px"/>
<path id="fan.pure_hot_cool_link" d="m991.68 472.21 17.998-3.945c0.3727 0.80556 0.1169-4.1203 0.1169-4.1203 0.4606 0.47643 0 0 0 0 2.1045 0.26975 5.5449-1.0471 5.5449-1.0471l3.3212-4.3418c1.7613-9.6469 0.9992-13.206 0.9992-13.206-0.6853-2.4192-0.066-0.98012-2.0559-7.2575 0 0-1.2012-5.6166-10.55-14.417 0 0-1.5506-1.2391-3.9786-0.30127 0 0-2.7358 1.2084-3.7711 3.7548-1.2449 0.25476-0.92758 4.3402-0.92758 4.3402s0.11055 2.4417 0.36319 5.4509l-12.992 3.6962 0.47998 2.5996-2.1603 0.59767c-0.8373 2.2465 0.62446 10.404 4.2458 15.551l-0.074 3.4793z" stroke="#b32800" stroke-width="1.0016"/>
<path id="climate.pure_hot_cool_link" d="m991.68 472.21 17.998-3.945c0.3727 0.80556 0.1169-4.1203 0.1169-4.1203 0.4606 0.47643 0 0 0 0 2.1045 0.26975 5.5449-1.0471 5.5449-1.0471l3.3212-4.3418c1.7613-9.6469 0.9992-13.206 0.9992-13.206-0.6853-2.4192-0.066-0.98012-2.0559-7.2575 0 0-1.2012-5.6166-10.55-14.417 0 0-1.5506-1.2391-3.9786-0.30127 0 0-2.7358 1.2084-3.7711 3.7548-1.2449 0.25476-0.92758 4.3402-0.92758 4.3402s0.11055 2.4417 0.36319 5.4509l-12.992 3.6962 0.47998 2.5996-2.1603 0.59767c-0.8373 2.2465 0.62446 10.404 4.2458 15.551l-0.074 3.4793z" stroke="#b32800" stroke-width="1.0016"/>
<path id="binary_sensor.kantoor_power_status" d="m1214.7 246.53 13.099 35.521 12.858-3.3753-6.9112 20.573-12.617 3.0538-10.857-28.798 4.4281-26.975 12.537-3.0538 13.582 35.199-13.019 3.3753-6.6701 20.252 6.6701-20.252z" stroke="#000" stroke-width="1px"/>
<path id="switch.wall_plug_switch" d="m1213.8 207.02 22.662-6.4291 137.74 332.71-25.234 7.072z" stroke="#000" stroke-width="1px"/>
<path id="media_player.spotify_george" d="m1085.9 230.37 120.7-32.845-8.8648 38.641-118.54 31.027z" stroke="#000" stroke-width="1px"/>
<path id="sensor.wasmachine_washer_machine_state" d="m840.11 725.32 20.172 67.817-20.172-67.817 6.5444 33.488 16.413 51.751 64.44-19.321-64.44 19.321-2.7854-17.421 66.203-18.947 1.0229 17.048-1.0229-17.048-20.457-67.964z" stroke="#000" stroke-width="1px"/>
</g>
<g id="sensors">
<g fill="#000000" font-family="sans-serif" font-size="40px">
<text id="sensor.z_wave_room_sensor_air_temperature" transform="rotate(-15 921.82 806.01)" x="1290" y="673" style="line-height:1.25;shape-inside:url(#rect58646);white-space:pre" xml:space="preserve"/>
<text id="sensor.z_wave_room_sensor_humidity" transform="rotate(-15 1299.8 859.94)" x="1315" y="538" style="line-height:1.25;shape-inside:url(#rect58646);white-space:pre" xml:space="preserve"/>
<text id="sensor.pure_hot_cool_link_temperature" transform="rotate(-15 983.14 485.09)" x="1040" style="line-height:1.25;shape-inside:url(#rect9182);white-space:pre" Y="470" xml:space="preserve"/>
</g>
</g>
</svg>
Feeling pretty good about the progress so far.
I’ve been able to get the temperature showing from both a room sensor and the dyson hot+cool fan. Also the humidity is showing and i’ve got css animations working for music playing, PC on, motion detected, washing machine operational, lights on/off, dyson fan heating/cooling so yay…
As you’ll notice there’s still a lot of doubling and trial and error in here It’s a work in progress.
Thanks to the lengthy tutorial from BitBorn i’ve been able te reconstruct most of what he did, somewhat that is.
Now for my questions:
I don’t have time at the moment to have a close look but some I can help with straight away. Before I get to that can I advertise the github discussion area that is great for complex questions like this: https://github.com/ExperienceLovelace/ha-floorplan/discussions
I don’t know which entity is the Dyson fan but you should be able to use the same shorthand javascript that you have for sensor.pure_hot_cool_link_temperature
there you are testing for undefined but you will change that to whatever the state is when it is off.
- entities:
- sensor.wupws_temp
name: Colour Coded Sensors
state_action:
service_data: '${entity.state != "unavailable" ? Math.round(entity.state) + "°" : "?"}'
service_data: |
var temp = parseFloat(entity.state.replace("°", ""));
if (temp < 10) return "temp-low";
else if (temp < 30) return "temp-medium";
else return "temp-high";
If you mean show a camera image on tap then just make the tap_action
service more-info
Hey @OzGav thanks for the quick reply
- entities:
state_action:
service_data: >-
Math.round(entity.state * 10) / 10 + "°C" : "OFF"}
service_data:
class: static-temp
service_data: |
var temp = parseFloat(entity.state.replace("°", "OFF"));
if (temp < 17) return "temp-low";
else if (temp < 22) return "temp-medium";
else if (temp < 25) return "temp-medium-high";
.temp-low, .temp-low tspan {
fill: #c0d3ed;
opacity: 0.7;
text-shadow: 2px 2px 5px #00429e;
.temp-low, .temp-medium tspan {
fill: #bcedb2;
opacity: 0.7;
text-shadow: 2px 2px 5px #20b004;
.temp-low, .temp-medium-high tspan {
fill: #e0d0a8;
opacity: 0.7;
text-shadow: 2px 2px 5px #b07c04;
.temp-low, .temp-high tspan {
fill: #e0a8a8;
opacity: 0.7;
text-shadow: 2px 2px 5px #f70000;
Yes so you can just add icons to your SVG (if using Inkscape they can be SVG or PNG) and then, using the camera as an example, just give the icon the ID of camera.yourcam and then in your yaml you just add an entity of camera.yourcam and tap_action of more-info
As for 2 you would do something like
${(entity.state !== “NaNC”) ? Math.round(entity.state * 10) / 10 + “°C” : “OFF”}
I don’t have the exact code with my as I am on the iPad but it will be something like that. You just need to put the exact wording of the sensor state when it is off
