I have a problem with script invocation which I can’t seem to resolve. I wonder if you (or anyone) can offer advice.
I have a collection of binary sensors linked to corresponding SVG elements. CSS updates are all working nicely and the entity info frame pops up when the associated SVG component is clicked. I now want to execute a script when an SVG element is clicked. My script is in place and executing as expected from the Home Assistant configuration interface.
I have added an action clause to my configuration which references the script, but the script does not get called when I click on an SVG element. No configuration errors and no runtime errors, just no action. The entity info panel continues to pop up as before and I wondered if this was pre-empting the click action? Have I missed something. My configuration is:
Not 1:1 with your needs, cause it’s related to browser_mod.
Else, taks a look at the docs?
And let us know, if you’re getting stuck . If so, please consider to create a New discussion on GitHub. It’s fine to ask here - but much easier for other to find inspiration, by having each question in a dedicated topic .
I looked at the example, it seems like it uses some classes in the SVG itself to change the picture, instead of poting to a different SVG altogether? Wasn’t quite able to use it the way I wanted.
I’ve spent quite some time today, but have not been able to find a solution that actually works. I am trying to setup my floorplan to use of 90% of the left side of the screen (column A, to give it a name). Then have a stack of cards on the right 10% of the screen (column B)
I created the following to illustrate what I want to do:
Sounds like you are looking for the “Sidebar view” that was introduced with the new Energy panel.
When creating a new view you can select the type (dropdown at bottom of View configuration popup).
We’re helping out where we can. But it’s not a all-round topic, for things not related to the component. The question asked, are mentioned many times before - and therefore, I’m asking the person to do a bit of research.
A simple search would have done it:
home assistant hide top bar
Or anything like that.
Please respect that we’re trying to keep the not ha-floorplan related stuff, to a minimum.
We’re using hours on this, and doing our best to help people our…
I have never tried a thing like this, but shouldn’t that be possible with column in Lovelave? If you’re not making any progress, I can try and see what’s possible.
Sorry maybe a stupid question. But I try to install floorplan and I´m totally stucked on this step: " 5. Remember to add the /hacsfiles/ha-floorplan/floorplan.js as a module to your resource file - like you do with other modules." https://experiencelovelace.github.io/ha-floorplan/docs/quick-start/
Yes, it is there. But it doesn´t shows itself if I try to add new card in Lovelace editing. There is just not card with floorplan or ha-floorplan name. Maybe I should add it manualy via YAML?
Hello Oscar,
After hours of research I just came across your project.
I am trying to document myself to try to do the same things, I manage to put 1 light but the config with several I can not.
could you show me your yaml code or tell me what’s wrong with me?
thank you in advance for your help
type: picture-elements
image: >-
/www/Floorplan/Plan%20Maison%20nuit.png
elements:
